Old 12-05-2012, 05:38 PM   #13831
Canadian FJR
Oddometer: 128
"The o-rings listed here http://advrider.com/forums/showthread.php?t=528038 also fit the DR350's BST33."
Thanks for the reply, we'll be chatting.
HandKPhil - very nice DR, the mate of it is sitting in my garage.
Canadian FJR
Canadian FJR is offline   Reply With Quote
Old 12-05-2012, 05:52 PM   #13832
tntmo
Oddometer: 528
Originally Posted by shearboy2004 View Post
Yep you right about the bearing swap and I believe the only difference between the rotors is that the SE model had 6 bolts and all dirt ones have 4 so keep what you have . I could be wrong , it has happened at least once before.
I have a 98 dirt model, it has the six bolt front rotor.
Buncha dirt bikes with license plates.
tntmo is offline   Reply With Quote
Old 12-05-2012, 06:34 PM   #13833
shearboy2004
KIWIINUSA
shearboy2004's Avatar
Oddometer: 4,424
Ok that's 1 wrong for me !! Bugger it I'm going riding and not looking at this thread until tomorrow so I'm not wrong twice in one night !
88 R100GS
75 Norton Commando Roadster
98 DR450
07 Sherco 510 called Holy Shit .450 Sherco called Bling .
13 Sherco 300i called The Bee's Knees .
shearboy2004 is offline   Reply With Quote
Old 12-05-2012, 07:33 PM   #13834
dirtyron
never grew up
Oddometer: 342
walmart batterie
mine just died. need one fast. any walmart fits? 96 se
dirtyron is offline   Reply With Quote
Old 12-05-2012, 09:18 PM   #13835
Airvent
Airvent's Avatar
Oddometer: 347
Originally Posted by HandKPhil View Post
Hi All,
Just picked up a super-clean '99 SE a couple of days ago. Just over 1500 miles on it. This is my first DR350.
I'm a dyed-in-the-wool KLR250 guy. Love 'em so much I've got two of them. They'd be the perfect small bore dual-sport bike for me, if only they'd given them a little more power and an e-start - hence my desire to experience the DR350.
Due to weather conditions and a total lack of free time, I've only put one mile on this bike since I got it, and that was on a slippery, muddy road, in the pouring rain. My initial impression was that the bike is indeed a little peppier than my KLR250's. Also, the DR seems to have really comfortable ergonomics for me. Given my very brief test ride, it's not that I could tell how it's going to feel after an hour in the saddle, but the bike does seem to fit me perfectly so far. I like the taller suspension vs. the KLR250. The bike also seems more dirt-oriented than the KLR. Weight feels about the same.
Anyone else out there have any KLR250 experience that can make an informed comparison?
I find the two bikes very similar as far as intended purpose. A true 50/50 dual sport. The DR350 is just so much better in every way. Lighter, more power, better frame, suspension, brakes, durability, aftermarket support, etc.
I'm a current DR350 owner and a former KLR250 owner. I rode the snot out of one for 15k miles.
Airvent is offline   Reply With Quote
Old 12-06-2012, 03:56 AM   #13836
cwc
Oddometer: 939
I also believe that all Suzuki did with the axle of the 99 was to use the same one that is in a whole shitload of RM's , lots of these parts cheap on fleabay .
I did an RM fork swap and was able to use my 99 axle and spacers .
Any idea of the date range for the RM axles?
I've got newer fork legs that I want to put on my 97.
They are presently mounted to my DR650 for testing, but I'd like to get the parts to mount them on the 350.
Charlie
DR350 It'll get you there
My Ride Reports Here
cwc is offline   Reply With Quote
Old 12-06-2012, 11:36 AM   #13837
MrPulldown
MrPulldown's Avatar
Oddometer: 3,391
Based on this:
http://oem-cycle.com/KawasakiDR350.shtml
This is what you need:
http://www.ebay.com/itm/2004-suzuki-...badc88&vxp=mtr
old Froks are 15mm axles. Newer ones are 17mm
MrPulldown is online now   Reply With Quote
Old 12-06-2012, 01:57 PM   #13838
3uba296
Thumpcurious
3uba296's Avatar
Oddometer: 134
Again I could be wrong but that would be twice in one night .
Not all Dirt have 4 bolts, 97-99 have six, same pattern as the RM´s. Also did RM250-92 fork swap to my DR350-97 and all DR stuff bolts right up to the forks, wheel, spacers, axle, caliper..
Dr350(80)R-97
3uba296 is offline   Reply With Quote
Old 12-06-2012, 03:44 PM   #13839
RuggedExposure
Now with more rugged
RuggedExposure's Avatar
Oddometer: 1,247
I ordered my Acerbis tank for $148. The DR350 tank came back in stock from the supplier and I decided to go with that instead of the xr250/400/650 tank.
I wouldn't have any issues fabbing up brackets for it, but I was concerned about leg room (I'm 6'2") and the added weight.
The fear and dread of you will fall on all the beasts of the earth
RE Fotowerks
Border Road 100 Border Road Rally Raid
'13 Husky Terra 650, '08 Kawasaki Meanstreak 1600, '95 DR350S
RuggedExposure is offline   Reply With Quote
Old 12-06-2012, 06:02 PM   #13840
markk900
markk900's Avatar
Oddometer: 468
Originally Posted by Canadian FJR View Post
In need of some O-rings. 1999 DR-350 SE, float needle and seat look great but the seat is real loose. I need a replacement O-ring for the seat and also one that hold the float frame in place. Where can I buy just the O-rings?
Canadian FJR
Local dealer will have them - just bought a set for a couple of dollars.
markk900 is offline   Reply With Quote
Old 12-06-2012, 07:39 PM   #13841
a1fa
Throttle Jockey™
a1fa's Avatar
Oddometer: 13,881
What's a fair price on 1993 DR350 with 6000 miles?
What's a good quiet exhaust for DR350?
Autodecompression mod?
Learn to ride. Ride to learn.
a1fa screwed with this post 12-06-2012 at 08:07 PM
a1fa is offline   Reply With Quote
Old 12-06-2012, 09:31 PM   #13842
ctjohnson
Oddometer: 27
Just got some new fork boots in the mail. I have the manual but one thing is confusing me. I need to remove the front wheel(taking off the caliper, the odometer cable guide, brake hose holder, the 4 axle holder nuts, and the axle.) Then loosen the 4 clamp bolts to slide out the fork.
Questions:
Do I do one fork at a time?
How to ensure I re-install them straight?
Any other things to look out for or pretty straight forward?
ctjohnson is offline   Reply With Quote
Old 12-07-2012, 03:57 AM   #13843
Greg Bender
Oddometer: 1,216
Questions:
No need to do one fork at a time. As long as the front end is supported (which it must be to remove the front wheel, etc), then you can do them both at the same time.
No need to worry about reinstalling them in the same position. The tubes are round and straight and the lowers can rotate around them.
This is a good time to change the fork oil (and the seals if they are leaking).
Hope this helps!
Regards,
Gregory Bender
Greg Bender is offline   Reply With Quote
Old 12-07-2012, 04:02 AM   #13844
Greg Bender
Oddometer: 1,216
A fair price really depends on where you are located and what mods have already been done. I'd say a reasonable range would be anywhere from $1000 - $1500, some more if suspension or other highly desirable upgrades.
A good quiet exhaust is the original muffler. I love 'em.
I own a 1993 DR350 (dirt) and it has manual decompression. It is not difficult to use and I would never think of modifying it for auto decompression. On models that came with auto decompression, I doubt I would go to the trouble of modifying it for manual decompression.
After priming pumps, my DR350 with CV carb is a 1 - 2 kick starter. This is the same as when it was fitted with its original Pumper carb.
Hope this helps!
Regards,
Gregory Bender
Old 12-07-2012, 05:16 AM   #13845
tntmo
Oddometer: 528
Price for one like that here in CA would be $500-$1500, depending on condition.
Best quiet exhaust is the stock exhaust, modified by KienTech.
The only way to add auto-decompression is to switch heads with a 94 or newer DR. They also had a different kick start ratio on the 94+ models, they are a lot easier to start.
Times are GMT -7.   It's 09:26 AM.
