Old 12-08-2012, 11:59 AM   #1
dwj - Donnie OP
dwj - Donnie's Avatar
Oddometer: 10,824
R1100gs oops!
The warnings about this was found after the damage was done:
While attempting to fix an oil leaking right hand head gasket we found the cam sprocket bolt frozen and used a air impact wrench to remove it. That succeeded in destroying both upper and lower plastic cam chain guides. We finally did get enough force to break the bolt loose but now it's damage recovery mode.
It looks like the engine has to come out and have the cases split to replace the cam chain guides due to the pins that pivot on inside the engine case. We've read about some people slotting the guides to enable replacement without the pain of the case splitting. I looks like for the lower one replacement might be possible by removing the pivot bolt on the outside of the case, but there is some concern about the one for the left cylinder coming out of position if this was tried.
We saw some info about this technique, but the info. was old and we're interested to know if the method is reliable for the long haul. Is there any guidance on the size and location of the slots out there?
Moe, Curly and Larry BMW repair...
BTW, this 1996 R1100GS is scheduled to leave for a 12,000 mile plus trip to Central America December 30!
Donnie - Retired & Riding
Return to Mexico 2012: http://www.advrider.com/forums/showthread.php?t=802682
Mexico & Central America Solo 2012: http://www.advrider.com/forums/showthread.php?t=767492
6,700 Miles to Baja, MX Solo 2011: http://www.advrider.com/forums/showthread.php?t=750875
dwj - Donnie is offline   Reply With Quote
Old 12-08-2012, 12:47 PM   #2
def
I have little to say
def's Avatar
Oddometer: 6,310
Send a message via Skype™ to def
Departing Dec 30th? You better get busy. I cannot comment on replacing the chain rails...maybe Anton the Expert has some insight here...and if he isn't too grouchy, maybe Sir Steptoe will chime in....or even Dr. JVB.
I'll be waiting and watching as to the path you take for repairs.
73
def is offline   Reply With Quote
Old 12-08-2012, 03:25 PM   #3
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 41,491
Steptoe has a method he posted, with photos, on how the change them without removing the motor or splitting the case. You cut the old ones out, then notch the hole where the pin goes and snap them in place.
Do a search. I will see if I can find it.
Jim
Old 12-08-2012, 04:05 PM   #4
bone13
bone13's Avatar
Oddometer: 201
Given your time frame, unless you have about a full week of free time dedicated to do a rebuild I would suggest the "split the rails" method. I know several technicians who have done this method with much success and have had bikes run at least 20k+ with no signs of failure. I would imagine if they will go that far they should last without a problem.
In regards to splitting the case method and why it takes so long: It's not the motor rebuild... its getting the motor separated. You do not drop the motor on this bike... You disassemble the entire bike from the motor... in sections, and without the frame jig its a REALLY big project. figure minimum 10-12 hours apart and 10-12 hours assembly thats 20-24 hours just to swap a motor provided everything goes smoothly. All said and done I had 40+ hours in mine due to a severe near untraceable oil leak in the clutch area (but I can now do a clutch swap on my bike in about 5 hours...lol).
When I did mine, I split the case largely due to my bike having 132k on it at the time I did it. As it's a bike I intend on riding for a long time to come, I wanted to be sure of the condition of the entire motor. I'm pleased to say even at 132K miles everything measured well within spec range. Although I did discover the timing chain tensioner rail was shot, which I never would have known without having removed the timing chain cover to do the motor tear down.
In summary, unless you just want a huge project or you have really high mileage on your bike and want to KNOW everything is right in the motor, and especially considering your time constraints... split the rails
On a side note if you do decide to split the case MAKE SURE all the necessary parts are available IN THE USA! the engine gasket kit when I did mine was not available in the states, and took almost a month to get Rush delivered from germany.
Good luck and let us know how it goes!
The Trouble with Trouble is it usually starts with Fun
www.ridgerunneradventures.com
bone13 is offline   Reply With Quote
Old 12-08-2012, 04:16 PM   #5
dwj - Donnie OP
Oddometer: 10,824
Anyone have pictures of the rails after they have been split? Thanks!
Old 12-08-2012, 05:41 PM   #6
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 29,135
Here is the lower rail. It can be replaced without splitting the cases. See the bolt head to the right of the screwdriver tip.
Here is the upper rail. It is secured in the left case.
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 12-08-2012, 06:06 PM   #7
def
def's Avatar
Oddometer: 6,310
Leave it to Anorak who has been everywhere in the boxer engine.
I wonder what those rails are made of, ABS? Delrin? Kel-F?
Old 12-08-2012, 07:28 PM   #8
Bender
I can pass this guy.
Bender's Avatar
Oddometer: 27,129
Send a message via Yahoo to Bender
I am pretty sure that Aardvark posted a thread on this very subject a few years ago.
Bender
Searching for the lost Xanadu.
The generation that would change the world is still looking for the car keys.
Bender is online now   Reply With Quote
Old 12-08-2012, 07:31 PM   #9
dwj - Donnie OP
Oddometer: 10,824
Hi! Bender!
Long time, no see!
Old 12-08-2012, 07:34 PM   #10
dwj - Donnie OP
Oddometer: 10,824
There was nothing under his "threads started"! I would still like to see a rail that has been slotted!
Old 12-09-2012, 05:29 AM   #11
Bender
Bender's Avatar
Oddometer: 27,129
Yo dude! I'll search a little harder next time I'm up to the computer. The search feature sucks on the phone.
Bender
Old 12-09-2012, 06:51 AM   #12
mike54
You don't get me
mike54's Avatar
Oddometer: 12,402
Here's a thread on UKGSER that has some good photos
http://65.38.186.190/forums/showthread.php?t=282821
I've seen something similar here but can't find it now.
A genius is the one most like himself. - T. Monk via S. Lacy
Do stand up guys lie?
mike54 is offline   Reply With Quote
Old 12-10-2012, 12:32 PM   #13
dwj - Donnie OP
Oddometer: 10,824
Thanks for the info and photos, you have all been a big help!
Old 12-14-2012, 12:16 PM   #14
Steptoe
steptoe
Steptoe's Avatar
Oddometer: 2,157
That thread will tell you all you need to know. A couple of engines i've replaced the cam chain guides on have now done more than 40K miles without any problems.
Have a good trip.
www.gsshop.co.uk
Steptoe is offline   Reply With Quote
Old 12-15-2012, 08:31 AM   #15
dwj - Donnie OP
Oddometer: 10,824
It looks like on the parts diagram shows a washer and snap ring for the side on the lower bolt the rail pivots on and that unscrewing the pivot bolt might cause those to fall out and drop down into the crankcase. How does that interact with replacing the lower guide?
Times are GMT -7.   It's 08:37 AM.
