12-12-2012, 03:47 AM
#6496 |
SAND EATER!
Oddometer: 477
I love my bike. I love it so much.
I was splitting the lane at a red light, and some ass hole in a gay little ricer civic thing didn't like it. he's revving his engine like a dick calling me a bitch out the window telling me to get my slow ass dirt bike off the street.. I motioned at the light and when it turned green i just smoked him and didn't even bother looking back. slow ass dirt bike was faster than that lame car.
'83 Honda XL600R valve seat ![]() RIDE RED! |
12-12-2012, 03:56 AM
#6497 | |
from the land of OZ
Oddometer: 253
Stu in FNQ The early bird catches the worm, but the second mouse gets the cheese. Growing old is mandatory... growing up is optional. 1985 XL600R 1988 XR600 |
12-12-2012, 04:22 AM
#6498 | |
Flange Furtler
Oddometer: 368
You could still buy the parts you need and have them posted over though |
12-12-2012, 04:34 AM
#6499 |
SAND EATER!
Oddometer: 477
No sticker, just a big ugly dirt bike. I fixed the clutch lever since then, picture was taken right after my first ride.
12-12-2012, 05:04 AM
#6500 |
Oddometer: 204
True. Though from what lve read on other forums to convert an XL600 to electric start requires a change of crankshaft, as well as left side crankcase and starter motor and stator cover. Lot of trouble and expense. Might be better off trying to find a lmf or rmg motor or bottom end at a wreckers or on ebay.
12-12-2012, 09:01 AM
#6501 |
Oddometer: 196
I'm sure this has been covered before.... and if it's been covered in depth before then we don't have to go over it in depth again... maybe someone could give a short answer of point me to the previous discussion... but:
Could one buy an XR650L bottom end (electric start) and swap on an XL600R top end (dual carbs, works with center-mount mono-shock) ? Would the connecting rod need to be swapped? Wouldn't that be a good way to get an electric start XL600R, with domestically sourced parts? Now don't get me wrong... I'm not necessarily anti-kickstart. It definitely has it's cool factor. But I did own one of these XL's in my 20's (20 years ago, 20 years younger!) and there were times that it wouldn't start, and that was REALLY frustrating. I will get this bike in good shape, and if it kick-starts easily every time, then I won't worry about this anymore. But if it ends up being frustrating, well then that is why I am engaging in this thought experiment NOW, to know my options. Thanks, Christian
Current Bikes: 1986 Honda XL600R, 1988 Hondasuki KLNX250R, 1988 BMW R100GS (dead) Previous Bikes: Honda XL250 (2 of them), Honda XL600R, Kawasaki KLR600, BMW K1100LT, BMW R60/6, BMW K75, Husqvarna 430XC Click HERE for my Cummins 4BT International Scout build thread www.christianristow.com |
12-12-2012, 09:04 AM
#6502 |
Oddometer: 7,983
Cut to the chase. Just buy a XR650l. No fuss, no muss.
Steve in SF BMW's 58 R26 79 R100s 91 R100gs 87 Harley FXRS-SP ~ 06 KTM 625 SMC ~ 72 Honda CB750/915cc ~ 92 XR600/654cc ~ 95 XR650l/675cc ~ 03 CRF450r ~ 05 CRF450x ~ 02 XR650l/675cc ~ 86 YZ490 ~ 93 YZ80 ~ 93 XR650l Project |
12-12-2012, 09:50 AM
#6503 |
Oddometer: 196
Install rotor cover gasket DRY? Or with a little silicone?
Anyone have experience installing dry (which is what I understand Honda recommends) and regretting it? (It's a Honda OEM gasket) Thanks, Christian
12-12-2012, 09:56 AM
#6504 |
Oddometer: 196
I am familiar with that logic... and it's very compelling.
On the other hand, I already HAVE an XL600, and the XR650 purchase option entails at least a $ grand or two outlay. So, just looking at options....
12-12-2012, 10:04 AM
#6505 | ||
Olds Cool Adventurer
Oddometer: 2,671
Easy starting on the XL is all about proper tuning. If the valves are adjusted correctly (easy), and the carbs are in good shape with no leaks (not so easy), the XL starts as easy as the average 250. |
12-12-2012, 02:07 PM
#6506 |
SAND EATER!
Oddometer: 477
How much work is it changing fork seals? I've never done it before... and those bitches are leaking.
12-12-2012, 02:50 PM
#6507 | |
Oddometer: 7,983
It's duck soup. I'm finished with the seals in a couple beers. Ten minutes a side tops.
12-12-2012, 05:15 PM
#6508 | |
Oddometer: 196
On another note... I am pretty serious about the dual headlight mod. Mostly because 1) I think it looks awesome, and 2) I have never liked the look of the rectangular light. Dunno why, just never have. So, I was about to go ahead and purchase the dual headlight assembly from a Yamaha FZR600 off of eBay, when I noticed something... the Mercedes 300D that a friend of mine abandoned on my land several years ago (bad tranny) had inner headlights that were the right diameter... Here's a pic from the web (not the car at my place) ![]() I called my friend to OK it, and then took out the headlight assemblies. The frames (or plates... they are cast aluminum) that hold the lights are pretty nice, and they have REALLY NICE adjusters for beam direction. So I stripped the lights out of the mounting pates, cut them in half, and TIG welded the "small" sides back together. ![]() ![]() See what I mean about those adjusters? They're awesome! And also this new assembly has tons of good places to mount itself to the bike. One issue is that the lights are the kind where you insert the bulb into the back... they are not sealed one-piece units, and the bulbs in there are single-filament (no high beam... or no low beam.. not sure really). So, I have to either look for a replacement bulb that fits in there that has multiple beams, or just get new 5.75" diameter sealed unit lights. I'm not sure of the right approach, but next time I am in town at the auto-parts store I will figure it out. Next up... (although this won't happen for a while because I can't do it until the front end is put back together) I will fabricate from aluminum a little fairing/cowling to go around the lights. I will probably try to closely emulate the stock euro-only-dual-light version, cuz I think it looks good. Christian
12-12-2012, 05:21 PM
#6509 |
Oddometer: 196
And also... my bike is in so many pieces all over the shop that I thought it would be fun to take a panoramic picture of it. It's too big, however, to post here... (plus I don't wanna put TOO many pictures of my build on here... just trying to be sensitive. Sometimes I think I should just start a build thread... but this seems to be where the action is)
HERE is the panorama. If you look closely you can see parts of the bike all over the place. Christian
12-12-2012, 05:23 PM
#6510 |
Oddometer: 196
Thanks. I talked to Mike at Ricky Stator today about the issue, he said I had 100 watts to work with on the lights, and I think that 50 watt bulbs are pretty standard in that diameter.
