Old 12-13-2012, 06:36 PM   #11
Steve G.
Steve G.'s Avatar
Oddometer: 6,687
Originally Posted by photomd View Post
If you're looking for a switched lead, jumper off the running light in the back. FWIW, I have a relay under the tank that provides current to my heated grips. This way the grips turn off/on with the key. I soldered a wire to the running light in the back as a source. My R/R is connected to the wire coming from the tail light: works great.
I've had the enduralast system on my airhead since 06 or 07. I thought it was straight forward to install, but did have some "learning experiences". Mine had to do with the connections. I was having a weak charge under load. I found my R/R had a diode out, but as I worked through the system, I found the connectors that came with the system were loose. I pulled all those connectors and soldered everything with shrink wrap. It's been good since. As a result, I don't trust those threaded connectors.
Thanks for that. I don't have alot of experience with the posi-lock connectors, souldering is always better.
Steve G. is offline   Reply With Quote
Times are GMT -7.   It's 12:09 PM.
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
