Old 12-07-2012, 01:34 PM   #1
TheMuffinMan OP
Forest Ranger Magnet
TheMuffinMan's Avatar
Oddometer: 6,371
690 Wiki Thread
KTM 690 Wiki Link
I've created this thread to assist in organizing what needs to be added to the 690 wiki, and what hasn't been added to the 690 wiki.
In your post please provide a title for the item and a link to the information. When I add it to the Wiki I'll throw it into the list at the end of this post
List of Topics I've added to the Wiki
Canisterectomy - http://ktm690.info/index.php/Canisterectomy_-_Bartron
SAS Removal - http://ktm690.info/index.php/SAS_Removal_-_Bartron
RR Tanks Install - http://ktm690.info/index.php/Rally_R...tall_-_Bartron
HOW Updates - http://ktm690.info/index.php/690_Hall_of_Wisdom
KTM Windshield Install - http://ktm690.info/index.php/KTM_Win..._Install_-_TMM
Suspension Tuning by James Siddall at Superplush Suspension - http://ktm690.info/index.php/The_Basics_-_James_Siddall
'08 and '10 Wiring Diagrams - http://ktm690.info/index.php/Electrical
Salvens Racing Rear Shock Removal Video - http://ktm690.info/index.php/Rear_Sh...Slavens_Racing
Spring Rate Database - http://ktm690.info/index.php/Spring_Rate_Database
Fuel Pump and Filter R&R - http://ktm690.info/index.php/Fuel_Pump_R_%26_R_-_Uller
Valve Shim Calculator Spreadsheet - http://ktm690.info/index.php/File:Va...Calculator.ods
"To strive, to seek, to find, and not to yield."
"You don't cross the mountains, they let you through."
KTM 525 XC-W // KTM 950 Adventure
TheMuffinMan screwed with this post 12-23-2012 at 10:01 PM
TheMuffinMan is offline   Reply With Quote
Old 12-07-2012, 01:46 PM   #2
TheMuffinMan OP
Oddometer: 6,371
As I mentioned in the 690 Wunderfest what I need now is content to add to the wiki.
More pictures the better. For an idea on what I'm thinking of look at the 950 HOW
http://ktm950.info/how/wotf/wotf.html
http://ktm950.info
Old 12-07-2012, 01:47 PM   #3
TheMuffinMan OP
Oddometer: 6,371
-Reserved-
Old 12-07-2012, 03:31 PM   #4
CordR
Oddometer: 514
Here is Bartron's thread (required reading for all 690 owners) where he goes through pretty much everything listed below:
http://advrider.com/forums/showthread.php?t=666269
Evaporative Canister Removal (DONE)
KTM radiator protector (DONE - write up pending)
Scotts Steering damper (James Renazco is putting out a rally style mount so I'm waiting for that)
Radiator fan fix (DONE)
Fuel line fix (DONE)
Radiator diffuser fix (DONE)
Radiator coolant hose fix
Fan power supply rub fix (DONE)
Rally-Raid side tanks install (DONE)
Rally-Raid 88 degree radiator fan switch install (PENDING)
Countersprocket step-up (Waiting on the ordered 14T CS)
Lynx fairing install (DONE)
Turn signal fix (This is resolved with the new exhaust)
FMF Q4 exhaust replacement (DONE)
Engine protection (G-it) (DONE)
Touratech pannier rack with Rear luggage rack (G-it) (DONE)
Uni USA foam filter (DONE)
Ignition map switch (DONE)
Heated grips (Pending Installation)
Renazco seat (DONE)
Rally-Raid lower and upper bolts (DONE)
G2 Throttle Tamer (Pending installation)
Delrin lower tank bolt bushings (Pending installation)
Painted the bike white (DONE)
Tune ECU modification (DONE)
CordR is offline   Reply With Quote
Old 12-07-2012, 09:45 PM   #5
TheMuffinMan OP
Oddometer: 6,371
Added the canisterectomy process with images hosted from the wiki. I'm going to figure out the references section so I can point back to the advrider post. But that should give people a taste what the end result will look like.
Also, just because a topic has been covered in the wiki doesn't mean another process/pictures/method of doing it isn't needed. The more information on there the better.
Canisterectomy - http://convulsingmuffin.com/690wiki/...tomy_-_Bartron
TheMuffinMan screwed with this post 12-07-2012 at 09:55 PM
Old 12-07-2012, 10:09 PM   #6
TheMuffinMan OP
Oddometer: 6,371
Did we want to use 690rider.com or ktm690.info, the latter is available.
Whenever we get a TLD for the wiki I'll also move it onto my ssd from my spinning disk raid array for faster response times.
Old 12-08-2012, 08:03 AM   #7
TheMuffinMan OP
Oddometer: 6,371
Uploaded USA SMC and Enduro manuals 2008+
Old 12-08-2012, 11:06 PM   #8
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,623
Nice!
Keep up the good work.
Yellow Pig is online now   Reply With Quote
Old 12-08-2012, 11:55 PM   #9
modeselector
Common as muck
modeselector's Avatar
Oddometer: 624
Nice job MuffinMan.
As far as domain - either good is my vote.
modeselector is offline   Reply With Quote
Old 12-09-2012, 12:29 AM   #10
offworlder
Oddometer: 256
My vote would be for ktm690.info, as its not only consistent with the (950) HOW domain, but a more representative/accurate reflection of the content.
690 owners - unite !
I just had the epiphany (that you clearly had some time ago), that 690s and Zappa go well together !
"...Thought he was a man, but he was a muffin...."
offworlder is offline   Reply With Quote
Old 12-09-2012, 01:03 AM   #11
Night Falcon
Adventure NZL
Night Falcon's Avatar
Oddometer: 2,421
Nice job. Couple of minor but common fixes I've done are Air Temp Sensor Fix & tank bolt replacements. I documented them on my 690 adventure thread but the pictures disappeared after photobucket revamped their site. Is that the sort of thing you are looking for? I can repost on here if you think its worth it?
Cheers
NF
My EXC530 Adventure
Night Falcon is offline   Reply With Quote
Old 12-09-2012, 07:45 AM   #12
LethPhaos
brb
LethPhaos's Avatar
Oddometer: 605
some external links that might be of use
http://www.qubar.se/2011/05/ktm-690-...convert-guide/ - for those of us that's like to use enduro wheels on the SMC
http://cyclehuttktm.com/FicheFinderN...on=FICHEFINDER - best online fichefinder I've found, off-course there's also offline pdf's available for those who know where to find them
| KTM 690 SMC RRP | Honda RD04 Africa Twin |
| Balkan ADV RR | Bacon trip log map | KTM 690 Wiki |
LethPhaos is offline   Reply With Quote
Old 12-09-2012, 08:02 AM   #13
modeselector
Common as muck
Oddometer: 624
Cheers
NF
YES if you don't mind, thank you.
Old 12-09-2012, 05:21 PM   #14
TheMuffinMan OP
Oddometer: 6,371
Added some stuff to the HOW as well as a few more of Bartron's posts (and got his permission to use his posts, thanks! )
Old 12-09-2012, 08:11 PM   #15
StepOnIt
Assitoner
StepOnIt's Avatar
Oddometer: 1,037
Thumb sweet
thanks
The road less traveled is the road I travel more.
"I feel sorry for people who don't drink. When they wake up in the morning, that's as good as they're going to feel all day." Dean Martin
StepOnIt is offline   Reply With Quote
Times are GMT -7.   It's 10:29 AM.
