12-08-2012, 11:15 AM
#46 |
I have little to say
12-08-2012, 12:11 PM
#47 |
Ride Far - Ride Fast
Oddometer: 4,759
Gee it's nice to be called sonny at a tender age of 61
I've been afflicted with the memory loss ever since the mid 60's
Beemers Past and Present: 74 R90S, 77 R100RS, 85 K100RS, 2x 87 K100RS, 96 R1100GS, 99 R1100S, 2002 R1150GS, 2005 F650 Dakar Plus the occasional Triumph, BSA, Yamaha, Honda, Suzuki and KTM but who's counting
12-08-2012, 12:37 PM
#48 | |
A proud pragmatist.
Oddometer: 2,862
Was looking at a clutch pack for a K on fleabay not long ago. Cheap and looked good but for the springs all blue at the tips. ![]() I could mock up mine back together on the airhead but not much time today for that. But don't you think that removing material from the plates when resurfacing without compensating for it with the thickness of the friction disk could also contribute to that from their design?
Have tools, will travel!
12-08-2012, 01:04 PM
#49 |
12-08-2012, 01:57 PM
#50 |
Oddometer: 4,759
I'll measure the thickness of mine and post it.
I'm not sure how much they removed but I did ask and they said they calculate it all when doing the friction material. They've been doing clutches since 1930 so you'd think they have it pretty well figured out. http://www.ottawaclutch.com/ "We specialize in the remanufacturing of all Industrial and Automotive clutches, custom applications, Racing Clutches, Cranes and Overhead Cranes, Forklifts and Tow Motors, Mines, Mills and Quarries, Buses, Transit, Passengers Coach and School Buses, On and Off Road Heavy Equipment Winches, Draglines and Logging applications Farm Equipment and Agriculture application Truck and Trailer shoes and brake block sets Commercial laundry applications, shoes, bands and pads Automotive and Light truck shoes and pads Punch Press and Brake Press bands, shoes and clutches Construction Equipment applications Steel uncoiler friction rings Gear tooth facings and segments for the rebuilders Heavy duty woven lining for Marine applications Motorcycle shoes and pads Friction Rings and Specialty Brake Pads Landscape applications Golf Course applications and golf cart shoes/pads Antique and Classic Automobile shoes and pads Printing Industries applications"
12-09-2012, 06:54 AM
#51 | |
Oddometer: 4,759
Wonder if that is close to yours. Just read that RBRacing recommends using an 1150 spring instead of an 1100 as it's 2.00mm instead of the 1100's 1.75mm bottom of the page http://www.rbracing-rsr.com/bmw_clutches.html
12-09-2012, 10:16 AM
#52 | |
A proud pragmatist.
Oddometer: 2,862
Well maybe for some tips but DON'T try to buy parts from them,they may not even exist yet.![]() That one I have here is 15.6 so no comparisons there. But add them lost millimiters from parts wear...cable stretch etc...etc...may all add up to more than the adjustments can take. My old GS I could even see the actuating arm bend when applying the clutch, had to reinforce that. ![]() Got to wonder now if I could put it on the larger scale I just bought and see what it takes to compress it.May overload the 300lbs scale. I'd replace that spring anyway,"off-level" is not that good that would introduce clutch chattering and uneven wear in the long term. Had to go back in my old GS just for that reason so now won't take any chances, clutch work= new spring. Got to be a reason why that lining got cooked to that point and that would create lots of heat, more than enough to weaken them springs.Doesn't take all that much heat to remove temper on spring steel, off the top of my head 650F is MAX for most of them. Interested in that anyway,reminds me of my youth dropping clutches & brakes at Asbestonos(?) in Quebec City and the smell in that shop. My K will probably need clutch work at 100,000 miles if I judge from my measurements at 20,000. I know that some have had theirs relined with success on the Ks, short term as "it works" but I haven't seen any long term reports.
12-09-2012, 10:27 AM
#53 |
Pepperfool
Oddometer: 2,568
If slack is needed to take up, the 1150 pushrod is 12mm longer and can be machined down to fit.
Old enough to know better.... Young enough to try it again |
12-09-2012, 12:47 PM
#54 | |
Oddometer: 21,551
A couple weeks ago, I called their tech support line with a question about whether the Street 360 or ceramic 4 paw clutch disc would be better for my riding style. I didn't even get to finish before the person on the other end interrupted and told me all the BMW clutches were still in development. I thanked her for her time and hung up. |
12-09-2012, 01:21 PM
#55 |
A proud pragmatist.
Oddometer: 2,862
RBRacing....haven't checked on them for 3 years or so but back then the parts were "under development".They'll develop them with customer's money it looks like.
If you go on their website there used to be some pretty funny comments from them about some of their customers. Enough to keep me away from them that's for sure.![]() I just had another tought....did you lift the part number from mainly the spring but the other parts also? Should be stamped on most of them, BMW is good for that. Then punch that into the MaxBMW parts finder to see what it fits. Older machines, never know who could have gone in there and done some hacking/mismatching. ![]() I know for a fact that clutch parts mismatch is a big NO NO for some of the Ks. BMW switched suppliers at some point in the 90s. There are bulletins on that but I don't know if there are any for the R-GSs. If you feel inclined to dig through that , and there are a lot of bulletins to dig through, I'll send you a link as to where to look. I won't post it here but as a courtesy to a fellow Canadian....no problems.
12-09-2012, 01:47 PM
#56 |
A proud pragmatist.
Oddometer: 2,862
Do I have a spring test for you.... Takes 200 Lbs to flatten that spring. That means I can't do that just standing on it, I tried. Gotta eat more.....![]() Now why did I buy that scale...... ![]()
12-10-2012, 09:05 PM
#57 |
Oddometer: 4,759
I wasn't quite as scientific but the 'heel on the spring on the scale' number got me about 135 pounds to flatten it. A lot different than 200# .... but I still don't think that's the non contact issue.
12-11-2012, 11:29 AM
#58 |
A proud pragmatist.
Oddometer: 2,862
Need more pics of your parts. Engagement hole in the spring? them could wear out according to my manual.
And the clutch lever behind the transmission? those do bend. Someone may just have taken up all the adjustments to keep that bike rolling and then bent it.Clutch sure looked....abused. I could see my lever flex by eye, had to reinforce it sticking a piece of alu pipe over it.135....does sound weak. Yes also did the heel dance on mine, no way I can flatten it. But I am only 170 with the winter gear on. Scientific...... Flunked all that to ride & wrench way back then. The near new "medical" scale from the Salvation Army. $3.99....I am cheap.
12-11-2012, 12:21 PM
#59 |
Oddometer: 4,759
I thought you'd like that 'scientific'
I could compress it easliy with my heel but I'm 225 I pulled the throwout bearing yesterday and checked the clutch arm and everything looks fine. That spring must be really compressed. I'm going to get a new spring and start fresh and see how that goes. Should I replace the throwout bearing too .. feels fine but I've read a couple of threads wehere the guys did a new clutch and 100 miles later that bearing is gone. I'm not thinking long term right now as I'm not sure if I'll keep the bike after I get it running. I may sell it and my Dakar for a 800GS or keep the both of them and ride one on the Alcan 5000 I'm registered for in 2014
12-11-2012, 12:38 PM
#60 |
Memory loss in the clutch spring not in yer noggin'...are you daft boy or have you forgotten we were talkin' about your clutch...Hmmmm, that fella is loosin' it.
