Old 12-09-2012, 06:48 PM   #16
Hondo OP
What if its a Samsquamch?
Hondo's Avatar
Oddometer: 9,805
Originally Posted by Wentjo View Post
Great build! Can't wait to see it finished. Let me know when your ready for a test ride.
If we get a weather break I'll shoot you a PM-
KLRWorld.com Forums - Nighthawk Forums
"Life's an adventure, and I refuse to live a boring one."
Hondo is online now   Reply With Quote
Old 12-09-2012, 06:51 PM   #17
Hondo OP
Hondo's Avatar
Oddometer: 9,805
Originally Posted by marc11 View Post
You are my new hero! Why or why hasn't Kawasaki given us an OEM street legal KLX450?
I wish that I knew. The KLX400 (DRZ-400 rebadged) was close, but really a Suzuki.
Old 12-13-2012, 05:37 PM   #18
busmonkey
Oddometer: 61
Looks good!
Hondo, what was the outcome of the voltage/light issue? Again thanks for the help with the led problem i had.
busmonkey is offline   Reply With Quote
Old 12-13-2012, 06:32 PM   #19
Hondo OP
Hondo's Avatar
Oddometer: 9,805
I sent the stock stator off to Baja Designs for an upgrade/rewind to 100 watts- the stock stator just couldn't keep up.
Old 12-17-2012, 06:01 PM   #20
NMTrailboss
Team Dead End
NMTrailboss's Avatar
Oddometer: 6,449
Very nice build Hondo!
Looking forward to seeing the finished product!
NMTrailboss is offline   Reply With Quote
Old 12-17-2012, 06:37 PM   #21
Hondo OP
Hondo's Avatar
Oddometer: 9,805
Thanks-
Soon I'll be posting up the details of the rest of the bike.
Posted from my Galaxy S3
Old 12-18-2012, 04:28 PM   #22
Wentjo
Wentjo's Avatar
Oddometer: 421
Originally Posted by Hondo View Post
Thanks-
Looking good
Wentjo is offline   Reply With Quote
Old 12-19-2012, 12:35 AM   #23
sidetrack one
Chief Tiddler
sidetrack one's Avatar
Oddometer: 5,918
That is some very nice bike prep you got going on there Hondo, well done!
I live more in 5 minutes on my motorcycle than some people live in a lifetime...............
Where are my pants?
www.buyabale.com.au.. Our farmers thank you!
sidetrack one is offline   Reply With Quote
Old 02-04-2013, 09:18 PM   #24
Hondo OP
Hondo's Avatar
Oddometer: 9,805
Now some more updates....
The forks on the KLX450R are the same ones as the KX450F, and need to have their pressure bled regularly.
The forks have a recessed fork bleeder screw in the fork cap that when unscrewed, will allow the pressure within the forks to equalize with the ambient pressure. A better option is a set of push-to-bleed speed bleeders.
The KLX & KX both need tall bleeders to clear the cap hex nut, so I chose to use some STR Offset Adapters and a set of their Speed Bleeders -
The bleeder screw is at the top of the cap-
Installation is simple- remove the stock bleeder screws, lube the small O rings on the adapters and screw the adapters into the fork. Then screw the bleeders into the adapter.
Here are a few pics of them installed-
Old 03-03-2013, 06:36 AM   #25
TOMMY B
PRODRIVE
TOMMY B's Avatar
Location: Taxes paid Too: Brewster, New York KLX 450R D/S
Oddometer: 153
Nice, KLX 450 R
I like all your upgrades & your Gas Tank looks great too I need to put one on my bike soon.
TOMMY B
RALLY ON /////////////
TOMMY B is offline   Reply With Quote
Old 03-03-2013, 06:42 PM   #26
kellymac530
motorcycle addict
kellymac530's Avatar
Oddometer: 1,052
Just to help anyone who does not already know, anytime you bleed off the forks, the bike needs to have the forks fully extended.
You can do it on a stand or even on the side kickstand but you need to lift the bars a bit and make sure the forks are topped out while you losen and retighten the bleeders...or if you have the push bleeders it is easier, but they still need to be and stay extended while you depress the bleeder.
it is easier to ask for forgiveness than permission
kellymac530 is offline   Reply With Quote
Old 03-18-2013, 11:08 AM   #27
wbunt
wbunt's Avatar
Oddometer: 420
Nice build , great timimg , I just bought a KLX450 and have ordered some of the parts to get mine titled . Thanks !
wbunt is offline   Reply With Quote
Old 03-18-2013, 11:35 AM   #28
CHECK_OIL
CHECK_OIL's Avatar
Oddometer: 373
Thumb
Thanks, good tip!
CHECK_OIL is offline   Reply With Quote
Old 03-27-2013, 06:27 PM   #29
wbunt
wbunt's Avatar
Oddometer: 420
Just put the Pro Billet Peformance insert in mine . Very nice , sounds good without being too loud and runs better .
Old 03-27-2013, 06:29 PM   #30
Hondo OP
Hondo's Avatar
Oddometer: 9,805
cool!
Sent from my ASUS Transformer Pad TF300T using Tapatalk HD
Times are GMT -7.   It's 10:10 AM.
