Old 12-07-2012, 06:17 AM   #13846
cwc
Oddometer: 925
Originally Posted by MrPulldown View Post
Based on this:
http://oem-cycle.com/KawasakiDR350.shtml
This is what you need:
http://www.ebay.com/itm/2004-suzuki-...badc88&vxp=mtr
old Froks are 15mm axles. Newer ones are 17mm
Thanks. That's an interesting page.
I ordered the other link. If the speedo drive has some life it will be a good deal.
Presently shopping for frocks.
Charlie
DR350 It'll get you there
My Ride Reports Here
cwc is offline   Reply With Quote
Old 12-07-2012, 08:31 AM   #13847
flyinfuzz
2 Quarts low
flyinfuzz's Avatar
Oddometer: 1,867
How about changing the clutch rod oil seal.? Does it pop out the top or need to pull the clutch cover to push it out from the inside ? 1998 sew . It figured since I lubed its chain it would return the favor and lube my boot
Cotton says : This is as screwed up as a rope with 3 ends
flyinfuzz is offline   Reply With Quote
Old 12-07-2012, 08:44 AM   #13848
Greg Bender
Oddometer: 1,171
IIRC, it pops out the top. Can be removed using typical "dental pick" tools. Just be careful not to gouge anything and you'll be set. Pretty easy, actually.
Regards,
Gregory Bender
Greg Bender is offline   Reply With Quote
Old 12-07-2012, 12:45 PM   #13849
wawarides
where's Laura0107?
wawarides's Avatar
Oddometer: 1,203
Originally Posted by dirtyron View Post
mine just died. need one fast. any walmart fits? 96 se
If you're near a Batteries Plus store, you could see if they have this one. I've never tried it, though; I always just use Yuasa.
Sandlapper Braaaappper - Savannah River Rambling - SC Dirt! - On a perpetual dirty road tour in the land of Hicks and Nothing - Twitter: @wawarides - Instagram: @wawarides
wawarides is offline   Reply With Quote
Old 12-07-2012, 02:35 PM   #13850
kobukan
almost gnarly
kobukan's Avatar
Oddometer: 1,712
Regards,
Gregory Bender
+1
"Dig" it out from the top. Just make sure you get everything out and the hole is nice and clean before you try putting the new one in or it won't go. A little oil in the hole and on the new seal will help it slide in.
'04 R1150GS, '97 R1100GS, '99 DR350, '02 DR650, '03 DR650
A Few Days Solo to Copper Canyon
A Maine Rider’s Arizona Day Trips
A Few Days Solo in Baja
kobukan is offline   Reply With Quote
Old 12-07-2012, 06:31 PM   #13851
flyinfuzz
2 Quarts low
flyinfuzz's Avatar
Oddometer: 1,867
Thanks $ 2.75 seal $ 5.50 shipping
Old 12-07-2012, 07:25 PM   #13852
a1fa
Riding Nomad™
a1fa's Avatar
Oddometer: 13,816
quiet exhaust anyone?
Learn to ride. Ride to learn.
a1fa is offline   Reply With Quote
Old 12-07-2012, 08:08 PM   #13853
Stretch67
Bent, But Not Broken
Stretch67's Avatar
Oddometer: 6,439
Are you asking if anybody has one for sale, or who prefers quiet over aftermarket loud? My 250 came with a scrapped-together POS homebrew pipe that sounded like crap, so I found a good used pipe on FleaBay. Nice and quiet.
I did the same with the gutted pipe on my new '98 XR400... stock quiet pipe from eBay. I hate loud pipes.
IBA # 33113
Alaska
Blue Ridge Parkway & Outer Banks
XR400 Index
Stretch67 is offline   Reply With Quote
Old 12-07-2012, 11:10 PM   #13854
RuggedExposure
Now with more rugged
RuggedExposure's Avatar
Oddometer: 1,243
Just put on new front sprocket, rear sprocket, chain, changed the oil and adjusted the valves.
While I had the tank off, I took a pic of my security switch I installed. I don't have a fancy key ignition like the SE owners, so I put on a kill switch before the spark plug and stuffed it to where I can barely fit my fat finger under the tank and engage it.
The fear and dread of you will fall on all the beasts of the earth
RE Fotowerks
Border Road 100 Border Road Rally Raid
'13 Husky Terra 650, '08 Kawasaki Meanstreak 1600, '95 DR350S
RuggedExposure is offline   Reply With Quote
Old 12-08-2012, 08:19 AM   #13855
kobukan
almost gnarly
kobukan's Avatar
Oddometer: 1,712
I've thought about doing something like that, but if I'm really nervous about where I'm leaving the bike I shift it into a high gear (4th, 5th or 6th) and switch the headlight all the way off. On the Baja Designs handlebar switch I have the bike won't run with the switch in that position. I figure most thieves won't know that, and even if they figure it out they're going to make a lot of noise stalling out repeatedly before they ever find a gear they can take off in.
Old 12-08-2012, 11:29 AM   #13856
TopDeadCenter
TopDeadCenter's Avatar
Oddometer: 344
Quick question about the auto decomp on a '94 se. Is there supposed to be a lever sticking out of the valve cover? I thought the auto decomp models didn't have anything there. Mine does but doesn't have a cabel or bracket. Am I missing something here? Did someone put an older head or motor into this bike?
TDC
I wear a helmet in public! Yeah!
GS850GLX
DR350SE
TopDeadCenter is offline   Reply With Quote
Old 12-08-2012, 11:48 AM   #13857
canyonkid
Does it Matter
Oddometer: 23
if you look at this link MrPuldown posted
you can check your motor serial # to see if it matched your model year bike.
canyonkid is offline   Reply With Quote
Old 12-08-2012, 04:08 PM   #13858
slartidbartfast
Love those blue pipes
slartidbartfast's Avatar
Location: Southern Louisiana or Southern England or ...
Oddometer: 4,863
As likely as not only the top end would be changed if someone messed with the engine for some reason. If the bike does indeed autodecompress then those parts are inside. If it doesn't then it needs a cable and lever fitting.
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100
January 2010 New Zealand South Island ride
Summer 2009 UK to Alps ride
Summer 2008 UK End-to-End ride
slartidbartfast is offline   Reply With Quote
Old 12-08-2012, 04:08 PM   #13859
RuggedExposure
Oddometer: 1,243
My ADV stickers finally came in.
RE Fotowerks
Old 12-08-2012, 04:23 PM   #13860
Bonerov
Damned dirty ape
Bonerov's Avatar
Oddometer: 434
Nice ammo boxes. I have a pair of boxes that I want to install on my DR, but haven't figured out how I want to mount them yet. I will likely end up having a buddy help me fab up something custom. So many projects, so little time (and money).
Bonerov is offline   Reply With Quote
Times are GMT -7.   It's 02:10 AM.
