12-02-2012, 11:49 AM
#31 |
Oddometer: 3,441
12-07-2012, 03:05 PM
#32 |
gonzo
Oddometer: 579
Definitely two pieces, an inner bladder and the outer shell. You can remove the gas cap and see it pretty clearly there.
Stubborn and Stupid "It's supposed to be a challenge, that's why they call it a shortcut. If it was easy it would just be the way." ~ Rubin, Road Trip |
12-07-2012, 03:39 PM
#33 |
Oddometer: 212
After reading the thread I'm still trying to understand the cause. If there's a bladder then there is no contact with fuel to the outer shell so it's not the Ducati problem where the ethanol causes the tank to develop bulges. If it's expansion then it would be easy to reduce the volume of the bladder or adjust the shape to allow a little clearance. If it's stress related fracture due to vibration etc then why wouldn't it be beefed up a bit in the areas where they crack? So what's going on here?
12-07-2012, 03:52 PM
#34 | |
Oddometer: 2,825
Erling |
12-11-2012, 02:14 PM
#35 |
Oddometer: 35
So I'm buying an '09 with the cracks, it is out of the three year warranty. Does anyone know if indeed this is covered for the 5 year fuel/emissions warranty? Has anyone reported leakage or is this strictly cosmetic?
Anxiously awaiting the cutaway of one...
12-11-2012, 03:31 PM
#36 | |
Oddometer: 2,825
Erling |
12-11-2012, 04:13 PM
#37 | |
gonzo
Oddometer: 579
I don't know if I'd classify it as it "strictly" cosmetic, it may indeed weaken the fuel tank. But the cracks will not instantly cause fuel leaks. I don't have a cutaway, but here are pictures of where the fuel pump and filler neck are mounted. ![]()
12-11-2012, 06:41 PM
#38 |
Oddometer: 35
Thanks for the info gents, picking it up tomorrow from a private party. Bike has just under 12k on it and he had the 12k service done at a local dealer in November. While he hadn't noticed it and they didn't tell him about it, the RO has tech notes that the tank is cracking and he was upfront and told me about it when I looked at the bike.
I will probably try to get it replaced even though it seems it may happen again from what everyone is saying. Worst case I see a few on forums and Ebay for sale with no cracks from parted bikes, I wouldn't mind doing it myself, need to learn the ins and outs of the bike eventually. |
12-11-2012, 08:24 PM
#39 | |
gonzo
Oddometer: 579
Edit: the tank comes off pretty easily, but you have to remove the subframe from the bike as the tank slides over the front of it. Makes sense when you see it.
Stubborn and Stupid "It's supposed to be a challenge, that's why they call it a shortcut. If it was easy it would just be the way." ~ Rubin, Road Trip Pomo screwed with this post 12-11-2012 at 08:37 PM |
12-12-2012, 03:59 AM
#40 |
Oddometer: 4,915
I have swapped many subframes and tanks, no special tools needed. The ring for the fuel pump can be unscrewed by tapping it with a screwdriver/chisel and a small hammer.
Proud member of the HUSABERG ADVENTURE TEAM! '12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6 |
12-12-2012, 06:48 AM
#41 |
Oddometer: 3,441
Just one note of caution. When working around fuel systems be careful of sparks.
Catastrophies are very rare, but having seen one in a garage I worked in many years ago ... I never want to see another one. ![]() I have a piece of brass rod that I use when I need to "persuade" something tied into a fuel system. Copper and alloys containing copper (brass, bronze, Monel metal (copper-nickel alloy), copper-aluminum alloys (aluminum bronze), are all non-sparking. A hunk of copper water supply pipe can usually be found without much trouble. I'll be the first to say that the risk is very small, but if the tank went boom it would really screw up the rest of your day
12-12-2012, 11:50 AM
#42 | |
Oddometer: 36
If the tank is of the construction I am describing, there is no separation between the white & black material shown in the picture. *former engineer at a fuel tank manufacturer |
12-12-2012, 02:02 PM
#43 | |
Oddometer: 3,441
![]() So is a crack that starts in the outer black layer of the tank likely to stop at the interface, or at least be slowed down, due perhaps to the layer of less permeable material between the inner and outer layer? Is the less permeable material (in between) just a coating or does it have some real thickness to it that you could see if you examined the tank closely? |
12-12-2012, 02:36 PM
#44 |
Oddometer: 480
So why are they cracking?
12-12-2012, 02:41 PM
#45 | |
Oddometer: 36
All my input is based on the one company I worked for in the fuel tank industry, BMW's tanks may be built/designed/molded in a different process or using different materials than I have experience with. |
