Old 12-11-2012, 08:09 PM   #3961
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,900
Originally Posted by Marki_GSA View Post
They were on at least 08-09 as well. My 09 has them.
Good info!
Jim
Old 12-11-2012, 08:14 PM   #3962
taran1900
taran1900's Avatar
Oddometer: 7
Originally Posted by tallguy-09 View Post
Curious about that feature, is it still there?
You have to buy the Ganz tolles extremes Eigenschaft-Paket to get it.
taran1900 screwed with this post 12-11-2012 at 08:25 PM Reason: I can't spell.
taran1900 is offline   Reply With Quote
Old 12-11-2012, 08:24 PM   #3963
taran1900
taran1900's Avatar
Oddometer: 7
Originally Posted by Montauk View Post
I couldn't figure out the purpose of this plastic thing sticking out on the left side above the cylinder
It is the new Fluss-Kondensator.
Old 12-11-2012, 11:21 PM   #3964
Kokopelli
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,662
No doubt Touratech is bending a protector for it as we speak.
R1150GS
R80GS Basic
Kokopelli is offline   Reply With Quote
Old 12-11-2012, 11:39 PM   #3965
Montauk
Oddometer: 280
Not much difference. The screws look different.
Montauk is offline   Reply With Quote
Old 12-11-2012, 11:42 PM   #3966
Rauven
I like the cold...
Oddometer: 195
But where will we get 1,21 Gigawatt from ?
Rauven is offline   Reply With Quote
Old 12-12-2012, 12:09 AM   #3967
advNZer?
advNZer?'s Avatar
Oddometer: 2,878
wait till 88 mph
aka BMWST?
advNZer? is online now   Reply With Quote
Old 12-12-2012, 08:00 AM   #3968
twray
Oddometer: 60
Any word on cruise control?
twray is offline   Reply With Quote
Old 12-12-2012, 08:19 AM   #3969
Montauk
Oddometer: 280
What about it? It's there. The control is on the left side.
Old 12-12-2012, 08:40 AM   #3970
Montauk
Oddometer: 280
At the show I asked the BMW Rep from NJ about the battery capacity being less. He kindly educated me that the decrease in the 12 amps from 19 (I think from current model) should not be viewed as a problem. It is the alternator that is critical to supply power to the system when in use. It quickly replenishes the energy back to the battery upon startup and continue to supply necessary energy to the system. If the alternator is of low capacity, then it fill not able to supply energy to the system, and will utilize the stored energy from the battery, thus depleting it.
He said the new WC has 580 Watt alternator. Current model has 620. The reduction is sufficient due to efficient use of electrical use. I asked him having additional lights and Gerbing gear will it be able to support. The answer is Yes!
He recommended using additional lights based on LED. It will draw very little electricity. You can continue to use your Gerbing gear, although to keep on mind that this gear uses lots of electricity, upon power-off, make sure you turn your Gerbing heat controller off. (I learned this when fueling my gas tank. I forgot to turn off, it depleted my battery. Lucky after few attempts I was able to start my bike's new BMW battery.)
So I was rest assured that 580W is adequate for the bike.
I suppose using less powerful alternator and battery, both will yield less space and less weight, necessary to offset the weight gained due to water cooled.
Old 12-12-2012, 08:48 AM   #3971
cug
Oddometer: 4,876
I was thinking about this video again, and now watched it a few times - not for the sound, I don't care too much about the sound of a bike, but I can't see the bike rocking sideways at all. Not a single shudder on start or throttle.
As I don't have my R1200GS anymore, I can only go from memory, but I think whenever you started that bike, it did rock sideways, even when it was on the centerstand. It didn't move badly of course, but I'd think the camera would catch this.
More and more looking forward to test riding it when they arrive here.
cug is online now   Reply With Quote
Old 12-12-2012, 09:08 AM   #3972
Montauk
Oddometer: 280
First I watched a video clip on YouTube where BMW person in Europe does a test on the side stand, and he gave more gas than at the show. I did not notice any sideway movement. It was awesome. BMW did acknowledge some improvement to minimize sideway (PTTL) movement. However, when Charlie Boorman tested it moved to the left. Notice it through the mirror.
YouTube link (could not embed from an iPad)
Charlie Boorman
Montauk screwed with this post 12-12-2012 at 09:37 AM Reason: YouTube link
Old 12-12-2012, 10:06 AM   #3973
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
Yes, it's an available option
EJ_92606 is offline   Reply With Quote
Old 12-12-2012, 10:09 AM   #3974
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
Interesting...I was so focused on the sound I didn't think about vibration, but looking at it again, the mirror and the windshield appear to be rock solid! Very nice!
Old 12-12-2012, 11:03 AM   #3975
oalvarez
Resident Raggamuffin
oalvarez's Avatar
Oddometer: 2,572
At the show I asked the BMW Rep from NJ about the battery capacity being less. He kindly educated me that the decrease in the 12 amps from 19 (I think from current model) should not be viewed as a problem. It is the alternator that is critical to supply power to the system when in use. .
but what about in relation to starting the motorcycle? 12a seems low, no? if there aren't enough cranking amps/voltage at startup it can affect the abs system.....interesting.
2014 Ducati MTS1200S
2012 Vespa 300 Super
past: Ducatis, Aprilias, Moto Guzzis, a Husky, KTM 1290 SDR, and some BMWs as well.
oalvarez is offline   Reply With Quote
Times are GMT -7.   It's 01:20 AM.
