12-11-2012, 12:59 PM
#46 |
Oddometer: 900
Personally, I think you are 'over thinking' the issue.
On the throttle cables and the choke, the issue is are they really at closed. You don't need to worry about the fully open issue. If you can't get them fully closed, you're hosed in terms of setting idle speed. If the choke is not fully closed you will never get the idle mix correct. |
12-11-2012, 01:12 PM
#47 | |
BigBrowedNeandereer
Oddometer: 1,004
His butt dyno is so finely tuned, it trumps all science. His eyes are more seeing than an electron microscope. Some of these airheads threads are 5 pages long, and 3 pages worth is just him repeating his demand for all and sundry to bow to his "wizdom". This is the ego of the Shaft, so just keep the salt handy as it takes lots of pinches to get past him and all other charlatans like him. |
12-11-2012, 01:58 PM
#48 |
Oddometer: 2,369
May I be so bold as to suggest that you try a 'Hamonizer' for what you're doing? (Digital balancing tool which was sold in the 'Vendors' section) Or would that be throwing more fuel on the fire? Just trying to be helpful here..... I'll go away now and watch the replies.
12-11-2012, 03:49 PM
#49 | |
because I can
Oddometer: 6,066
12-11-2012, 03:54 PM
#50 | |
because I can
Oddometer: 6,066
Make sure the choke lever goes to full on against the stop and full off against the stop. That's when they are adjusted right. IMO you really need to adjust them to the full on stop or they can be about impossible to start in cold weather. |
12-12-2012, 10:31 AM
#51 | |
A proud pragmatist.
Oddometer: 2,860
Glad I could help you with that.....somewhere else. Need more pics?....I'll be over there!
Have tools, will travel!
12-12-2012, 11:34 AM
#52 |
Oddometer: 2,531
good point ... pic's or it didn't happen
SS all BS aside, I don't mind anyone drilling into what ever I post. this is why IMHO, detailed technical data on forums are among the most accurate available anywhere because it's Vetted!. anything that survives yours and others ruthless nit-picking ... odds are will be correct. there's detailed technical postings all over the WWW. But trouble is it's very hard to tell crap from truth. which gets back to why I've got such a high opinion on technical information posted on forums. it's vetted!!!! especially on high traffic forums like ADV with 287k members. anytime someone posts technical data. if there's any hint of a mistake. Someone will ruthlessly point it out!!! odds are usually there's several folks waiting to pounced on ANY mistakes no matter how small. this is why I'll go out of my way to post LOTS of clear pictures. to where there is NO doubt validity of what I've posted. not saying I've never made mistakes ... but very seldom will anything I post be fundamentally wrong. why do you think folks are constantly posting... Pic's or it didn't happen!!! (SS if need be I'll chase down as easy to use, digital camera to send you for free and/or help you get up to speed on posting pic's.)
Bringing BMW R90S back to life, R80G/S, LiFePO4 testing Which is more reliable ... Points or Electronic Ignition for Airheads? _cy_ screwed with this post 12-12-2012 at 12:17 PM |
12-12-2012, 07:34 PM
#53 | |
because I can
Oddometer: 6,066
12-12-2012, 07:48 PM
#54 | |
Oddometer: 2,531
when I stated my believe above, reasons was stated why. I've personally done 500+ carbs ... don't need google to tell me what works... in this thread .. manometers was in question so I posted up all types of manometer from my HVAC tools to leave zero doubt that I understand how manometers work. but evidently claims backed up with evidence means little to nothing to you. you keep right on ignoring documented statements while providing none of your own. why don't you back it up... you post all sorts of statements with no pic's, links, etc to back it up. I've even offered to send a camera for free and help with learning process. pic's or it didn't happen...
Bringing BMW R90S back to life, R80G/S, LiFePO4 testing Which is more reliable ... Points or Electronic Ignition for Airheads? _cy_ screwed with this post 12-12-2012 at 08:02 PM |
12-12-2012, 11:30 PM
#55 |
Oddometer: 2,052
Checked the throttle cables? you might have frayed cable which is causing one side to hang up occasionally.
I go with the previous advice on setting- with the carbs off I set the butterflies one turn open, the mixture screws about 1/8 th turn less out than the book, and 1/16 ": free play in the throttle cables - if you can get someone else to turn the throttle you can synchronize them near enough by feel. If everything is in good order this will be as good as you need, and if it doesnt work you have something wrong that should be found and fixed - no point in trying to adjust it out. For fine tuning I use a colourtune plug , and I balance with a Synchrometer flow gauge, but that is just personal preference. And I check the valves by feel on a hot running engine -----.
Adelaide Hills, Australia. 93 R100 GS, 77 R75/7 ,70 BSA B44VS, , 86 R80 G/S PD, 95 BMW Funduro F650 ST |
12-12-2012, 11:51 PM
#56 | |
Oddometer: 2,531
if one has not seen a colortune, there's a clear quartz window that allows viewing during combustion.
Bringing BMW R90S back to life, R80G/S, LiFePO4 testing Which is more reliable ... Points or Electronic Ignition for Airheads? _cy_ screwed with this post 12-12-2012 at 11:57 PM |
12-13-2012, 01:50 AM
#57 |
Oddometer: 1,006
Three is a school that believes that colourtunes give inconsistent results on 1000cc airheads, because the mixture in the big cylinders just does not burn cleanly.
Better to aim for adjusting the mixture screws for the most power/revs
Charles http://i46.photobucket.com/albums/f1...ps6e61ae2e.jpg R90s 1070 replica, R90/6 1971 Commando Fastback |
12-13-2012, 01:44 PM
#58 |
Oddometer: 2,052
Colourtunes work just fine on all my airheads, and the twin plug motor looks no different to the others.
FWIW the best colour is usually just out from stumble on the way in - I can tell the difference in running between about 9 and 1200 revs, but after that any difference is too small to detect, particularly if you have worked out how the gearbox works and like to keep the motor spinning 500 revs either side of peak torque.
12-13-2012, 01:57 PM
#59 | |
because I can
Oddometer: 6,066
12-13-2012, 05:20 PM
#60 | |
because I can
Oddometer: 6,066
