Old 12-06-2012, 08:38 PM   #6451
Night Falcon
Adventure NZL
Night Falcon's Avatar
Oddometer: 2,163
Originally Posted by numbutt View Post
Ho-hum it must be winter in USA/north..threads are becoming mundane..!!.... thought id follow some others in disabling the sidestand switch...( in a slow quest to reduce ? the ocasional flame-out when racing to a stop )
Another inmate suggested a 1K to 3K resistor to repace the hall switch putting this resisror between the pink and black wires [ there are 3 wires going to the switch pink, black and blue ].
I did a few tests to ceate some understanding and what we have is a blue wire that supplies a regulated 5 Volts from the ECU to power the switch [ the switch is a Hall device [ linear response to a magnet ] coupled internally to a Schimdt trigger level detector that provide a snap action . [ hope im not boring anyone ]. Anyway, at ignition switch on, 5V is sent to blue and without the Hall connected the pink wire also reads 5 Volts. With the Hall switch in place and activated [ stand up ] the pink wire is locked down to 2.50Volts. Black is the earth wire or at earth potential [ 0 ].. I did a few tests to establish the ( voltage ) effect of adding the first mentioned resistor ''cheat '' to ''pull down '' the pink wire to about 2.5 Volts .
3.3K gives 3.02 volts
2.7K gives 2.78 Volts
2.2K gives 2.52 Volts [ test resistors between black and pink ]
1.8K gives 2.27 volts
1.5K gives 2.06 Volts
1.0K gives 1.6 Volts
After all this bull we must conclude that probably the best resistor to use is 2.2k { 2200 ohms } ...a standard value and i used a 1 watt metal oxide type [ most stable ] [ fortunately i carry many of every resistor 1 ohm ...1 Meg ohm at home so its an easy test !! ]
So after all that #&*@# , simply cut wires to stand above connector near shock, solder in 2.2 K ohms between Pink and Black, heat shrink it, then isolate and heat shrink off the blue so it cant short....and Bobs your uncle ....
great report but you lost me after "it must be winter in the USA/North"
My EXC530 Adventure
My KTM690 Adventure
2008 250 Beta Rev3 - Trials with lots of errors
Night Falcon is offline   Reply With Quote
Old 12-06-2012, 09:41 PM   #6452
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,550
Call me lazy but I just bought a pre-made side stand switch and plugged it in.
Seth S
Seth S is offline   Reply With Quote
Old 12-07-2012, 12:04 AM   #6453
motoged
motoged's Avatar
Oddometer: 908
Yeah....I was gonna say that.
But some of these guys know how to make a simple job so effin complicated
Ged the Luddite
Ged Schwartz
Kamloops , BC
Baja '05 , Baja 06/07 , Baja 08/09 , BC Alpine Single Track
motoged is offline   Reply With Quote
Old 12-07-2012, 02:28 AM   #6454
ktmmitch
Oddometer: 632
3-Wheeler 690 Fun!!
We are currently working with Torque Racing on a customers very special machine.
It is a brand-new EML chassis that has been specifically designed to accept the KTM 690 Enduro engine,and we are currently working on manufacturing a new airbox,and silencer and radiator mountings to finish it off.
It had Reiger shocks all round,and the workmanship on the chassis is fantastic.
It will become a road-legal enduro machine,and I would love to have a go in it!!!
ktmmitch screwed with this post 12-07-2012 at 02:43 AM
ktmmitch is offline   Reply With Quote
Old 12-07-2012, 04:29 AM   #6455
LOZ
Oddometer: 1,209
its all happening at your place!!!!
LOZ is offline   Reply With Quote
Old 12-07-2012, 06:31 AM   #6456
Seth S
Seth S's Avatar
Oddometer: 4,550
fits the eariler bikes too?
Seth S
Old 12-07-2012, 06:33 AM   #6457
Seth S
Seth S's Avatar
Oddometer: 4,550
Ged the Luddite
I have learned over time that if someone has already taken the time to make a viable solution then it is often worth the cost of buying it vs the cost and time of creating your own solution. If there is no existing solution or the existing solution can be improved upon then its worth the effort.
Seth S
Old 12-07-2012, 08:34 AM   #6458
DirtJack
DirtJack's Avatar
Oddometer: 1,580
Most of us have used 2.2K ohm 1/4 watt resistor when disabling most any sensor/control. Seems to work well.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 12-07-2012, 10:22 AM   #6459
tattewell
Mad Poser
tattewell's Avatar
Oddometer: 778
Gave up on this POS. Bought an Africa Twin, and as soon as I get back to Canada in July, mine's for sale.
Excellent attempt KTM, but you shit the bed on waaaaaay too many issues to attempt to fix. Still love my 450 EXC.
tattewell is online now   Reply With Quote
Old 12-07-2012, 11:26 AM   #6460
TheMuffinMan
Forest Ranger Magnet
TheMuffinMan's Avatar
Oddometer: 6,007
After owning a 950 the list of 'issues' for the 690, as well as the time it takes to fix them is ridiculously lower
To each's own! Good luck.
"To strive, to seek, to find, and not to yield."
"You don't cross the mountains, they let you through."
KTM 525 XC-W // KTM 950 Adventure
TheMuffinMan is online now   Reply With Quote
Old 12-07-2012, 11:27 AM   #6461
TheMuffinMan
Oddometer: 6,007
Progress on the wiki!!
http://convulsingmuffin.com/690wiki/index.php/Main_Page
Old 12-07-2012, 01:39 PM   #6462
TheMuffinMan
Oddometer: 6,007
What I need now is content.
Links to posts that have valuable content about mods, explanations of procedures, maintenance, known issues, etc. I'll polish the wiki categories and layout a bit this weekend and will start adding content as we find it.
For now I've created a new thread so we don't spam this one with links to posts/data to be added to the wiki.
Wiki Thread
Oh, does anyone have a Logo we can use that isn't copyrighted or something? I'm also go to see if I can get some sort of skin for the wiki pages.
TheMuffinMan screwed with this post 12-07-2012 at 02:02 PM
Old 12-07-2012, 02:01 PM   #6463
ktmmitch
Oddometer: 632
Yes Seth,from 08-on
Old 12-07-2012, 03:28 PM   #6464
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,004
Wiki Thread
My wife offered to make a logo, do you want Her to do it? I've never gotten a response from you, so just making sure I'm not on your ignore list.
Just say'IN
crankshaft is offline   Reply With Quote
Old 12-07-2012, 04:16 PM   #6465
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,680
Good? How does this help the thread? What useful information did you share?
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
Times are GMT -7.   It's 03:14 PM.
