Old 12-07-2012, 06:12 PM   #71671
Rumlover
Ed
Oddometer: 707
Originally Posted by vfr870 View Post
I believe that's a large white decal on the headlight cowl. I put a Acerbis headlight on my KLX and it came with a big white decal that looks just like the above pic.
Correct. It was stock on the 2007 DR. Should be able to order it.
Edit: Looks like it's on the 06 as well -- and maybe some other years too
Rumlover screwed with this post 12-07-2012 at 06:27 PM
Rumlover is offline   Reply With Quote
Old 12-07-2012, 06:40 PM   #71672
TrophyHunter
Oddometer: 2,310
Learn something new around here every day. Part of the enjoyment IMO.
'07 WR450 2013 HD Road King '15 Tiger 800 XCx
TrophyHunter is offline   Reply With Quote
Old 12-07-2012, 06:54 PM   #71673
sunthechip
Oddometer: 143
Yeah... I'll paint it myself - I'm not paying $40 for a piece of tape
Or if anyone has one that they havent used, I'll take that. I'll give you a fair price
sunthechip is offline   Reply With Quote
Old 12-07-2012, 09:49 PM   #71674
planemanx15
planemanx15's Avatar
Oddometer: 1,009
Originally Posted by Tex76 View Post
You're doing it wrong
Yea... Literally just broke off. It was the strangest thing, I wasn't even touching it, it just fell. I think the previous owner might have glued it. It seems to have some residue on it.
2000 Suzuki DR650-790 - 790cc Big bore build thread
1985 Yamaha CA50 - The little scooter that Could
2009 Piaggio BV-250 - Escusi, Babba be bo-bee
planemanx15 is offline   Reply With Quote
Old 12-07-2012, 10:07 PM   #71675
shaddix
Oddometer: 647
So my bike is an hour away and I am trying to buy some clear hose on amazon that will fit on the bleeder valve but I don't know what diameter hose will fit on the caliper... Does no one know or can measure?
shaddix is offline   Reply With Quote
Old 12-08-2012, 04:31 AM   #71676
mrprez
KJ4WMZ
Oddometer: 1,265
The stuff I use is .325 OD. .2 ID.
I use one of these:
http://www.amazon.com/Motion-Pro-08-...=brake+bleeder
Sent via morse code
mrprez screwed with this post 12-08-2012 at 04:46 AM
mrprez is offline   Reply With Quote
Old 12-08-2012, 07:16 AM   #71677
planemanx15
Oddometer: 1,009
Originally Posted by Rusty Rocket View Post
It's kinda like a breaker-bar for the axle wrench.
Cool thank you.
Old 12-08-2012, 10:17 AM   #71678
shaddix
Oddometer: 647
I use one of these:
Thank you!!
Old 12-08-2012, 11:02 AM   #71679
jhomc1300
Oddometer: 13
Clutch basket nut
So I stupidly thought I could do the NSU screws without mishap, but of course I was wrong. I am in the process of putting things back together, and realize that I don't know how tight the bolt that holds the basket on should be. Should there be any freeplay when pushing the basket back and forth on the shaft? If so how much? Thanks.
jhomc1300 is offline   Reply With Quote
Old 12-08-2012, 11:42 AM   #71680
sandwash
sandwash's Avatar
Oddometer: 1,371
Clutch basket nut at 36 ft/lbs.Not the bolts for the clutch springs.
97dr650
sandwash is offline   Reply With Quote
Old 12-08-2012, 11:55 AM   #71681
jhomc1300
Oddometer: 13
Clutch basket nut
Long before I get to 36# the plate holder will no longer free wheel. Maybe I am doing something else wrong.
Old 12-08-2012, 12:06 PM   #71682
jhomc1300
Oddometer: 13
Clutch basket nut
Sorry to have bothered everyone. I went to the parts diagram, then went to the shop, and found the missing washer, now it works fine. The bike is a 2008 with 6000 miles and the NSU screws came loose with only very minimal pressure. Thanks again.
Old 12-08-2012, 03:15 PM   #71683
blk-betty
bam-a-lam
blk-betty's Avatar
Oddometer: 2,493
Broken Header Pipe - Only 6K miles
'09 DR650 just turned 6K miles today and about 20 miles from home exhaust got a little bit louder. About 10 miles got a whole lot louder. Figured it was a crack somewhere on the head pipe as that where the sound was coming from.
Thought about stopping and worried a little about doing engine damage but had no other way to get home so babied it the last 10 miles.
WTF! The head pipe is broken clean off at the flange where it bolts up and there is about 1/2" gap 360 degrees, actually looks like someone cut it off with a rough blade hacksaw.
Is this a common occurence?
Only motor mods are opened up breather box with DT-1 air filter, Pro-Cycle jet kit, and GSXR1000 muffler with Kientech mid-pipe on OEM header.
Anyone have a spare oem header or is there a better option.
Any day on a dirt road is a great day
blk-betty is offline   Reply With Quote
Old 12-08-2012, 03:26 PM   #71684
suguzzi
Greybeard
suguzzi's Avatar
Oddometer: 37
Sounds to me like someone got over zealous grinding the internal header weld. You can go too far!
suguzzi screwed with this post 12-08-2012 at 03:28 PM Reason: spelling
suguzzi is offline   Reply With Quote
Old 12-08-2012, 03:28 PM   #71685
aardschok
Fallout Rider
aardschok's Avatar
Oddometer: 562
You might could check with a sign shop for a piece of white vinyl for a few pennies. That's what I did for added colour to my helmet. Counter person says "I don't know what to charge for a 6" square piece of scrap, just buy something here next time you need a sign."
"When you have to shoot...Shoot! Don't talk."
MVT
aardschok is offline   Reply With Quote
Times are GMT -7.   It's 11:31 PM.
