Old 12-07-2012, 03:28 PM   #6451
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,005
Originally Posted by TheMuffinMan View Post
What I need now is content.
Links to posts that have valuable content about mods, explanations of procedures, maintenance, known issues, etc. I'll polish the wiki categories and layout a bit this weekend and will start adding content as we find it.
For now I've created a new thread so we don't spam this one with links to posts/data to be added to the wiki.
Wiki Thread
Oh, does anyone have a Logo we can use that isn't copyrighted or something? I'm also go to see if I can get some sort of skin for the wiki pages.
My wife offered to make a logo, do you want Her to do it? I've never gotten a response from you, so just making sure I'm not on your ignore list.
Just say'IN
crankshaft is offline   Reply With Quote
Old 12-07-2012, 04:16 PM   #6452
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,692
Originally Posted by tattewell View Post
Gave up on this POS. Bought an Africa Twin, and as soon as I get back to Canada in July, mine's for sale.
Excellent attempt KTM, but you shit the bed on waaaaaay too many issues to attempt to fix. Still love my 450 EXC.
Good? How does this help the thread? What useful information did you share?
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
Old 12-07-2012, 05:14 PM   #6453
TheMuffinMan
Forest Ranger Magnet
TheMuffinMan's Avatar
Oddometer: 6,241
Oh, sure! I was preoccupied with finals I guess I didn't see/respond to your post. Whoops!
"To strive, to seek, to find, and not to yield."
"You don't cross the mountains, they let you through."
KTM 525 XC-W // KTM 950 Adventure
TheMuffinMan is online now   Reply With Quote
Old 12-07-2012, 05:46 PM   #6454
Assfault
Exposed Member
Assfault's Avatar
Oddometer: 2,318
Originally Posted by LOZ View Post
its all happening at your place!!!!
Are you saying these are ready now?
Don't see them on their website yet.
* Assfault, Ass-Fault, Ms Ass, thier neighbors or friends, are not responsible for any incidents, accidents, or accusations, that might result from you using this forum in the pursuit of adventure greatness. Avoid taking ADV before bed time. Do not use if you experince faintness, dizzniess, inversness, difficulty urinating or an erection lasting longer than 4 hours. Thank you*
Assfault is online now   Reply With Quote
Old 12-07-2012, 07:44 PM   #6455
modeselector
Common as muck
modeselector's Avatar
Oddometer: 624
Sounds like next couple weeks, just before Christmas.
modeselector is offline   Reply With Quote
Old 12-07-2012, 07:51 PM   #6456
numbutt
john
numbutt's Avatar
Oddometer: 103
Originally Posted by DirtJack View Post
Most of us have used 2.2K ohm 1/4 watt resistor when disabling most any sensor/control. Seems to work well.
Thanks for the support !!.... Its much quicker to fit a resistor than wait for a plug-in cheat to arrive in the post and at about 1 to 2 cents for the resistor is just a tad cheaper too. There is an additional advantage that one is eliminating the plug which can be another possible future failure point..... say no morre says Monty Python.
numbutt is offline   Reply With Quote
Old 12-07-2012, 08:14 PM   #6457
Gros Buck
Beef = Packed Vegetables
Gros Buck's Avatar
Oddometer: 848
Originally Posted by Seth S View Post
Call me lazy but I just bought a pre-made side stand switch and plugged it in.
I'm even more lazy ... I bought it, and I never installed it ...
Paul Jr 8
KTM690r 2011
Gros Buck is offline   Reply With Quote
Old 12-07-2012, 09:17 PM   #6458
gbx2001
Geophiz
gbx2001's Avatar
Oddometer: 101
Originally Posted by numbutt View Post
Ho-hum it must be winter in USA/north..threads are becoming mundane..!!.... thought id follow some others in disabling the sidestand switch...( in a slow quest to reduce ? the ocasional flame-out when racing to a stop )
Another inmate suggested a 1K to 3K resistor to repace the hall switch putting this resisror between the pink and black wires [ there are 3 wires going to the switch pink, black and blue ].
I did a few tests to ceate some understanding and what we have is a blue wire that supplies a regulated 5 Volts from the ECU to power the switch [ the switch is a Hall device [ linear response to a magnet ] coupled internally to a Schimdt trigger level detector that provide a snap action . [ hope im not boring anyone ]. Anyway, at ignition switch on, 5V is sent to blue and without the Hall connected the pink wire also reads 5 Volts. With the Hall switch in place and activated [ stand up ] the pink wire is locked down to 2.50Volts. Black is the earth wire or at earth potential [ 0 ].. I did a few tests to establish the ( voltage ) effect of adding the first mentioned resistor ''cheat '' to ''pull down '' the pink wire to about 2.5 Volts .
3.3K gives 3.02 volts
2.7K gives 2.78 Volts
2.2K gives 2.52 Volts [ test resistors between black and pink ]
1.8K gives 2.27 volts
1.5K gives 2.06 Volts
1.0K gives 1.6 Volts
After all this bull we must conclude that probably the best resistor to use is 2.2k { 2200 ohms } ...a standard value and i used a 1 watt metal oxide type [ most stable ] [ fortunately i carry many of every resistor 1 ohm ...1 Meg ohm at home so its an easy test !! ]
So after all that #&*@# , simply cut wires to stand above connector near shock, solder in 2.2 K ohms between Pink and Black, heat shrink it, then isolate and heat shrink off the blue so it cant short....and Bobs your uncle ....
Thanks for your writeup - very thorough and informative - I enjoy learning from posts like this.
gbx2001 is offline   Reply With Quote
Old 12-07-2012, 09:20 PM   #6459
gbx2001
Geophiz
gbx2001's Avatar
Oddometer: 101
Gorgeous bike - this is the 690 Adventure that KTM should have built.
Old 12-07-2012, 09:41 PM   #6460
crankshaft OP
crankshaft's Avatar
Oddometer: 14,005
Originally Posted by RoninMoto View Post
You are probably right. My tires never leave the pavement. I should have got a SM
Riding in the dirt is scary, I prefer pavement
Just say'IN
Old 12-07-2012, 10:06 PM   #6461
TheMuffinMan
Oddometer: 6,241
Did we want to use 690rider.com for the wiki? I checked and ktm690.info is available.
Old 12-08-2012, 05:55 AM   #6462
crankshaft OP
crankshaft's Avatar
Oddometer: 14,005
I'm offering .com for free but let everyone choose
Just say'IN
Old 12-08-2012, 02:22 PM   #6463
mickd
crash test dummie
mickd's Avatar
Oddometer: 1,918
HI ALL
well i had my first PITA on the 690 today,having a nice easy ride in mt mee,the 690 stalled with a loud "POP" and a PSHHHHHHH, the sound came from under the air box area,so i had a good look around only to find the rubber boot had came away (see pic) and also the airbox was pushed back towards the battery
bike is a 2012,with less than 2000ks with a akro slip on inc akro mapping.
1, so what would make this happen,
2, is there a fix for this,cos i dont want it to happen again (PITA)
3, has there been a recall for this
Photobucket
You suck. And your mother dresses you funny.
I've just been to my first muslim birthday party. Musical chairs was a bit slow but F**k me, pass the parcel was bloody quick.
mickd is offline   Reply With Quote
Old 12-08-2012, 04:51 PM   #6464
gbx2001
Geophiz
gbx2001's Avatar
Oddometer: 101
Rubber boot popping off
Originally Posted by mickd View Post
HI ALL
Photobucket
You are not alone with this issue - Rally-Raid found this issue on a couple of 690Rs they were preparing for RTW travel and said they reported it to KTM. It sounded like some of the boots were "shorter" than specced Sorry I don't know if there is a factory TB on this issue. I will look around and see if I can find the RR article on this.
Old 12-08-2012, 10:09 PM   #6465
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,594
So, with the added fuel capacity and associated weight, what springs are a good starting point to manage the new weight of the bike?
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Times are GMT -7.   It's 10:53 AM.
