12-07-2012, 09:49 PM
#71836 |
Oddometer: 740
Yea... Literally just broke off. It was the strangest thing, I wasn't even touching it, it just fell. I think the previous owner might have glued it. It seems to have some residue on it.
2000 Suzuki DR650 - 790cc Big bore kit, V-Strom seat, Warp 9 Supermoto rims, TM-40 carb. 1985 Yamaha CA50 - My Hot Rod 2009 Piaggio BV-250 - Escusi, Babba be bo-bee |
12-07-2012, 10:07 PM
#71837 |
Oddometer: 589
So my bike is an hour away and I am trying to buy some clear hose on amazon that will fit on the bleeder valve but I don't know what diameter hose will fit on the caliper... Does no one know or can measure?
12-08-2012, 04:31 AM
#71838 | |
KJ4WMZ
I use one of these: http://www.amazon.com/Motion-Pro-08-...=brake+bleeder
Sent via morse code ..-. -.-- ..-. ..-. mrprez screwed with this post 12-08-2012 at 04:46 AM |
12-08-2012, 07:16 AM
#71839 |
Oddometer: 740
Cool thank you.
12-08-2012, 10:17 AM
#71840 | |
Oddometer: 589
12-08-2012, 11:02 AM
#71841 |
Oddometer: 8
Clutch basket nut
So I stupidly thought I could do the NSU screws without mishap, but of course I was wrong. I am in the process of putting things back together, and realize that I don't know how tight the bolt that holds the basket on should be. Should there be any freeplay when pushing the basket back and forth on the shaft? If so how much? Thanks.
12-08-2012, 11:42 AM
#71842 |
Oddometer: 837
Clutch basket nut at 36 ft/lbs.Not the bolts for the clutch springs.
97dr650 bad ass FCR-MX pumper ,plus other goodies
12-08-2012, 11:55 AM
#71843 |
Oddometer: 8
Clutch basket nut
Long before I get to 36# the plate holder will no longer free wheel. Maybe I am doing something else wrong.
12-08-2012, 12:06 PM
#71844 |
Oddometer: 8
Clutch basket nut
Sorry to have bothered everyone. I went to the parts diagram, then went to the shop, and found the missing washer, now it works fine. The bike is a 2008 with 6000 miles and the NSU screws came loose with only very minimal pressure. Thanks again.
12-08-2012, 03:15 PM
#71845 |
bam-a-lam
Oddometer: 1,842
Broken Header Pipe - Only 6K miles
'09 DR650 just turned 6K miles today and about 20 miles from home exhaust got a little bit louder. About 10 miles got a whole lot louder. Figured it was a crack somewhere on the head pipe as that where the sound was coming from.
Thought about stopping and worried a little about doing engine damage but had no other way to get home so babied it the last 10 miles. WTF! The head pipe is broken clean off at the flange where it bolts up and there is about 1/2" gap 360 degrees, actually looks like someone cut it off with a rough blade hacksaw. Is this a common occurence? Only motor mods are opened up breather box with DT-1 air filter, Pro-Cycle jet kit, and GSXR1000 muffler with Kientech mid-pipe on OEM header. Anyone have a spare oem header or is there a better option.
'12 H-D Road Glide Custom '09 Suzuki DR650 '09 H-D XR1200 |
12-08-2012, 03:26 PM
#71846 | |
Greybeard
Oddometer: 37
suguzzi screwed with this post 12-08-2012 at 03:28 PM Reason: spelling |
12-08-2012, 03:28 PM
#71847 | |
Fallout Rider
Oddometer: 508
12-08-2012, 03:38 PM
#71848 |
bam-a-lam
Oddometer: 1,842
Know nothing about machining. Are those welds "cleaned up" by hand or is it all mechanized?
12-08-2012, 03:40 PM
#71849 |
Oddometer: 740
Finished installing my hayabusa muffler today and went out for a test ride. At 60 I pegged the throttle and the bike bogged down. I assume I need to go one higher on my Main jet? I have a tm-40 from procycle and it came with a bunch of jets. My air box is cut. I went from cut air box and stock muffler to cut box and hayabusa muffler.
12-08-2012, 04:04 PM
#71850 | |
Greybeard
Oddometer: 37
You can grind the stock pipes' weld for somewhat more flow- which I did at first- but I really don't think it is worth the trouble for what you gain and the run the risk of going too far. I would never do it again in retrospect. |
