Go Back   ADVrider > Riding > Regional forums > Central – From Da Nort Woods to the Plane States
Old 12-07-2012, 11:36 AM   #6046
SlipChip OP
Adventure Commuter
SlipChip's Avatar
Oddometer: 3,355
Originally Posted by muddyrabbit View Post
Is it me or does the Tenere in that video look like a TDM with wire wheels?
Yeah but,
In this case looks don't count for much, ST is of course a 750 vs. TDM 850, frame is different, etc. Relatively few interchangable parts.
Chip
`92 Yamaha TDM 850
“Discoveries are often made by not following instructions, by going off the main road, by trying the untried.” - Frank Tyger
"Life begins at the end of your comfort zone." - Neale Donald Walsch
SlipChip is offline   Reply With Quote
Old 12-07-2012, 03:24 PM   #6047
ScienceOfDirt
U-Boat Rider
ScienceOfDirt's Avatar
Oddometer: 1,723
Anyone know where I can get one of these this weekend?
It's the moly bolt assembly that holds the handguards to then end of the handlebar. I tried FormaThread without any luck. I was thinking of heading to Hartville Hardware tomorrow, but it's probably a long shot.
The whole assembly came up missing without a trace when I took my bike off the trailer at home.
Friend: That was some trail shortcut. Me: Yep. See how fast we got lost.
ScienceOfDirt is offline   Reply With Quote
Old 12-07-2012, 04:08 PM   #6048
Jon
Jon's Avatar
Oddometer: 1,261
I can't seem to find my spares in this style but did find the ones that slide for tension on the inside of the bars I could loan you. Similar to these. https://www.google.com/search?q=acer...aMR32KKHJyfaM:
Jon is online now   Reply With Quote
Old 12-07-2012, 05:51 PM   #6049
MeefZah
Curmudgeonly
MeefZah's Avatar
Oddometer: 10,908
A long tapered head bolt, a flanged nut, and a 2" section of appropriately sized fuel hose should do in a pinch. Put the fuel hose over the bolt, install the nut behind it, and begin to tighten until the fuel hose starts to distort and expand. Slide it in the end of the bar, and continue to tighten the bolt; the expanding fuel hose will keep the nut from slipping and will also tighten against the inside of the bar.
Suzuki OEM bar end weights are held on this way. It may not be as structurally intact as the pictured thingy for a barkbuster, but it'll work.
I may actually have a spare or two, let me look when I get home at 10:30.
"A man turns his back on the comforts of home, and when the dust all settles and the story is told, history is made by the side of the road..." - DBT
MeefZah is offline   Reply With Quote
Old 12-07-2012, 05:55 PM   #6050
muddyrabbit
Lost Boy
muddyrabbit's Avatar
Oddometer: 3,844
I have a box of spare/discarded of those parts. Damned if I could tell you where.
muddyrabbit is offline   Reply With Quote
Old 12-07-2012, 07:27 PM   #6051
ScienceOfDirt
U-Boat Rider
Oddometer: 1,723
Thanks for all the ideas/offers. What does everyone think of filling the end of the bar with 5 minute epoxy, shoving a drinking straw into the center, and tapping the straw slightly larger when it hardens? The other plan is to steal the one from the KLR if it turns out to stop raining long enough to ride? I didn't realize this thing would be so hard to find. It looks just like a concrete anchor, or moly bolt to me.
Old 12-07-2012, 07:30 PM   #6052
S2P
S2P's Avatar
Oddometer: 700
I think I have a few of those in my tool box, Let me know and I'll see what I have in the morning.
"In wine there is Wisdom, in beer there is Freedom, in water there is Bacteria"...Benjamin Franklin
WR 426
TTR 125
S2P is offline   Reply With Quote
Old 12-07-2012, 08:09 PM   #6053
rxcrider
rxcrider's Avatar
Oddometer: 1,356
That looks like an Acerbis Rally handguard anchor. If it is, http://www.ebay.com/itm/Acerbis-HAND...f06a1c&vxp=mtr
or you can upgrade: http://www.slavensracing.com/shop/ri...-insert-mounts
I'd offer to take one off my bike for you, but it sounds like you can already do that yourself.
'95+'95+'96 BMW R1100RS/RSL
AMA, OMTA (ohio organization), BRC, BMWMOA
rxcrider is offline   Reply With Quote
Old 12-08-2012, 07:42 AM   #6054
ScienceOfDirt
U-Boat Rider
Oddometer: 1,723
Yes, they're from Acerbis hand guards. Does anyone think I need the ring that came with the anchor? I'm not sure what it is other than a spacer, and none of the replacement anchors I've found online include it. The full kits from Acerbis do, but at $50, I passed.
They have the threaded inserts at FormaThread, though they're not solid like the ones in the link. It looked like the M8 x 1.25mm insert would fit, but they didn't have any installation tools, or the correct tap size.
Old 12-08-2012, 08:35 AM   #6055
Danjal
Insert wit here.
Danjal's Avatar
Oddometer: 2,755
I've got a m18 tap. Could just bolt em right in.
Danjal is offline   Reply With Quote
Old 12-08-2012, 06:08 PM   #6056
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 5,229
Chicken, Ak
-26 deg. F.
For once Ohio doesn't seem so bad.
Michael
AES Racing - Crow Canyon Riding Park
mgorman is offline   Reply With Quote
Old 12-08-2012, 06:35 PM   #6057
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 5,229
Adv Moto and Motorcycle Escape magazines have DR650 hop up info.
Books a Million
Michael
Old 12-08-2012, 07:22 PM   #6058
rxcrider
rxcrider's Avatar
Oddometer: 1,356
I think I have a pair of the rings in question from the acerbic guards. I think they were to keep the twist grip from rubbing on the bark buster. And one for the other side to keep things even. Let me know if you want them
Old 12-09-2012, 12:33 AM   #6059
ScienceOfDirt
U-Boat Rider
Oddometer: 1,723
Thanks, I'll get them from you some time. I still have the ring on the throttle side, so I guess I'm good for now. I'd like to have a spare for when I loose the throttle side.
Old 12-09-2012, 08:09 AM   #6060
Danjal
Insert wit here.
Danjal's Avatar
Oddometer: 2,755
Books a Million
Their search function must suck as much as their mobile site... 0 results.
Times are GMT -7.   It's 01:55 PM.
