Old 12-05-2012, 08:03 PM   #1051
rboett
posser noob 205
rboett's Avatar
Oddometer: 1,615
Originally Posted by dsy View Post
[SIZE=2. Am pleased enough that I ordered the H11 kit today to soup up my GSA stock fog lamps. [/SIZE]http://www.theretrofitsource.com/product_info.php?cPath=32&products_id=3955
Doug
These look nice,, for your stock gsa fogs, what ballasts, color, and bulb config did you order exactly?
That'L do Pig,, That'L do
rboett is offline   Reply With Quote
Old 12-06-2012, 01:55 PM   #1052
dsy
dsy's Avatar
Oddometer: 54
Went with the 35w ballasts and the 4300K bulbs to match the headlights. Will have to drill out the end cap on the rear of the fog lamp coverings to use the straight H11 bulb since the Source does not carry them with the 90 deg base. Should not be a problem. Will know this weekend
Doug
2012 1200GSA
2007 JK Wrangler with diy hemi install
GS GSA Oil Cooler guards http://www.advrider.com/forums/showthread.php?t=860275
dsy is offline   Reply With Quote
Old 12-06-2012, 02:41 PM   #1053
rboett
posser noob 205
rboett's Avatar
Oddometer: 1,615
Doug
great, take some pics of the build process, and let us know the result, pleeeeeeeeze
Old 12-07-2012, 03:54 AM   #1054
TuefelHunden
TuefelHunden's Avatar
Oddometer: 485
Well it's cold enough to test the lights. Now running a CanBus ready 35watt ballast on low beam and a 55watt DDM ballast on high. All is right with the world.
I had a 55w DDM unit and added the CanBus error cable, but when it got down into the 40's it would fail. Usually would light after a few minutes. When down in the 30's it would not just fail, but would not recover until the ambient temp got well into the 50's. The 55w DDM would work every time in high beam at any temp, AND you did not need the error cable. (Yes, I switched the two 55w ballasts and bulbs)
Old, but not Dead
TuefelHunden is online now   Reply With Quote
Old 12-08-2012, 08:20 PM   #1055
dsy
dsy's Avatar
Oddometer: 54
Installed the H11 hids from the Retrofit Source today ( http://www.theretrofitsource.com/pro...oducts_id=3955 ) into the GSA fog lamps. Very easy install and huge increase in light output onto the road.
I thought I would have to drill the end caps out since they did not have a right angled bulb base like the stock H11 but the caps went back on with just a little pressure on the wires. The new hid H11 comes just like the H7 setup for the hid headlight replacement with the wires that feed the bulb and the trigger wires coming thru a rubber grommet.
You dont need the grommet or to have the trigger wires go thru it so just cut it off.
You will use the trigger wires with the plug that you separated from that grommet, to splice into the stock power wire that was feeding the fogs. Cut the stock fog plug off about 3" from the plug and keep it in case you ever want to go back to stock. I went to West Marine and got some nice heat shrink type butt connectors. (the red ones. I think they are for 22 gauge wire) and some 3/8" heat shrink tubing to go over the butt splices to give it a more finished look. On the stock fog lamp power wire the solid brown wire is the neutral on both sides. The other one is the 12v+. You dont need the can bus harness or even the heavy duty relay harness on the fogs. So if you buy from the Retrofit Source you might want to see how much they can knock off the price, for not including either of those.
I'm not going to go into much about where to install the ballast as thats been covered pretty good above with all the options but what I did for mine when I did the head lamps was just split some vinyl hose and put that on the cross bar under the beak to act as a little bit of cushion and zip tied the ballasts across the two tubes. Its very solid.
Head lamp ballast install here. For the fog lamp ballast I'm reusing the slim ballast I got from 1Off. Those are still on the sides behind the plastic panels.
The light from the fog lamps have a nice sharp cut off so its easy to adjust them to not blind the on coming drivers. I did about 10 miles around town tonight and did not get flashed once.
[QUOTE=dsy] I was running the 1off hids, and dont want to offend anyone who thinks those were great but I was never happy with the output of mine from day one. I contacted 1off a few times about the piss poor performance of them, but they kind of just blew me off. (It was close to the time they were folding up).Doug]/QUOTE]
Looks like the problem with the 1Offs I had was because of the bulb I got from them that I used for the low beam. It never got as bright as it should have and since 1Off was folding up they had no reason to want to help make it right. I'm pretty sure that was the problem because I re-used the 1Off slim Ballasts with the new H11 bulbs from the Source for the fog lamps and they get as bright as what I was expecting when I originally did my Hi and lo headlamps. I tried re-using the 1Off slim ballasts due to space. The slim ballast fit better in behind the plastic side panels. Will be using the new ballasts I just got to convert the fogs in my Jeep to HID.
2012 1200GSA
dsy screwed with this post 12-09-2012 at 07:09 AM
Old 12-09-2012, 07:22 AM   #1056
rboett
posser noob 205
rboett's Avatar
Oddometer: 1,615
Installed the H11 hids from the Retrofit Source today.
Thanks for the write up
hope the conversion goes well for your jeep.
I may be doing this for MY GS ADV and MY Jeep (great minds....)
Old 01-29-2013, 07:05 PM   #1057
Steiney
Oddometer: 10
So, after going through 1000+ posts (and quite a few adult beverages ) I think I learned what I needed to know...
I have a 2012 GSA, do about 90% of my riding at night (raining or not), ride into the low 20's, don't want to give up my "instant on" rarely used high beam, and absolutely don't want any fault codes or issues with the cold temps.
I'm leaning toward: Retrofit H7 4300 35K w/canbus for low beam, keep the stock high beam (for flash and as a readily available back-up), and Retrofit H11 4300 35K for stock fogs.
It sounds like these ballasts are the bigger ones - most everything I read had to do with mounting them in older bikes - any updates or are they still a pain in the ass?
The only wiring mods required are the fog light plugs, is this correct?
Any thoughts or comments on this set-up for my particular situation? I don't mind paying a little more for a quality product and the service that comes with it.
As always, you guys rock...!
Steiney is online now   Reply With Quote
Old 01-30-2013, 02:50 AM   #1058
mikegc
mikegc's Avatar
Oddometer: 1,000
HID Conversion on a 12GS (pictorial)
Steiney, I switched out my low beam on the '09 GSA over a year ago (4300K, 35W) and haven't changed a bulb since. I did the auxiliary lamps, too, but didn't care for them because of the "clutter." I switched them out for some PIAA HIDs with self contained ballasts and they were better. Finally, though, I've wired up some LED auxiliary lamps and wired them to flash full power in conjunction with the high beam.
If you decide to use the OEM lamps, the plugs are easy to swap. I had no CANbus issues at all as long as I stayed with 35W.
Mike
IBA 25881
Duty- Honoring a Friend
mikegc is offline   Reply With Quote
Old 01-30-2013, 04:48 PM   #1059
Steiney
Oddometer: 10
Thanks Mike. Yeah, the clutter will be an issue unless I just get a set of Kristas (man they're sweet). Then I only have to deal with the low beam balast which shouldn't be too bad.
Old 01-30-2013, 10:59 PM   #1060
onesaintsfan
BigJohnHart
onesaintsfan's Avatar
Location: McComb MS, where men are men and sheep are nervous
Oddometer: 1,188
High beam
I changed out both the high and low beam to 35w HID on my 08GSA. The High beam throws a totally different pattern than the lows. It appears that the lows make a big U shaped beam ahead of you. The High beam fills this in and projects ahead. But I tell you, if you change out and go to HID, you will rarely use the High beam because the low by itself gives plenty of light. So much so most people think you have high beams on. If you ever get on some dark two lane road late at night you will be glad you went HID in both.
John Hart McComb MS
2009 Triumph Speed Triple "the mistress"
2008 BMW R1200GSA-" the wife"
2005 Chaparral 210ssi " Native Sun II "
" Damn a motorcycle, if somone would buy this thing I would take the bus home "
onesaintsfan is offline   Reply With Quote
Old 01-31-2013, 02:51 AM   #1061
mikegc
mikegc's Avatar
Oddometer: 1,000
Steiney, I made a bracket for the ballasts that fit onto the engine/tank guard using an existing mounting point:
I hope this helps.
Mike
IBA 25881
Old 01-31-2013, 03:58 AM   #1062
TuefelHunden
Oddometer: 485
What he said. If you are running a road where you are switching the high on an off, you don't get the delay every time you switch on. Got a 35 low and 55 high. That 55 is great running dark back roads.
Old, but not Dead
Old 02-17-2013, 01:26 PM   #1063
mercury01
Oddometer: 37
Five years ago I installed HID's in my Ducati Multistrada - 55W, both Hi and Lo. Never had a problem and loved those lights!
Recently I installed HID in my '07 R1200GS. Bought DDM's 55W; 4500K units; one each for Hi and Lo. Installed as per instructions here. Worked like a charm.
mercury01 is offline   Reply With Quote
Old 03-31-2013, 05:36 PM   #1064
RFlagg42
One hoopy frood....
RFlagg42's Avatar
Oddometer: 974
Pardon me if this is a stupid question, but after installing one of these upgrade kits, the HID bulb will eventually fail. At that point, do you have to puchase a new kit? It doesn't look like you can just buy a replacement bulb the way the wires are connected to it.
Eric
2013 LD Rally Season: Big Money Rally (1 Jan - 25 May), Iron Butt Rally (1-12 July)
"As a dog returns to its vomit, so a fool repeats his folly." - Proverbs 26:11
"Even a journey of several thousand miles begins with a single receipt and a witness Form" - Lao-Tzu
RFlagg42 is offline   Reply With Quote
Old 03-31-2013, 07:50 PM   #1065
JimVonBaden OP
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 41,487
Eric
You can buy bulbs on e-bay any time. That said, the ballast is more likely to fail than the bulb.
Jim
JimVonBaden is online now   Reply With Quote
Times are GMT -7.   It's 06:52 AM.
