Old 12-08-2012, 08:51 AM   #1
Sutherngintelmen OP
on the mend
Sutherngintelmen's Avatar
Oddometer: 977
Steering Towards Stupid - Stop Me! R80gspd
Last time I had the bike in the mountains I noticed the steering resistance began to increase. No longer does the wheel fall gently to the right - definitely needs an adjustment.
Repair manual documents this as straightforward as one would expect. If that is, you can loosen the cap nut. I've put as much torque on this as I feel safe doing. My set up is a crescent wrench with custom tube breaker bar borrowed from shop tire swapper rig. I was eyeing the sledge over in the corner of the shop but stopped myself.
The nut measured 35.4mm on my calipers, am thinking I need to go buy a big 6 side socket, pull the handle bars off, strap the bike to the floor and pull like a mofo. Any free advice?
There is a pleasure in the pathed woods, There is a rapture in the smoking pipe, There is chaos, where none intrudes, in the deep dell, with its thrills roar; I love not nature less, but bikes the more. Byron riding.
All posted pics < 6/30/12 deleted courtesy of Apple
Sutherngintelmen is offline   Reply With Quote
Old 12-08-2012, 08:54 AM   #2
DiabloADV
Semi-Occasional
Oddometer: 1,534
Torch.
Remove GPS first!
'74/'70 R98/6/GS Traveling Bike (construction under way)
'91 Bill Holland Steel w/Dura Ace
DiabloADV is offline   Reply With Quote
Old 12-08-2012, 08:58 AM   #3
Airhead Wrangler
More tacos than you
Airhead Wrangler's Avatar
Oddometer: 5,114
Heat indeed. Get a little piece of sheet metal of easily bendable gauge to mask off what you don't want to torch. A few layers of aluminum foil works nicely too.
R80ST Gets The HPN Treatment
Ducati Pantah 500SL Rebuild
Seattle to TDF on an airhead
WTB R100R Mystic sidestand and mount.
Old 12-08-2012, 08:59 AM   #4
Bigger Al
Still a stupid tire guy
Bigger Al's Avatar
Oddometer: 7,270
Impact gun, 36MM socket. Heating with a heat gun first couldn't hurt.
"Nearly all men can stand adversity, but if you want to test a man's character, give him power." -
Abraham Lincoln
Bigger Al is offline   Reply With Quote
Old 12-08-2012, 09:10 AM   #5
JRP
Old guy
JRP's Avatar
Oddometer: 1,362
Kroil...loosens most anything
http://www.kanolabs.com/google/
"What could possibly go wrong? " The Jerk
2012 TE 250
2010 F 650 GS
1983 R 80 G/S
JRP is online now   Reply With Quote
Old 12-08-2012, 09:18 AM   #6
Sutherngintelmen OP
on the mend
Oddometer: 977
Heat! Of course - brilliant. I'll start there since it's got the most attractive price tag.
Many thanks - as always.
Old 12-08-2012, 09:54 AM   #7
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 2,862
I bought that 36mm socket recently,it has quite a few other BMW applications. Less than $15.00. Just looked for an online price for you and what do you know, it is available free at Autozone under their "Loan a Tool" program.
Have tools, will travel!
Old 12-08-2012, 10:11 AM   #8
craydds
craydds's Avatar
Oddometer: 993
+ 1. You NEED more tools. You WANT more tools.
Ray
ABC #12947
'75 R90S
craydds is offline   Reply With Quote
Old 12-08-2012, 10:28 AM   #9
craydds
craydds's Avatar
Oddometer: 993
Originally Posted by Bigger Al View Post
Impact gun
+ + 1. MUST have more tools. A very good reason to have the 36 mm socket is that you will want to torque the cap nut to specs with a torque wrench. Now you get to buy a torque wrench! yippee!
Ray
ABC #12947
'75 R90S
Old 12-08-2012, 10:46 AM   #10
oldroadie
/5 dirt road wannabe
Oddometer: 342
I'd take off the handlebars and clamp a pipe in there for something solid to hold on to so you don't tweak the forks against the stops. An air wrench would be very nice too, mine was around $40 at Lowes.
oldroadie is offline   Reply With Quote
Old 12-08-2012, 10:46 AM   #11
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 6,917
Send a message via AIM to crazydrummerdude
That worries me. I can just picture a stripped nut.
Get the socket!
crazydrummerdude is offline   Reply With Quote
Old 12-08-2012, 11:43 AM   #12
Big Bamboo
Big Bamboo's Avatar
Oddometer: 823
Originally Posted by oldroadie View Post
i'd take off the handlebars and clamp a pipe in there for something solid to hold on to so you don't tweak the forks against the stops. An air wrench would be very nice too, mine was around $40 at lowes.
+1 Also, if you grind the business end of that 36mm socket flat, it will be much less likely to slip off and mar something else in the process.
"No hour of life is wasted that is spent in the saddle." =Winston Churchill=
Big Bamboo is online now   Reply With Quote
Old 12-08-2012, 11:48 AM   #13
_cy_
Oddometer: 2,536
Kroil is excellent/pricey... mixture of 50/50% acetone/ATF is better and dirt cheap.
soak with above 50/50% mixture overheat before doing anything else. then try impact on 36mm socket before going to heat method.
impact action breaks free frozen nuts with less chance of breaking. save heat as a last resort.
you may be pleasantly surprised next morning after soaking with 50/50% acetone/ATF overnight.
_cy_ screwed with this post 12-08-2012 at 11:54 AM
Old 12-08-2012, 11:59 AM   #14
Sutherngintelmen OP
on the mend
Oddometer: 977
Got it too hot to touch and came off with no drama. Fear not, I have ordered a 36mm socket, brown santa should deliver it Tuesday. I love more tools! This city, this time of year, Saturday shopping shall be avoided at all costs
I did end up removing the bars as it made working the cap nut simpler. Trade off was discovering some buggered threads on the stud of my left clamp. I didn't have the 'BMW special wrench 31 4 850' lying around to loosen the slotted nut so opted for a drift and some gentle (I promise) blows. I have a feeling many of you would cringe watching me wrench.
End result is reasonable for now, I've got plans to drop the forks in Jan/Feb as the boots need replacing. Will do a bearing inspection and grease or replace at that time.
Warming her up
More like it
Old 12-08-2012, 12:50 PM   #15
Paul_Rochdale
Paul_Rochdale's Avatar
Oddometer: 142
"A very good reason to have the 36 mm socket is that you will want to torque the cap nut to specs with a torque wrench".
I know you Merrycans love your torque wrenches, in fact I have one just for the engine/gearbox internals, but I would tighten that nut up by feel. I've always done that with my bikes and never had a problem. Just check it as the bearings may settle down and tweak it a bit more if necessary. BTW torque wrenches should not be used for UNDOING nuts but for TIGHTENING them up. That's why we have tommy bars.
Let me tell you a story. About twenty years ago I was a student on a Police Motorcycle Course and the bike I was given to ride suffered from wheel wobble. I reported this at the time but was told to 'take it or leave it'. Our bikes were BMW R80s. Next day we were in a group, on the motorway, running at 100mph. Yes, we were allowed to do so. I was the lead rider and came upon a couple of artics which I began to overtake. I knew the front would start to shake as I got to the wash from the front of the drivers cab, only this time it was more severe than before. The front began to wobble and nothing I did would stop them. The handlebars crashed from lock to lock and I was flung off the bike and tumbled down the motorway. When I came to a halt, the two artic drivers had also stopped, and I was helped up and walked to the hard shoulder.
So what is this leading up to? Well the bike was examined by the Police Accident Investigateor and found to ey unroadworthy. The bearings in the headstock were found to be dry and RUSTY, and either too tight or too loose (I can't remember which). Officials from BMW HQ visited the workshop and also examined the bike and surprisingly to everyone claimed there was no specific torque setting for the headstock. We all found this difficult to believe. Other than extensive gravel rash - full leathers were introduced to all Police riders within weeks - I got away with it. So for me, headstocks are adjusted by feel.
Paul_Rochdale is offline   Reply With Quote
Times are GMT -7.   It's 12:00 AM.
