12-07-2012, 06:20 PM
#4291 | |
Two-wheelin' Fool
Oddometer: 2,565
12-08-2012, 12:08 AM
#4292 |
Three Wheel Maniac
Oddometer: 401
7,5 Amps is apparently too critical for starting up HID. In all the bikes I prepared with HID, I exchanged the 7,5 A fuse for a 15 A. Problem solved
Three Wheel Fever forever Xtankteam™ Proud sponsor of the Sibirsky Extreme Project |
12-08-2012, 07:35 AM
#4293 |
Oddometer: 1,309
![]() A blown fuse suggests a short. With everything else, sounds like you might have a bad ballast. Swap the wires to the ballasts and see if the highbeam turns on with no low beam Thanks gents. One issue fixed, researching the other and hope I didn't make an $$ problem with my wiring job. Oh well, learn by mistakes. Know where I might get a ballast alone if that's the problem? No way do I want to buy a whole set-up just for that if I can help it.
"Not all those who wander are lost" J.R.R. Tolkien |
12-08-2012, 12:40 PM
#4294 |
Two-wheelin' Fool
Oddometer: 2,565
12-08-2012, 03:05 PM
#4295 | |
Team 2nd Wind
Oddometer: 1,384
08 WR250F 07 G650 X Challenge ![]() Bergen Co, NJ AMA / CJCR / ECEA In a world that what we want is only what we want until it's ours |
12-08-2012, 08:54 PM
#4296 |
Panzerkampfwagen VI
Oddometer: 1,119
Thanks Tammy.
Dan 2005 BMW R1200ST 2007 BMW G650X XChallenge |
12-11-2012, 05:37 AM
#4297 |
Oddometer: 262
Ohlins Sale
I have no relation to this but figured I should mention it on here for anyone whos shopping for a new shock.
I only go in vendors once a month, and figure many are the same and will miss it. http://advrider.com/forums/showthread.php?t=846354 I bought my ohlins through a group buy last year and it was the best money ever spent. The price I paid was only slightly less than the $727 these guys are charging, and I had been looking for a year before buying one. |
12-11-2012, 08:33 AM
#4298 |
Oddometer: 2,068
Doesn't the Ohlins make the bike a bit taller? Seems like a good price, but I have been leaning toward getting a Hyperpro, possibly even a shortened one. Not sure I want something that will make the bike seem even taller since I'm a little fella.
Marc 07 XChallenge 99 VFR |
12-11-2012, 09:35 AM
#4299 |
Two-wheelin' Fool
Oddometer: 2,565
Yes. An Ohlins that is sprung properly will make the nike A LOT taller. Mine has a seat height of about 42". Just realize that putting 2 feet flat on the ground is really overrated.
12-11-2012, 09:43 AM
#4300 |
A nation in despair
Oddometer: 21,030
the need for 2 feet flat on the ground is a nasty myth spread by some here as well as presumably well meaning outfits like MSF. I have no idea where it comes from except ignorance. I wonder how many tip overs occur due to some hapless new rider trying for two flat feet, finding one is over a depression, him losing his composure and going down on that side.
Why be born again when you can just grow up? |
12-11-2012, 10:20 AM
#4301 |
Oddometer: 1,437
I hate to admit I'm such a poor mechanic. I swapped out chain and sprockets a while back. The front sprocket has no locking washer, or anything to keep that bolt in place.
I put some locktite on it, but it still makes me nervous. Is there something I'm missing? Anyone else wonder about this? Just tighten it as much as you dare and go? Thx..
IBA#32778 2008 R1200GSA 2007 G650XChallenge No man is as good as he ought to be, and few men are as bad as they seem.. (from a early 1900s post card found in Perry, Missouri..) |
12-11-2012, 10:23 AM
#4302 |
Oddometer: 2,068
Flat feet?!?! Who said anything about flat feet?
I'm 5'8" with an inseam < 30". I'm fine with tippy toes or one foot at a stoplight. But a 42" seat height! I think I'd have to put the sidestand down at lights. I'll probably go with the Hyperpro. I'm toying with a lower shock because for the riding I do, I think the confidence from a lower seat height would actually outweigh the loss of travel. My bike is likely getting close to 400 pounds, and it gets a bit unnerving on off camber or really rocky trails. I can only think of one time where I even came close to using all the suspension. Even then, I don't think a 1" lower shock would have made much difference, but the lower seat height would have been comforting.
12-11-2012, 11:00 AM
#4303 |
A nation in despair
Oddometer: 21,030
If his seat height is really 42", the side stand won't work unless it's majorly extended.
12-11-2012, 11:10 AM
#4304 |
Two-wheelin' Fool
Oddometer: 2,565
My bike leans over pretty far on the sidestand. I usually do a side launch to get going (first gear, gas + clutch, stand up on left peg, swing right leg over) and the reverse to dismount the bike. Stoplights in high winds are interesting.
12-11-2012, 11:35 AM
#4305 |
A nation in despair
Oddometer: 21,030
I'll bet. We often have very high winds here. Riding the DRZ over freeway fly overs always was an adventure during those times. Even standing at a stoplight could be a challenge & that only had a 37" seat height.
