Old 12-07-2012, 12:41 PM   #1
ebrabaek OP
Oddometer: 2,843
A whole lot'o slapping going on....
After I got the 18 inch tubeless build with the stock gearing supersprox, I have had my share of chain slap. I have adjusted the chain loos ( about 5cm as per manual), and tight at 3cm....... 2mm camber left...... 2mm camber right.... And nothing seems to help. Have had non of this before the new wheel. Excel 18 inch tubeless....supersprox. A fantastic combo..... Chain is the stock installed after the recall. Had 1500 miles from new when I changed the wheel. I know about needing to change it all, when installing a new sprocket, but through out my life on bikes.... I never had this. It happens at neutral torque, on the bottom 1/3 of the chain. Drives me nuts. Next is a new DID chain with a master link. I was just curious, if any have had this happen after the taller 18 inch rear....???
Erling
ebrabaek is online now   Reply With Quote
Old 12-07-2012, 05:04 PM   #2
Motorfiets
Motorfiets's Avatar
Location: North of Jack Daniel's, South of Country Music
Oddometer: 2,974
does it have a tight spot possibly?
Motorfiets is offline   Reply With Quote
Old 12-07-2012, 06:02 PM   #3
ebrabaek OP
Oddometer: 2,843
Could be... I will check this tomorrow. This is the second build rear wheel, and they both started this, so perhaps, unless by chance they both have a tight spot, I'd like to blame the chain. It gets worse with 2 up..... That's why I tried to go over/under with tension, as it changes a little with second up. It only happens at neutral torque. pull a little power, it goes away... or let go of the throttle a little....It goes away. I have checked with the builder, and they have been awesome, and are stumped as well. It is time for a DID with a master link anyway.
Erling
Old 12-09-2012, 12:11 PM   #4
mapuda
Crash Tested
mapuda's Avatar
Oddometer: 249
Erling,
Have you considered a chain guide?
Bartron & Indy's solution.
http://www.advrider.com/forums/showt...=407174&page=2
The BRP part
Good judgement comes from experience. Experience comes from bad judgement.
mapuda is offline   Reply With Quote
Old 12-09-2012, 03:07 PM   #5
ebrabaek OP
Oddometer: 2,843
Originally Posted by mapuda View Post
Erling,
The BRP part
I actually have. I am in the planning stage of a Carbon Fiber/K-39 chain guide. It most likely would solve this. Only thing is ....This issue has me stumped, and I know there are a few fellow inmates that runs the same conversion as I. I was just curious if they had experienced anything similar. Mine will be savoring the same function as the BRP in the linky above, but situated further forward, and with a few more tricks. Cup holder.... toolbox....Etc......Uhhh.....and...ehhh... extra zip ties.....
Erling
Old 12-09-2012, 03:09 PM   #6
ebrabaek OP
Oddometer: 2,843
Just checked for rear sprocket roundness. It is 100% true, and round. I would expect nothing else from this great wheel builder. Before switching I did not measure the with of the stock sprocket, and compare with the supersprox. Perhaps some one would be so great as to measure their stocker.....
Erling
Old 12-10-2012, 12:27 AM   #7
Mike.C
Stelvio Dreamer!
Mike.C's Avatar
Oddometer: 522
Maybe not, I have installed the BRP guide and still have to listen to Sir Slap a Lot making his presence known. FWIW with standard sprockets and chain it never happened, installed Supersprox and he reared his ugly head. installed a DID chain and he calmed down a bit, but is still a distraction.
After talking to a mate with a KTM 990 I now just ignore it, or try not to have the engine revs/ground speed in the slap spot.
Cheers, Mike
Don't just look at it - Ride the bloody thing!
Mike.C is offline   Reply With Quote
Old 12-10-2012, 02:20 AM   #8
Snowy
Oddometer: 1,116
Too tall a gear for the road speed.
Mine has a couple of tight spots, a slightly out of round rear sprocket, and a chain guide.
It slaps. You get used to it.
But my chain and rear sprocket have 50000km on them, so new ones will be on there soon. I think the tight spots have worn the sprocket weird.
My trail videos. Yes, I need to learn to edit. Baby steps...
https://www.youtube.com/user/DRMZ650?feature=mhee
Snowy is offline   Reply With Quote
Old 12-10-2012, 05:46 AM   #9
ebrabaek OP
Oddometer: 2,843
I see... Did 525 it is then..... I was thinking that with a chain guide between 1/3 -1/2 forward from the rear sprocket would minimize it, but yet as you mentioned might it help, as my dry has one, and is stil slapping. What gets me here is that it does it at all speeds....all gears... Neutral torque.
Erling
Old 12-10-2012, 06:01 AM   #10
runnin4melife
Oddometer: 481
Would be interesting to try the stock sprocket and see if it disappears (I know you don't have one now). The only thing I can think of since you have a relatively new chain is that perhaps the cush drive in the new hub is culprit. If it is exceptionally rigid or has too much play it could lead to a slack issue that can compound with a tight spot and creat a rather annoying slap. The only real way to determine this is to change one component at a time.
This could explain the "at all speeds" issue because even at a steady speed the cush drive is bouncing back and forth just do to rotational inertia and friction differences etc... I am not an engineer but have had enough physics (for the inevitable science driven drivel that will undoubtedly appear on this post).
runnin4melife is offline   Reply With Quote
Old 12-10-2012, 06:11 AM   #11
ebrabaek OP
Oddometer: 2,843
I don't think it's too tall geared... at least in my case, because when I first got this fantastic combo, I started with a 45 tooth rear supersprox, but as it was great for the trail, it was too low on the streetside, So I went to a 41. I guess I will just ignore it.
Erling
Old 12-10-2012, 06:14 AM   #12
ebrabaek OP
Oddometer: 2,843
Could be.... The cush drive for the 950 ( Excel billet hub) is tight. I would say a bit tighter than stock. The rubber pieces are a bit smaller, but harder to press in. I will start with the Chain. What is your with of your stock sprox..... ??? I think the Supersprox is a few mm's thinner....
Erling
Old 12-10-2012, 06:15 AM   #13
runnin4melife
Oddometer: 481
Will measure when I get home (2-3 hrs) do you want width and then the radius and circumference?
Old 12-10-2012, 06:26 AM   #14
ebrabaek OP
Oddometer: 2,843
Just the with Adam, as I just looked, and the Supersprox has about 1.5mm space to "wobble" the chain....
Erling
Old 12-10-2012, 08:05 AM   #15
mapuda
Crash Tested
mapuda's Avatar
Oddometer: 249
Does the chain slap at speed but with the clutch in? You mentioned it slaps at zero torque which I take to mean not under a load. Maybe it is the pulse of engine firing that causes the chain to slap?
Just trying to wrap my head around it.
Times are GMT -7.   It's 07:47 AM.
