Old 12-08-2012, 07:22 AM   #3436
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 5,979
Friday December 7, 2012
International Motorcycle Show, Long Beach, CA
Walked the show last night. Finally got to see the Terra 650. Looks like the 630 but different. Looks to have the same suspension. Probably make a lot of people a very nice dualsport.
Specs revealed an 80lb weight gain though. Holy crap, that's double what I figured it would come in at. Oh my. I feel real bad for those that will take them offroad. It's just as bloated as the Sertao. I can hardly lift that one off the kickstand.
So even with my Dirtbagz and all my gear I'm just about up to the dry weight of the new Huski. OMG.
Bar-10 Ranch, North Rim of the Grand Canyon, 2012
Chris Brown - "The Browneye"
"Without Motorcycles, People Live Very Boring Lives." - Malcolm Smith
Camp Nelson 2014 RR Laguna Seca 2012 RR Sequoia 3-Day Campout Thanksgiving 2012
browneye is online now   Reply With Quote
Old 12-08-2012, 10:46 AM   #3437
Blaise W
Blaise W's Avatar
Oddometer: 679
Chris, no way the Terra is in the same league as the TE630! Don't even think about it, if you ever really did. I think it will be a nice road bike with the ability to poke it's nose down a few reasonable trails. I'll have mine in Death Valley (along with the 630) and you can try it out if you like. Just keep it off of Lippencott or the trail to the Salt Trams!
Ken
Blaise W is offline   Reply With Quote
Old 12-08-2012, 03:35 PM   #3438
Gryphon12
Gryphon12's Avatar
Oddometer: 1,333
Same Suspension? First, it's non-adjustable. Then...
TR650: GC: 8.1" Seat: 34.4" Travel f/r 7.5/ 7.5" Rake: 26.5* Trail: 4.41" WB: 59.1"
TE630: GC: 11.8" Seat: 37.2" Travel f/r 10.6/12.6" Rake: 30.0* Trail: 4.58" WB: 58.5"
Capabilities: All the difference in the world! TR better for the street - TE better off-road.
And...It is a Husky Sertao!
1990 Honda NT-650 Hawk-GT
Never doubt that a small group of thoughtful, committed citizens can change the world;
indeed, it's the only thing that ever has. - Margaret Mead
Gryphon12 is offline   Reply With Quote
Old 12-08-2012, 05:56 PM   #3439
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 5,979
What is 'GC'?
I did not realize there was that much difference in suspension. I just looked at the Terra forks and they looked the same.
BTW, the Terra had crappy (cheap) looking rims. I did notice that.
I'll be keeping my 630.
Old 12-08-2012, 06:05 PM   #3440
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 5,979
Ken
Speaking of the Salt Tram, you should plan to do that ride with us. I would love to do it again. Awesome scenery, you look across at the Sierra range, not up at it.
We came up the back side from the 395, down into Saline Valley. That's quite a downhill, certainly easier than trying to go up it.
Sierra range in the background here...
Old 12-08-2012, 08:29 PM   #3441
Gryphon12
Gryphon12's Avatar
Oddometer: 1,333
Originally Posted by browneye View Post
What is 'GC'?
Sorry, I type too fast sometimes and forget my database short-hand doesn't always translate. "GC" is ground clearance. Sometimes analogus to seat height, and sometime correlates with suspension travel, but not always. Together with steering geometry and wheel-base, they give me a pretty good picture for comparing with other similar bikes - until the test ride, when it all goes out the window!
Old 12-09-2012, 05:22 AM   #3442
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 5,979
Ah, well yes, if they took 3" out of the suspension then it reduced the seat and ground clearance by the same. Wow. I can't imagine, even the 630 is pretty limited, it bottoms regularly if ridden hard. I may have to have mine updated/re-done.
Old 12-12-2012, 10:14 AM   #3443
Fast1
Twisted Throttle
Fast1's Avatar
Oddometer: 1,884
Has anyone attemped install of the compression adjusters, changed fork weight oil or volume and/or changed front springs in their forks?
Results?
Difficulties doing the install/labor?
Source for compression adjusters?
14 Husqvarna FE 501 10 Yamaha FJR 1300 11 Husqvarna SM630
Fast1 is offline   Reply With Quote
Old 12-12-2012, 03:02 PM   #3444
johngil
Reseda, CA
johngil's Avatar
Oddometer: 3,801
Results?
Yes.
Adjuster was from Marzocchi and I purchased from my local suspension shop. I had the forks re-valved, so I can't compare with a stock setup.
I have a set of .52 springs, but haven't put them in yet.
I believe LT Racing has the adjusters in stock.
johngil is online now   Reply With Quote
Old 12-12-2012, 09:46 PM   #3445
Blaise W
Blaise W's Avatar
Oddometer: 679
I had LTR work on both forks and shock; a world of difference. While he was in there I had him remove the spacer in the forks to give me back the extra inch Husky took out on the 630. Nice. The stock rear spring was way too heavy and it was lightened quite a bit. Maybe a notch too much though. It's perfect when riding without gear, but sags just a bit much when fully loaded for full on adventure rides and can bottom on big hits. It's so cushy though I think I'll leave it alone since there is plenty of pre-load that can be cranked in when needed.
Old 12-12-2012, 09:48 PM   #3446
Blaise W
Blaise W's Avatar
Oddometer: 679
Chris, if you guys do the Salt Tram again, I definitely want to go! Sounds like a challenge, and fun! I can't wait to load up and head for Death Valley again. Glad you are taking the RV this time as it has to be a LOT better than the tent.
K
Old 12-12-2012, 10:12 PM   #3447
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 5,979
K
You got it. I'm going to try and get johngil to lead a ride again. Going to tell him to cut some of the sand going west ouf of Darwin though. It's an epic journey up there and just enough technical to make it fun.
I would like to get some suspension work done on mine for sure. Guess I'll have to look up this LTR guy.
The tent is fine. Been camping out in one all year while the coach sat. It finally needed some tires after eight years, they were getting cracked enough I didn't want to drive on them anymore. A blow out on the 19.5's can take half the fenderwell out. But yeah, it's a nice haven if the weather turns crappy. Besides, I think wifey and son are coming this year. I may have to bring the tiger too, take her on a tour, scotty's, ubehebe, etc.
Here's johngil at the salt tram cabin. The guy is a hardcore rider for sure.
Here's the dentist, the architect, and the computer wizz. In no particular order.
On the way to the tram site. And yes, there was snow up there.
The Salt Tram structure with Saline Valley below.
browneye screwed with this post 12-12-2012 at 10:22 PM
Old 12-12-2012, 10:26 PM   #3448
Blaise W
Blaise W's Avatar
Oddometer: 679
KTM guys just HAVE to wear some orange, don't they! That's a great shot and I wonder if I could talk you out of a copy? Taking along your Jet Boil for coffee was a stroke of genius and I've taken to copy lately. I'm running without racks lately and just using Wolfman Enduro bags as they carry plenty for day rides. Sounds like a wise move for the climb you described. I'm bringing my new Terra along to do some road and light gravel this time so I can save my knobbies. I also want to run out to Lone Pine and try to get up Mt. Whitney as it was closed for road maintenance last year. So much to see in DV.
Old 12-12-2012, 10:53 PM   #3449
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 5,979
Ha! Says a guy on a husky with red on, and his buddy just the same.
The jetboil goes in my mid-rolie bag on the back for cup-a-soup or coffee. Pretty nice when there's a chill in the air.
Here's my Osborne Cabin lunch spot.
The ol' browneye...at Osborne. I was solo and getting bored so I snapped a pic. Just as I was getting ready to head out, 8 other riders from my group showed up.
Up the canyon at Osborne
Old 12-14-2012, 05:42 AM   #3450
SilverBullet
Oddometer: 434
...Source for compression adjusters?
You can also get the compression adjusters through Husky. TE610 came with them in for a few years. Sometimes Husky parts are better priced than aftermarket.
_
2013 Yamaha Super Tenere
2011 Husqvarna TE630
2004 Suzuki VStrom 650
2002 KTM 300EXC
1974 Suzuki TM400
SilverBullet is offline   Reply With Quote
Times are GMT -7.   It's 09:01 AM.
