12-09-2012, 03:12 PM
#1 |
Oddometer: 107
Arai XD-4 helmet whistling.
Hey everyone
I just brought a arai XD-4 adventure helmet, anyway I get it home take it for a ride and find that any speed over 40 it whistles like a vortex throwing ball thing. Rang arai got some recommendations and he said check for leaks around the visor and just locate the noise. The noise comes from the sun visor/peak of the helmet. I took it back after a week to shop I brought it off and I was told it was normal for a arai helmet to whistle. And she said to get use to it. The thing that annoys me is the fact I brought a $800 dollar helmet that is worse than my old $200 dirt bike helmet. So my question is does anyone else have a arai XD-4 and do they find they whistle? Not just wind noise, but whistle like one of those vortex throwing balls |
12-09-2012, 03:25 PM
#2 |
(KTM quack)
Oddometer: 1,608
MIne doesn't whistle, but apparenlty on some bikes the intake vents on the visor can whistle if left open . If closing them improves the whistle you cold consider using one of the xd 3 or older visors which didn't have the vents?
12-09-2012, 03:34 PM
#3 | |
DRZ'er II
Oddometer: 362
12-09-2012, 03:41 PM
#4 |
Hendo66
Oddometer: 83
No whistling from outside, only from me inside because I am happy :) best helmet yet.
I'm sure you've tried placing your hands up around the visor to try & pin point the area making the noise? I would also try another bike to check its not turbulence related from bike???? After that take it back and request trying another helmet.
Hendo66 2008 BMW F800GS 2011 BMW R1200GS |
12-09-2012, 03:54 PM
#5 |
Oddometer: 187
[QUOTE=Hendo66;20213081]
I would also try another bike to check its not turbulence related from bike???? +/QUOTE] +1 on this, if you have a fairing of some sort, it might be directing air at the peak causing the whistle. You could even just try standing up and get into some clean air.
DRZ 400 E Aprilia Tuono Avanti Blade C 8 |
12-09-2012, 05:33 PM
#6 |
You call that a bullbar?
Oddometer: 111
Had the same problem. For me it was generated at the back of the peak (or tailing edge). I stuck a bit of foam (about 2-3mm thick) on the underside of the peak at the back to disturb the airflow and that has worked. When I get a chance I'll post a pic.
Left or right??? ![]() www.checkingtheboundaryfence.com - The upside, down-under tour of Australia. August to September 2009 |
12-09-2012, 05:35 PM
#7 |
Oddometer: 111
Ps - mIne did it standing, sitting and everything in between so I concluded it wasn't bike related
12-09-2012, 05:41 PM
#8 |
Oddometer: 1,095
Mines heaps quieter than my Old XD3. Is the airflow coming off your bike causing it perhaps?
12-09-2012, 08:53 PM
#9 |
Oddometer: 4,874
I've got one and it doesn't whistle. Like someione else has said, it may depend on air flow over the front of your bike and the direction it hits your helmet from. Mine's a lot quieter then the previous model.
And he sees the vision splendid of the sunlit plains extended, And at night the wondrous glory of the everlasting stars. |
12-09-2012, 09:16 PM
#10 |
Oddometer: 214
Mines not whisling but found if i closed the brow vents in the visor the wind noise is alot less.
Reollc4 ![]() past bikes 04 950 Adventure 03 640 Adventure 99 XR400 electric start 95 DR350se |
12-09-2012, 09:36 PM
#11 |
Oddometer: 318
Mine does not whistle either, but it did when I broke one of the pinlock pins. Now has a piece of tape over the pinlock hole and problem gone.
12-09-2012, 09:46 PM
#12 |
philth
Oddometer: 4,804
why do lady parachutists wear parachute pants?
so they dont whistle on the way down
i must not post hairy buttocks |
12-09-2012, 11:08 PM
#13 |
I did that.
Oddometer: 6,451
What tune is the helmet whistling? This is important, as different tunes signify different things.
For instance, if it's whistling Dixie you need to join the Rebels and get the confederate rockers on your jacket. If it's whistling I Should Be So Lucky, then wear a little skirt and go acting. If it's whistling like a kettle, bring a tea bag......you get the idea.
I'm here all Millenium, 2 shows a day...... |
12-09-2012, 11:22 PM
#14 | |
Oddometer: 187
12-09-2012, 11:29 PM
#15 | |
Sand, Gimme more sand
Oddometer: 1,132
640 Adventure - now gone and in its place a DRZ 400 with 28ltr Safari tank of course! XR 75 Dont criticize someone till you have walked a mile in their shoes, at least then if they get angry they will be a mile away - and barefoot.
