Old 12-08-2012, 02:30 PM   #361
Cretin
Bing
Oddometer: 15
12.3:1
95 octane listed, the lower compression twin spark 650gs runs ok on 91, 12.3:1 sounds too much for 91 octane
Cretin is offline   Reply With Quote
Old 12-08-2012, 04:32 PM   #362
ferals5
800+652
ferals5's Avatar
Oddometer: 1,149
maybe, maybe not. so many other factors have a bearing on whether it will run happy on 91. Valve timing/overlap, ignition map, also fuel injection can run a higher air/fuel mix than carbs . there's a bucket load of parameters.
what probably will happen is the engine management will retard ignition to stop the knock and it will suffer from worse power and fuel consumption as it runs the engine in a less optimal part of the mapping.
My single sparker gets best performance & economy from 95 (11.5 ratio)
no easy answer.
cheers
Mark
ferals5 is offline   Reply With Quote
Old 12-09-2012, 02:03 AM   #363
davorallyfan
Commonist
davorallyfan's Avatar
Oddometer: 16,177
Nino is on nuts
Bruno is on bolts
Maurizio is on mudguards
I wish they would stop chugging on the chianti and get on with it.
7th Day Adventourist.
Re-incarnated
Terrafied
I have learnt a lot from my mistakes. I am heading out to make a few more.
davorallyfan is offline   Reply With Quote
Old 12-09-2012, 01:07 PM   #364
B1
Carbon-based bipedal
B1's Avatar
Oddometer: 3,385
pricing looks good...
strada on bike sales ride away for $10795 here by a victorian dealer. and he's got the terra for $9995.
$9695 plus ORC in qld here and taking orders now. and the terra for $8995 plus ORC.
EDIT: and just popped in to full throttle at slacks creek, brisbane today. they sold their first batch out already but are taking orders for the second lot coming. $9995 on road with dual seat reg and 12 months. so a few hundred less if you went single seat reg for six months. bloody cheap for an european bike...
B1 screwed with this post 12-09-2012 at 11:01 PM
B1 is offline   Reply With Quote
Old 12-09-2012, 11:42 PM   #365
Bigem
Bigem's Avatar
Oddometer: 2,558
Thumb
RIP KLR and DR!! ha ha
Hopefully this will force the Japs to stop producing 25yo bikes with the performance, economy and ergos to match and build 'modern' bikes!!
"I'm a thousand miles from nowhere,
Time don't matter to me,
Cause I'm a thousand miles from nowhere,
And there's no place I'd rather be!!
Bigem is offline   Reply With Quote
Old 12-10-2012, 03:47 AM   #366
ADVJake
***** dweller
ADVJake's Avatar
Oddometer: 4,341
I would call it modern in the way of EFI , dash and its "look" but i certainly wouldn't say it has better suspension, weight and capability than a 25 yo design of the DR / KLR.
Im still waiting for something else.
"And some guy said, let there be filtering, and we filtered and we saw that it was good, and hours became minutes..."
ADVJake is offline   Reply With Quote
Old 12-10-2012, 05:03 AM   #367
Muddler
Muddler's Avatar
Oddometer: 771
Agree, but at least it has the price to reflect that.
Speaking of which, no comparisons with the 660 Tenere yet?
Muddler is offline   Reply With Quote
Old 12-10-2012, 11:55 AM   #368
B1
B1's Avatar
Oddometer: 3,385
amen. although it's a bugger this husky is still so heavy. with the official specs saying 183kg for the terra it weighs a hell of a lot more than a DR650. if it was around the same weight i'd be ordering one now. there's an official husky model ride day this sat (with a terra included) at full throttle in bris between 8.30am and 2pm....
the usa-based thread on this bike is slamming it for having the rotax engines made in china now. but hopefully they'll have good quality control in place. most of our name brand goods are made there now and it's not an issue with western style checks in place.
B1 screwed with this post 12-10-2012 at 12:03 PM
Old 12-10-2012, 12:54 PM   #369
drchupachup
Thirsty
drchupachup's Avatar
Oddometer: 608
are these the same western style checks that the Japanese have been implementing for the last 3 or 4 decades?
drchupachup is online now   Reply With Quote
Old 12-10-2012, 07:54 PM   #370
Bigem
Bigem's Avatar
Oddometer: 2,558
183kgs wet/58hp, compares with 194kg wet/40hp KLR and 166kg wet/46hp DR650.
The Husky will run away from the other too and go a lot further on the same amount of fuel!!
Terra also makes the Tenere look very expensive in comparison!!
Old 12-10-2012, 09:00 PM   #371
davorallyfan
Commonist
Oddometer: 16,177
So when you rode it the suspension was a bit average eh?
Re-incarnated
Terrafied
Old 12-10-2012, 09:26 PM   #372
bully1
bully1's Avatar
Oddometer: 4,458
I may be wrong, I was wrong once before ( 1992 I think it was ) but the weight in the specs is 183kg ready to ride, I reckon that means full of fuel. DR weight specs is dry, take 13.5 kgs off the Terras weight then compare. Not much in it for the extra 15 ponies.
I reckon the Terra will piss over all the opposition.
'02 GSX 1400 outfit........lot's of grin factor
'11 Husky TE 630.......tyre shredder
'06 HUSKY TE610 x 2............ for the boys
'92 R100GSPD ( modified)...........slow and easy
bully1 is offline   Reply With Quote
Old 12-10-2012, 09:46 PM   #373
ADVJake
***** dweller
ADVJake's Avatar
Oddometer: 4,341
Going by what others have said, its got a similar feel to the husky 610 suspension which was very stiff considering it had long legs.
Old 12-10-2012, 10:15 PM   #374
B1
B1's Avatar
Oddometer: 3,385
well spotted bigem, the specs i saw didn't mention wet/dry at all. 165kg is sounding much more respectable. googled around and found this:
TR 650 Terra without ABS, unladen weight: 165 kg (363,76 lbs) / weight fully fuelled: 183 kg
probably drop another 5kg getting rid of the second pipe....
Old 12-11-2012, 01:11 AM   #375
Cortez
BAZINGA!
Cortez's Avatar
Oddometer: 7,083
That's exactly the same weight as the Aprilia Pegaso Strada/Trail, and that
thing goes very well, and it's 10hp down on the Husky.
'08 Yamaha FZ6n S2 ABS
SOLD: '03 Peugeot Speedfight2, '07 Kawasaki ER6F ABS, '06 Kymco Agility 125, '12 Kymco Downtown 300i ABS
My Flickr gallery --- My 500px gallery
Cortez is offline   Reply With Quote
Times are GMT -7.   It's 08:03 PM.
