12-02-2012, 07:06 AM
#5866 |
Motoswami
Oddometer: 51
cruddy gas tank
Ratchdaddy said:
"We are going to have to clean the tank real good. Somewhere in the past the tank was creamed or some other treatment. Now it is coming off in spots. The petcock was clogged with a gummy substance." Suggestion: in the meantime, an in-line filter might prevent having to re-do the carb cleaning job. Good daddy showing your son how things work. Too bad he wasn't on hand for the magic moment when the planets lined up just right and it fired up. Pete |
12-02-2012, 01:23 PM
#5867 |
All-season-rider
Oddometer: 88
Life is a just a game - lets play! |
12-02-2012, 02:57 PM
#5868 | |
Oddometer: 134
I knew I should have used the inline filter but the parts store was 20 minutes away and we were on a roll this morning. We spent the morning cleaning the tank. Layers of the cream crap came out and lots of rust but no leaks.. Cleaned the petcock good and the screen. I thought the tank was clean enough the the petcock screen would catch anything if there was still some crud. I was wrong. She started right up and we were riding her around for about 30 min before the carb gummed up again. Oh well, we know how to pull it off now. The other problem that became evident was that the clutch in the new engine may be bad. I am going to pull it apart later. It does not disengage. I am thinking probably warped plates or a weak spring. Anyone have any thought on this? I have the good clutch from my other engine but I looked online and a fleabay clutch pack is only 40 bucks so I may go that route if necessary. Back to the garage. Turns out that I am also missing all the air cleaner parts. I will tear apart the garage and my storage unit to see if they were missplaced. I dont remember if I ever had them at all. Any good alternatives such as a pod airfilter that anyone has done?
Ratchdaddy 2010 F800 GS 1988 NX250 |
12-02-2012, 04:17 PM
#5869 | |
Oddometer: 226
I've got a tank and an airbox for sale.....
Buncha dirt bikes with license plates. |
12-02-2012, 04:26 PM
#5870 |
Oddometer: 335
Ahhh look its a snow lepeaord nice kitty
Goes to show ya Hondas ultra reliability
12-02-2012, 11:42 PM
#5871 | |
All-season-rider
Oddometer: 88
Best of luck
12-02-2012, 11:53 PM
#5872 | |
All-season-rider
Oddometer: 88
Some bigger studs would be better on the ice, but this slippery ice its rather seldom to experince on the roads here, so... :-)But it's cold to drive now. It's alot moisture in the air, so it's not comfortable to breath..
12-05-2012, 03:18 PM
#5873 |
Oddometer: 78
Winter
I bought my NX as a skeleton with a bunch of boxes and put it together. Then I blew it up. Then I fixed it again. I made a MCCT and I've been riding it almost everyday since then. It's been between anywhere between 20-65F here and it never skips a beat. 20* morning, crack the throttle once, close the choke, and it start like a champ. I mainly commute in the city and I can't really fault the bike. I know that was its original intended purpose and I'm finally getting to enjoy it as such. I'm able to park next to the GS's, KTMs, and DRZs and just smile as I walk into work. Sure they look great, but the NX is economical, simple, nimble, and peppy enough to make a city commute fun - and dissuade me from modding my car.
Anyway, the point of this post is to say that despite the fact that my NX qualifies as an antique next year I'm thoroughly enjoying it and I wasn't sure I ever would after it exploded. I plan to continue driving it through the winter a part from when there is snow/ice on the streets. Any other winter commuters in here? I need to change out to fork oil and do an oil change this weekend. To my knowledge, a fork oil change is dead simple: pop out the drain bolt, pump the fork a couple times, replace bolt, and then crack the tops off and refill with 13.9oz of ATF. I wanted to add PVC spacers as well as a cheap preload to counteract the marshmallow fork. What size PVC has been used? 1.5" or 2" diameter? I know there are better ways to do this, but I'm just looking to take a little of the brake dive out of it and have a bit better ride. Stay warm and ride on! |
12-05-2012, 04:58 PM
#5874 |
Oddometer: 335
Right now my nx sits in the garage uninsured and not registered,Im debating if i wait till spring or not to go get it on the street.Right now money has been kind of tight.
12-06-2012, 04:19 AM
#5875 |
Oddometer: 1,832
if money is tight now,
what makes you think it will be less tight after xmas? |
12-06-2012, 06:52 PM
#5876 |
Oddometer: 335
It wont be less tight and sad to say if we fall off fiscal cliff alot of us are going over w it I feel.THis bs is gonna bankrupt america. Hell I might just have to park the car n truck an ride more
Im german,ya know what they say about germans,ya just cant keep a good german down![]() ![]()
12-07-2012, 04:53 AM
#5877 | |
My First Gold Chain
Oddometer: 301
Using 15 wt (150 lb rider) or 20 wt (200 lb rider) fork oil will slow the fork compression and delay the bottoming of the springs espessially with an inch less of fork travel when using preload spacers. This is the order used from top to bottom: White PVC Spacer, 1 1/16" in diameter, cut SQUARE at 15/16" in length 1/16" thick stainless steel flat washer 1 1/4" diameter Short factory Spring Factory Washer Long Factory Spring Same feelings here on the NX. Every couple of months I think about replacing it. With what? High strung dualsport - requires an oil change every 6 hours of use - No way Another reliable dualsport - have one - I'm Swiss - Why spend money on a newer version of what I have. Keeping this bike FOREVER! |
12-07-2012, 09:26 AM
#5878 |
tractus pro pensio™
Oddometer: 1,564
If anyone has a plastic DRIVE SPROCKET COVER for the left side,
Please PM me, with a price.... When my chain exploded this week, it busted mine up... Luckily, i was only going 3mph when the chain locked up and wrapped around the CS sprocket... All I need is the little plastic cover that keeps your pants from getting chewed into the drive chain.. Thanks ya'll, Ride Safe! |
12-07-2012, 10:05 AM
#5879 | |
Oddometer: 226
I had the same thing happen, the master link went bye-bye and the chain destroyed the cover. I salvaged most of my parts and glued them back together, but it's still not all there. Sort of like my mind.
12-07-2012, 06:58 PM
#5880 | |
Back Roads Explorer
Oddometer: 168
Cover Repair
Maybe this would help if you decide to repair the old one. http://www.plastex.net/Home_Page.php I haven't tried it but seems like a possible repair item if that's the way you have to go. |
