Old 12-10-2012, 01:06 AM   #71731
Tyrepower
Tyrepower's Avatar
Oddometer: 148
Originally Posted by Magnum Noel View Post
Just to change the subject for a minute. Has anyone invented or found a way to waterproof their garage door remote whilst leaving it fixed on the bike? I have mine in my jacket pocket and sort of wobble down the the road stearing with my right hand whilst trying to activate the remote button through the jacket outer with my left hand. There must be a better way?
I just put mine in a zip lock bag.
My biggest fear is when I die, my wife will sell all my bikes for what I "told her" they cost!!!
It's all good fun until someone gets hurt......... then it's hilarious!!!
Tyrepower is offline   Reply With Quote
Old 12-10-2012, 02:37 AM   #71732
devans101
Oddometer: 32
Garage Remote
http://www.f2ptechnologies.com/
devans101 is offline   Reply With Quote
Old 12-10-2012, 03:32 AM   #71733
rogor
Oddometer: 44
+1 on the ziplock bag
rogor is offline   Reply With Quote
Old 12-10-2012, 03:41 AM   #71734
bull600
bull600's Avatar
Oddometer: 352
Never had a problem using this type - it's independent of weather
Cheers
bull600 is offline   Reply With Quote
Old 12-10-2012, 04:41 AM   #71735
planemanx15
planemanx15's Avatar
Oddometer: 1,009
haha..i was going to post the same video
2000 Suzuki DR650-790 - 790cc Big bore build thread
1985 Yamaha CA50 - The little scooter that Could
2009 Piaggio BV-250 - Escusi, Babba be bo-bee
planemanx15 is offline   Reply With Quote
Old 12-10-2012, 10:29 AM   #71736
Fire Escape
Fire Escape's Avatar
Oddometer: 1,600
Agreed!
Originally Posted by procycle View Post
Really! Removing the clutch isn't that big a deal. Nothing to be afraid of! Plus, it's an opportunity to inspect the steel plates for hot spots and the clutch basket fingers for wear. It doesn't take any more time to remove the clutch than it takes to dink around grinding tools and turning little screws 1/12 of a turn at a time. Once you have the clutch cover off it only makes sense to inspect everything you can while you're in there.
No question that you are correct, and if the project were to come up again I would pull off the clutch. I just looked at it once I got that far and said 'I can do this' and so I did. Sometimes it is good practice/therapy to figure out how to get it done 'the hard way' (at least for me, being retired and sometimes having 'too much time' on my hands). Not enough miles on my DR that I was concerned about inspecting the clutch.
Off topic: Just got through putting my set of your SM wheels back on the bike for 'winter' (down in a warm state) use, couldn't help thinking (again) how nice those wheels are. Done again I would probably go with 19/17 rather than the 17/17 but I doubt that I will wear these out. Thanks!
Bruce
No one calls the Fire Department because they did something smart!
06 DR 650, Moose RS Holder, Handguards and Skidplate, ProTaper bars, Garmin 60CSx, Motech racks w/ 20mm Ammo cans, Renazco 08 Scrambler, Conti Trail Attacks and BlackTiger Fork mod, 05 FSE 450, 03 KLR 250, 02 FXDX, 72 WR 250 (again), 72 SL 350 K2 (again), 72 TR6R, 06 XT 225
Fire Escape is offline   Reply With Quote
Old 12-10-2012, 10:32 AM   #71737
neo1piv014
ADV in training
Oddometer: 619
Bruce
What kind of rubber did you decide to put on them?
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 12-10-2012, 11:30 AM   #71738
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 3,044
I've always been skeptical of the old 'warp your valves' claim. I can't see how a little bit of cool air could do any harm. Especially since the exhaust valve heads get a blast of cool air on every intake stroke anyway.
My own opinion of where this old wives tale came from is this: If the motor had a restrictive exhaust and loosing the whole system caused the fuel mixture to become too lean - then you could easily damage the exhaust valves,
We used to run drag boats with zoomies on them which is an exhaust pipe about 8" long coming off the head. Never had a valve problem. The big thing is to let the valves cool before shutting the motor off. When you work a bike (or anything) really hard those valves get super hot. If you just shut the bike off they then get cooled quickly. Doing this multiple times can cause the valves to lose their temper. It is always a good practice to let an engine idle/low rpm to let things cool down at a slower rate before shut down.
Mongle is online now   Reply With Quote
Old 12-10-2012, 02:09 PM   #71739
Sierra Thumper
Oddometer: 641
Cheers
I just showed my wife this video....she thought there might be better options for garage door openers
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack
Sierra Thumper is offline   Reply With Quote
Old 12-10-2012, 03:02 PM   #71740
shu
Oddometer: 1,039
For those running the stock BST carburetor (no jetting or needle changes, no holes drilled) here is a pic of needle wear after 52,000 miles (83,000 Km).
Just a tiny bit of 'stepping'. (not a great pic but if you enlarge it on your screen you can see it a little better.)
I replaced it and the diaphragm anyway with parts from an almost new carb that I bought here for a nice price.
........shu
shu is offline   Reply With Quote
Old 12-10-2012, 03:13 PM   #71741
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,696
........shu
I wonder if that part of the needle is exposed to fuel enough that a little grease wouldn't stay?
Mambo Dave is offline   Reply With Quote
Old 12-10-2012, 03:38 PM   #71742
rogor
Oddometer: 44
Anyone have a spare oem header or is there a better option.[/QUOTE]
Just saw these on ebay. might be worth a look??
http://www.ebay.com.au/itm/280998084...84.m1424.l2649
Old 12-10-2012, 04:20 PM   #71743
dickensheets
smprparatus
Oddometer: 283
I had same issue years ago. I wired a remote switch in a discreet location on the side of the house. I've since seen them offered with keypads for ciphers. I can open the garage from outside the house now as long as the power is on.
dickensheets is offline   Reply With Quote
Old 12-10-2012, 04:54 PM   #71744
Midnightventure
Oddometer: 755
On my big bike I took a small remote, opened it up and soldered in switch with leads on it. Then put in a sandwich bag and installed behind a panel with the switch installed in a hole I drilled in the panel.
Midnightventure is offline   Reply With Quote
Old 12-10-2012, 09:29 PM   #71745
shaddix
Oddometer: 647
I replaced my brake fluid tonight on the front... didn't realize I needed a socket for the rear so it still has the old stuff.
Anyway, how do I know if I did it correctly? I used a syringe and pumped it up from the caliper to the reservoir instead of using the lever to pump it out. I then did a few pumps with the lever doing it the normal way to make sure no air in the caliper. I can pull on the lever and it activates the brakes early in the available movement of the lever, but if I pull harder I am capable of pulling the lever back to the grip. The pads are brand new...
shaddix is offline   Reply With Quote
Times are GMT -7.   It's 04:31 PM.
