Old 12-07-2012, 04:11 PM   #76
firewall738
Kawasaki long range
Oddometer: 2
klr exhaust
i know this is off topic but... i'm looking to get an exhaust system for my 2012 klr and i've been looking at either the fmf bomb or a yoshimura pipe, just a slip on, does anyone have reccomendations?
firewall738 is offline   Reply With Quote
Old 12-07-2012, 04:52 PM   #77
GAS GUY OP
MILE EATER
GAS GUY's Avatar
Oddometer: 3,397
Buy the Leo Vince muffler.
It comes with a USFS spark arrestor and multiple baffle tubes so you can make it quiet or louder.
When my bike rolls out of the garage in the spring it will have one.
2008 KLR 705-2004 ST1300-2001 FZ1
2001 GAS GAS 321
IBA # 23,716
http://gasguysadventures.blogspot.com/
GAS GUY screwed with this post 12-08-2013 at 07:16 AM
GAS GUY is online now   Reply With Quote
Old 12-07-2012, 05:03 PM   #78
GAS GUY OP
MILE EATER
GAS GUY's Avatar
Oddometer: 3,397
Hole location for Torsion spring
Here is a pic of the hole that was drilled for the spring.The hole looks to be at about 8:00 oclock.
But 7:30 was the recommended location in 2008, and now with the latest springs it is recommended to be at just a bit past 6:00 o clock.
I talked to Eagle Mike about it and he said it could have broke from being over tensioned or damage from installation if the wrong tools were used.
So, I am going to drill a new hole at just past 6 o clock.
2001 GAS GAS 321
IBA # 23,716
GAS GUY screwed with this post 12-08-2013 at 07:17 AM
Old 12-07-2012, 06:02 PM   #79
GAS GUY OP
MILE EATER
GAS GUY's Avatar
Oddometer: 3,397
New Torsion spring installed
For those not familiar with it, this is how it should be attached.
2001 GAS GAS 321
IBA # 23,716
GAS GUY screwed with this post 12-08-2013 at 07:18 AM
Old 12-07-2012, 08:41 PM   #80
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Your first post in this thread really says a lot. Values to be admired. Nice to see so much positivity here ... as opposed to that god awful KLR HP thread. Some real KLR haters showed up there ... true Trolls. Worst of ADV Rider. Your thread is the opposite!
I'm a DR650 rider but have owned two KLR's in the past (an '85 KLR600 and '98). I recently spent a couple hours on a buddies very well set up '09 KLR. It was a nice surprise. I like my DR650 (well modified) but I could easily be seduced by the much better looking KLR. (I prefer the NEW style).
Lots of temptation out there regards new bikes ... but I too must reduce debt and expenses. Any extra money ... and free time ... has to go into actually doing the riding, which to me ... is what it's all about. RIDE RIDE RIDE!! All the best with your new bike ! it's a beauty!
Old 12-08-2012, 01:08 AM   #81
davidb21
Oddometer: 90
lmao that thread game me like 2 hours of entertainment at work today just reading all the back and forth bs
davidb21 is offline   Reply With Quote
Old 12-08-2012, 02:56 AM   #82
kojack
My Hardley is a POS
kojack's Avatar
Oddometer: 970
Dr650 is a great bike like everything, once modified to your needs. The biggest issue with the Dr from the showroom is the size of the tank. Easy fix. Then you can go and go. The 3rd gear is blown way out of proportion as well. Its all good.
Sent from my ARCHOS 80G9 using Tapatalk 2
kojack is offline   Reply With Quote
Old 12-08-2012, 08:08 AM   #83
GAS GUY OP
MILE EATER
GAS GUY's Avatar
Oddometer: 3,397
Deep hole fix
While I was in here correcting the Torsion spring I also needed to address the deep Hole issue that affects all 2008 and alot of 2009 bikes.
If you are unaware of this, Google it ,and you will find all the info about it.
You can see in the pic, the odd bushing wear at the bottom right of one of the bushings that the pin sets in that supports one of the starter gear transfer clusters.
Basicly, the hole in the outet cover is too deep, which allows the pin to go into it to far and not support the gear cluster on the inside properly, so you have to put a spacer in the hole in the cover to prevent it.
Alot of people use various things but Eagle Mike has the proper spacer so I just got one from him.
2001 GAS GAS 321
IBA # 23,716
GAS GUY screwed with this post 12-08-2013 at 07:21 AM
Old 12-08-2012, 09:03 AM   #84
GAS GUY OP
MILE EATER
GAS GUY's Avatar
Oddometer: 3,397
Here is the spacer supplied from EM.
2001 GAS GAS 321
IBA # 23,716
Old 12-09-2012, 02:01 PM   #85
Murphy Slaw
Murphy Slaw's Avatar
Oddometer: 1,594
Great thread.
Murphy Slaw is offline   Reply With Quote
Old 12-09-2012, 03:13 PM   #86
kojack
My Hardley is a POS
kojack's Avatar
Oddometer: 970
So anything above 2010 is not affected by the hole?
Old 12-09-2012, 04:03 PM   #87
GAS GUY OP
MILE EATER
GAS GUY's Avatar
Oddometer: 3,397
That is correct.
But it is a very simple fix, you only have to pull the outer cover and put the spacer in the hole.
2001 GAS GAS 321
IBA # 23,716
GAS GUY screwed with this post 12-08-2013 at 07:22 AM
Old 12-10-2012, 01:28 AM   #88
kojack
My Hardley is a POS
kojack's Avatar
Oddometer: 970
Originally Posted by GAS GUY View Post
That is correct.
Oh yeah. Just making sure, I'm going after a 2012 and just want to makes if I have to order this part or not.
Old 12-10-2012, 03:03 AM   #89
PWRCRZR
Grumpy Old Bastard
PWRCRZR's Avatar
Oddometer: 7,593
I am paying down debt.I am tired of bills, and just want some simplicity in my life.I am going to leave the high tech, expensive bikes for the rich.
Nice looking bike and a good life plan.
I have been leaning this way for several years. Resisting the urge to replace my KLR with something newer, fancier and more expensive. In the end a well set up KLR gets the job done just fine for me.
However, I am not complaining because I know that I am probably better today then I will be tomorrow, so I try and enjoy every day as it comes, and stay determined to live well and be appreciative of what I still can do..."Stromsurfer"
PWRCRZR is offline   Reply With Quote
Old 12-10-2012, 06:24 AM   #90
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,557
I rode a buddy's 2008 just like yours - well, except it was stock (but with Kawasaki-replaced rings to fix the oil issue). I was surprised at how much more neutral and comfortable the bike was compared to my DR650. I can see the KLR's ergonomics easily making a prior GSA-rider happy... and that whole package you bought really making anyone happy.
Mambo Dave is online now   Reply With Quote
Times are GMT -7.   It's 06:27 PM.
