Old 11-20-2012, 04:15 PM   #211
crash279
DFW Supermoto Crew
crash279's Avatar
Oddometer: 43
Originally Posted by B1 View Post
WR450F TIPS MODS & REVIEWS
with the power they put out they can't be as bulletproof as a tractor like the DRZ, but generally they go a lot longer than comparable high performance bikes in terms of rebuilds, valve adjustments etc. personally i preferred the steel frame models (pre 2007) as they were barely any heavier and it was much easier accessing the carby and engine without that bulky alloy frame...
I have seen a lot more drz failures then WR. I'm with you on the steel frame though. Maintenance was waaaaay easier.
Sent from my DROID RAZR using Tapatalk 2
crash279 is offline   Reply With Quote
Old 11-23-2012, 10:50 PM   #212
n16ht5
ride the night
n16ht5's Avatar
Oddometer: 2,367
YZ timing! Retarded my WR exhaust cam one tooth for more power. Have to mill down the decompression pin to keep your estart though!
This is a FREE mod. You need to have an aftermarket or YZ exhaust to get the extra power though, it improves exhaust scavenging by opening the exhaust valves at a different time.
I noticed extra snap throughout the powerband.
pics:
-starting...
valves have moved... probably not a great thing, but the bike has 150+ hard hours and this is the first time they needed to be adjusted
exhaust cam decomp pin
pin out it measures .940
dremeled down .040 or 1mm.. then rounded and sanded smooth with a few grades of sandpaper to a shine. Now put it back in, only 1 tooth retarded (make sure you use a white pen to line up everything!!!)
back together, greasing bolts (swingarm bolt) if you haven't ever greased yours, do it. there are pics on the xr400 section of a guy who resorted to cutting off his entire swingarm from a frozen bolt.
n16ht5 screwed with this post 11-23-2012 at 11:53 PM
n16ht5 is offline   Reply With Quote
Old 11-23-2012, 11:02 PM   #213
nrspence
nrspence's Avatar
Oddometer: 91
Excellent post and pics. The swing arm bolt is often neglected.
Watch your topknot
Watch your top knot.
nrspence is offline   Reply With Quote
Old 11-23-2012, 11:48 PM   #214
n16ht5
ride the night
n16ht5's Avatar
Oddometer: 2,367
Keyed ignition!
this: $15 off ebay
http://www.ebay.com/itm/Key-IGNITION...083dba&vxp=mtr
It has 4 wires.. green and black w/ white strip are not used.
The other two are used with the brown and solid pink wire.
Zip tied to the speedo box mount. nice and snug
switched on
I converted the whole bike to DC... so I added a relay to turn all the accessories and lights on (or enable them to be on) when the ignition switch is turned on
This is a mini relay. I discovered a handful of them at a junk yard in a ford car. I think I got half a dozen for a dollar. Also in that mess of wire is a phone/gps charger adaptor hardwired in to power my android GPS running MyTrails.
key turned on.. headlight comes on, tail light.. power for acc comes on... the big black and red on/off on the right is power for my heated grips.
my LHRB/Rekluse setup
Old 11-26-2012, 08:17 AM   #215
GlennR
Playin' in the Fire
GlennR's Avatar
Oddometer: 2,109
n16ht5,
Would you explain a little about the DC conversion? What is the AC originally for and why don't you need it? What gain do you get over the stock DC?
(Talk slow, I'm not real smart about electricty...)
GlennR is offline   Reply With Quote
Old 11-26-2012, 10:20 AM   #216
yukonjon
yukonjon's Avatar
Oddometer: 140
Originally Posted by ADVbuba View Post
Which light is best for headlight? Philips or...???
Was also curious what you guys are using? Seems like my normal bulbs keep burning out on the bumpy trails. I also have the hi and low switch on my bike so looking for something heavy duty with good light output. Thanks in advance.
yukonjon is offline   Reply With Quote
Old 12-07-2012, 05:05 PM   #217
nrspence
nrspence's Avatar
Oddometer: 91
Damn this thread is dead.
Love me some motorbike riding!
Old 12-07-2012, 06:04 PM   #218
Nice_Rumble
Nice_Rumble's Avatar
Oddometer: 2,247
Originally Posted by mxbundy View Post
BAM!!!!
Tell me who makes the DS kit you used? The seat, which brand is it?
Noise annoys, ride stealth
Member: CCCOFVT, MVTR, NETRA
2013 KTM 500EXC
Nice_Rumble is offline   Reply With Quote
Old 12-07-2012, 06:32 PM   #219
yukonjon
yukonjon's Avatar
Oddometer: 140
The seat is made by seat concepts. The poster of that bike is the guy you need to talk to if you want to buy one (mxbundy). I love the seat I got from him. Check him out in the vendors section. Believe it's free shipping for forum members too.
Old 12-07-2012, 06:43 PM   #220
johnson357
Bad Monkey Racing
johnson357's Avatar
Oddometer: 1,283
I have a Guts seat foam and cover that I like.....will post some pics after I get it set up for the Mex1K Rally
johnson357 is offline   Reply With Quote
Old 12-07-2012, 06:50 PM   #221
Nice_Rumble
Oddometer: 2,247
Anyone use the Yamalink lowering link? Lowers the rear 1.6"
http://www.motorcycleloweringlinks.c...-lowering-link
What kind of milage could one expect from the IMS 3.0 gallon tank?
http://www.imsproducts.com/Products/...eSet=3.0%20gal
2013 KTM 500EXC
Old 12-07-2012, 07:26 PM   #222
yukonjon
yukonjon's Avatar
Oddometer: 140
I'm also interested in the link since my wife just bought a wr250. Little tall for her.
As for the tank, I'm generally getting 45 miles a gallon on the road so 130 miles a tank maybe. As for off road it varies a lot but I have done over 100 miles of rough trails on my stock tank which is 2.7 I believe. Ill have to double check.
Old 12-07-2012, 09:05 PM   #223
wilkinsonk
soup de grimace
Oddometer: 847
I get a little over 100 miles in the sand dunes with my Acerbis 3.1 and that's with a lot of heavy throttle application. I usually end up transfering gas to my friends on their MX bikes on the way back to the trucks.
- Ken
wilkinsonk is offline   Reply With Quote
Old 12-08-2012, 12:32 AM   #224
B1
Carbon-based bipedal
B1's Avatar
Oddometer: 3,343
a mate of mine is looking at a dirt bike that will occasionally have to double as a pint sized adventure bike. he's looking at the CRF450 but i'm convinced he'd be better off with the WR450F as it should go a lot longer between engine rebuilds. i know my old 2006 WR450F had clocked up about 7000km of dirt and adventure riding with no engine work needed at all.
anyone got rough mileage estimates before you've had to do cam chains, top end or bottom end work?
free enduro training vids for gumbies here
B1 is online now   Reply With Quote
Old 12-08-2012, 08:06 AM   #225
Nice_Rumble
Oddometer: 2,247
I'm considering a 2012 WR450F but am concerned about some of the negatives the press is throwing at it.
From motorcycleusa.com http://www.motorcycle-usa.com/276/13...-Shootout.aspx
"Power output isn’t the issue for our testers, but controlling the engine does cause some concern. First of all, as Martin alluded to, getting the dang thing to start with its button takes an act of Congress. We put it to the test constantly during our photo shoots and not one of us could find a secret to getting it lit. Kicking works pretty well, but who wants to do that? Also, the drivetrain received poor marks, worst in the test, primarily because of its YZ450F-derived clutch. It takes Herculean strength to engage and it fades at the mere thought of fanning."
“Noise from the resonator on the head pipe was louder than the exhaust.” He wasn’t the only one to comment on the noise. It was the loudest in the stationary sound test with 93 dB, but our riders were more concerned with the ruckus coming from the engine/intake/header. We couldn’t pinpoint the noise, but it’s definitely the raspiest and most obnoxious."
"The Yamaha is a big boy. The WR might have gotten a rolling chassis from the YZ250F, but not a single one of our testers ever described it as particularly 250-ish. It feels fairly narrow and the seat height is listed at 37.8 inches, which is lower than the Honda and KTM, but our testers all felt it is the tallest and struggled to get their toes on the ground (sans our 6’4” beanstalk). It’s also the heaviest bike in this test at 274 pounds and it doesn’t make excuses for its girth."
http://www.motorcycle-usa.com/13/139...out-Video.aspx
Are any of these issues founded?
2013 KTM 500EXC
Nice_Rumble screwed with this post 12-08-2012 at 08:21 AM
Times are GMT -7.   It's 04:02 PM.
