Old 12-06-2012, 09:25 PM   #15451
Shibby!
Oddometer: 1,657
Originally Posted by bill pierce View Post
Thanks for the input. Does that TM40 make it easier to start.
Most say yes, but I didn't have an issue with the stock carb.
Every once and awhile I still have a bear of a time starting it but that's normally with elevation different than what it's jetting for and tip-over or stall under high load.
It's normally a 1-2 kick start.
Tour of Idaho T1 Challenge - https://spotwalla.com/tripViewer.php...551f1642711d75
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! screwed with this post 12-06-2012 at 09:31 PM
Shibby! is offline   Reply With Quote
Old 12-06-2012, 10:37 PM   #15452
sintax
Oddometer: 495
That is a HUGE yes on my part!
sintax is offline   Reply With Quote
Old 12-07-2012, 10:24 AM   #15453
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,615
I'd think so too, you get to squirt a little fuel with a pumper, then start it. I have TM40's on another bike and they're great, still get 42 or so on the road and 30 mpg in the dirt. One TM40 per 575cc cylinder.
Old 12-07-2012, 11:12 AM   #15454
sintax
Oddometer: 495
Honestly its made me super lazy.
When the bike is cold i'll pull the choke (no squirts), pull in the decomp, clear it out with a few strokes, get the bike so it will kick through with the auto-decomp, kick it through once or twice and it till fire up and purrrrrrrrrrr
Does anyone have any logic about how the auto deomp works? It seems like sometimes mine will only be auto decomp, and then sometimes I go to kick it and its like not there and its full compression? So if i actuate the decomp i can kick it through a time or two and then the auto decomp will work again.
Its been a mystery to me since i've gotten this bike (i'm a two stroke guy at heart, but actually contemplating buying a 4stroke as a dez bike too)
Old 12-07-2012, 11:24 AM   #15455
BigNastybrp
Big Nasty
BigNastybrp's Avatar
Oddometer: 694
I run the Mikuni HRS 42mm Carburetor it has more circuts and jet in easy, I love it.
the tm40 is for a two stroke but lots of the guys run them. I found it cheaper to get the hrs42 off ebay for $200 and the cables from motion pro $100. or the fcr41 off a crf250 you can get them cheap as well. Bert
BigNastybrp is offline   Reply With Quote
Old 12-07-2012, 11:38 AM   #15456
sintax
Oddometer: 495
Kind of half true. there is a 2 stroke version of the TM40 available that was built for snow machine use. This version of the carb does not have an accelerator pump. But its not the same carb we use for our bikes.
Old 12-07-2012, 12:06 PM   #15457
BigNastybrp
Big Nasty
Oddometer: 694
good to know thanks thats the one on my work bench for sell cheap
Old 12-07-2012, 12:52 PM   #15458
medisyn
Oddometer: 149
Originally Posted by Sierra Thumper View Post
I have to say, the IMS 4.7 that came on my xrl is one tough, solid fitting sob. Its taken some hard shots over its 8 year life and the damn thing is indestructible.....its barely even scratched. And it fits absolutley ROCK solid, and has never moved an inch from an impact.
Personally if I was buying another tank, I'd spend the extra for an IMS......I've been that impressed with mine
Does the IMS fit with the spal/ktm fan?
medisyn is offline   Reply With Quote
Old 12-07-2012, 04:51 PM   #15459
bill pierce
I don't wana pickle
bill pierce's Avatar
Oddometer: 741
Where did you guys get your TM40? I see Sudco has them. Was the jetting close when you bought it? looks like they are selling for around $500.
bikes
BMW R1100s,destroyed by deer strike.
Yamaha FZR 1000 (sold)
Honda Cr 500 sold
bill pierce is offline   Reply With Quote
Old 12-07-2012, 05:52 PM   #15460
sintax
Oddometer: 495
Powerbarn!
my jetting was not that close, but easily fixed
Old 12-07-2012, 08:58 PM   #15461
jm-2008
jm-2008's Avatar
Oddometer: 507
Tm40
[QUOTE=bill pierce;20200608]Where did you guys get your TM40? I see Sudco has them. Was the jetting close when you bought it? looks like they are selling for around $500.
Powerbarn -
Good guy, helpful and delivery here in Oz was about as quick as most things are from the USA
He will/should have some benchmark settings by now.
Has had a fair amount of feedback from a number of us re settings/altitude & engine config.
Mine was reasonably close for a stock motor/side cover/exhaust etc.
Moved the needle one clip and changed pilot & airscrew otherwise as good as I can tell.
Starts/runs OK
Plenty info on the Edddy vs TM40 thread
JM-2008
jm-2008 is offline   Reply With Quote
Old 12-07-2012, 10:26 PM   #15462
bill pierce
I don't wana pickle
Oddometer: 741
Thanks guys,
They don't list that carb on their web site so I call.
bikes
Honda Cr 500 sold
Old 12-07-2012, 11:54 PM   #15463
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,384
[QUOTE=BigNastybrp;20194483]...40k+ with out a rebuilt.../QUOTE]
That's awesome. Put a lot of miles on my 650R too and am approaching 10,000 on the KTM that replaced it. Only hope it's half as reliable as the BRP. So far so good. Who else has a high-mileage XR?
jesusgatos is offline   Reply With Quote
Old 12-08-2012, 03:30 AM   #15464
BuRPsa
Finally growing up..
BuRPsa's Avatar
Oddometer: 548
The 4.6 gallon IMS fits a Spal 4", the 7g does not.
As an aside, the KTM-fan is a Spal in a shroud.
BuRPsa is offline   Reply With Quote
Old 12-08-2012, 10:00 AM   #15465
Shibby!
Oddometer: 1,657
I ran the sumo fenders but they break off when I hit the sand bank then you get to run 800 miles home from Las Vagas. See
In ten 11+ year I have run my xr650r I have tried to do the valves every 800 to 1000 miles and oil. at 40k+ with out a rebuilt from new. if you are going to do some thing take the time to do it Right
I have about 40,000 KM on mine. Oil changed every 2000 KM on trips, and valves checked/adjusted every 4000.
I wasn't talking a sumo fender. Those things are just plain ass ugly. I run a CRF450 fender. Takes some trimming in the back area, but in my opinion it looks 100x better then any sumo or stock fender.
Times are GMT -7.   It's 08:09 AM.
