Thread Tools Search this Thread Rating: Thread Rating: 371 votes, 4.93 average. Display Modes
Old 12-08-2012, 09:07 PM   #6196
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,762
Originally Posted by Emmbeedee View Post
I tried to figure this out tonight but was not able to make a Shortcut directly to the Fuel Services category. Nearest I could get was to create a shortcut which switches to the Automotive Profile, and activates the Where To application. In the Where To app I had changed the order of the icons so that Fuel Services was second in the list order, so I didn't need to scroll.
The Shortcut was made into a Favorite, accessible through the Status Screen/Favorite Dashboard I get with a single Power Button push.
Not perfect, but it works.
The way it was done before v4.60 was to do the following:
Setup, Main Menu, (pick where you want it), ADD ITEM, Where To?, pick the POI category. But, they have changed the category list to the highest level so you can't get to the Fuel Services or Hospital or Food/Drink, etc. This is very disappointing. Time to write an email to the Montana Team and let them know that they didn't FIX anything by changing the level at which we could access Where To? categories for the Main Menu pages.
Cheers,
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK is offline   Reply With Quote
Old 12-08-2012, 09:18 PM   #6197
atlas cached
OX Ambassador
atlas cached's Avatar
Oddometer: 688
Added to the missing features list at the Montana Wiki.
perhaps someone with older firmware can make a bunch of these up and post the XML text - once we know the codes, we could still build them from scratch :)
EDIT:
The missing feature has been removed and rewritten into Feature Request #70.
My apologies for mis-understanding the real issue the first time.
atlas cached screwed with this post 12-09-2012 at 10:51 AM
atlas cached is offline   Reply With Quote
Old 12-09-2012, 04:49 AM   #6198
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,665
Originally Posted by Windrock View Post
Can someone send me the PM with the Dropbox Info please.
The way it works is that you send me a PM with your request, and include your email address for the invite to be sent to.
Emmbeedee screwed with this post 12-09-2012 at 04:54 AM
Emmbeedee is online now   Reply With Quote
Old 12-09-2012, 05:52 AM   #6199
levain
STILL Jim Williams
levain's Avatar
Oddometer: 7,348
Cheers,
That makes more sense, Dan. Once upon a time, this was possible, but no longer! Bummer. Engineering less flexibility into a product is never a good thing!
2015 KTM 690 Enduro R, 2008 Yamaha WR250R, 1971 Lambretta DL
levain is offline   Reply With Quote
Old 12-09-2012, 08:20 AM   #6200
DRTBYK
DRTBYK's Avatar
Oddometer: 5,762
For the REAL GEEKS in this crowd...
Here's a start to the Montana Menu Page decode.
The following screenshot is what the subsequent code is referenced to:
The layout is 3x3 columns. The App position starts in the UpperLeft and flows down then move right and flows down, etc.
The interesting thing (to me anyway) is that the Drawer (if you still have one) is considered the "Main Menu"
Well, that should get you all started. Got to run...
Cheers,
Cheers,
Dan
All Things GPS
Old 12-09-2012, 10:36 AM   #6201
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,665
Very interesting. But I'd be cautious in case something you change causes the Montana to brick itself... Hopefully changes like this would be cleared in a Master Reset, but I don't want to be the one to find that out.
Gotta run, as the saying goes.
Old 12-09-2012, 11:24 AM   #6202
Rocky TFS
Rocky TFS's Avatar
Oddometer: 565
Setup, Main Menu, (pick where you want it), ADD ITEM, Where To?, pick the POI category. But, they have changed the category list to the highest level so you can't get to the Fuel Services or Hospital or Food/Drink, etc. Cheers,
Well DAMN , I knew it was real easy when I did it 6 months ago, and the little magnifying glass differentiates these from shortcuts. I still have the fuel services icon and it works fine,but I haven't done a master reset recently.
I assume it will dissapear as soon as I do.
MONTANA BETA, ARE YOU READING ME? CAN YOU HEAR ME NOW?
Rocky TFS is offline   Reply With Quote
Old 12-09-2012, 11:37 AM   #6203
DRTBYK
DRTBYK's Avatar
Oddometer: 5,762
UPDATE: There isn't an issue. Seems that if you place the App Icon on a Menu Page or in your Favorites Dashboard, you won't see that App offered if you try an place it in the same area (page/dashboard).
Better to send an Feature Request to the Montana Team
Master Reset will not change your Profiles nor should future updates change these "App calls". All of the Montana Apps are defined in the "lookup tables" internal to the Montana code (that's how "lookup tables" work). Just because the Dev Team has changed the list of Apps they show us in this Where To? list does not change the previously defined Apps #'s. Hence, Fuel Services should always be #66 in the "lookup table". IF, they were to completely remove the App (feature) from the Montana then the App# would no longer work (or would call some other App) but that is really a poor way to do business with PND's so I don't think we'll see any of that (I hope not anyway).
Anyway, messing around with what # is called in a Profile really can't do much harm to the Montana. Just make sure you Backup all of your personal data (Profiles, Shortcuts, etc).
Cheers,
Cheers,
Dan
All Things GPS
DRTBYK screwed with this post 12-10-2012 at 02:20 PM
Old 12-09-2012, 11:42 AM   #6204
atlas cached
OX Ambassador
Oddometer: 688
Can you post a screen shot with the fuel services icon, please?
Old 12-09-2012, 11:43 AM   #6205
DRTBYK
DRTBYK's Avatar
Oddometer: 5,762
See post #6217
Cheers,
Cheers,
Dan
All Things GPS
Old 12-09-2012, 11:45 AM   #6206
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,665
Can you post the code for that shortcut to the Dropbox?
Old 12-09-2012, 11:47 AM   #6207
atlas cached
OX Ambassador
Oddometer: 688
See post #6227
Cheers,
Can't.
This post is only #6224, yours was #6222 - But I'll look at it once someone posts it :)
Old 12-09-2012, 11:48 AM   #6208
DRTBYK
DRTBYK's Avatar
Oddometer: 5,762
You mean the Profile. The code is shown in post #6217.
Yes, I will shortly post the Profile.
Cheers,
Cheers,
Dan
All Things GPS
Old 12-09-2012, 11:51 AM   #6209
atlas cached
OX Ambassador
Oddometer: 688
Does your Fuel Services Icon still have the magnifying glass, shortcut arrow, or neither?
Old 12-09-2012, 11:56 AM   #6210
DRTBYK
DRTBYK's Avatar
Oddometer: 5,762
These Icon's are those for the Where To? search apps. They will all have the magnifying glass. They are not "shortcuts" but rather predefined "Search" apps.
Cheers,
Cheers,
Dan
All Things GPS
Times are GMT -7.   It's 05:40 PM.
