Old 12-10-2012, 10:25 AM   #1
skidxr OP
Excuses
skidxr's Avatar
Oddometer: 388
Is this normal?
Hey all.. I'm experiencing what sounds like the cam chain rattling on my 2007 990 ADV. 17K miles. Fresh oil change. Valves are due to be checked. Sounds like a machine gun... BB gun machine gun that is.
I hear this if starting off in first gear with low RPM's. If I rev it and slip the clutch more than usual it does not happen. I have always thought this was the drive chain slapping but now I'm not sure and think it may be the cam chain.
I have read a few post's on this but it seems guys are hearing this at cold start-up. I hear it very briefly when starting the bike, always have. I can't hear it at any other time in any gear unless I find myself lugging it. Yes I know you are not supposed to lug it but sometimes it happens that way. The bike runs perfect other than this rattle. Could the tensioner be worn out for the cam chain? There is no evidence of water in the oil via inspecting the filter. I run 20 - 50 Mobile One oil.
HELP !!! Is it going to blow?
skidxr is offline   Reply With Quote
Old 12-10-2012, 11:37 AM   #2
Bugman98
Oddometer: 206
Isn't the 20-50 vis oil a little heavy? If you hear this after start up its probably due to the fact that the cam chain tensioners aren't "pumping up" with oil fast enough. A lighter weight oil might solve this problem. I had this issue with my 950 and it got worse until I was hearing the rattle sound when at idle and the engine was warm. I did a lot of research and all signs pointed to a worn oil pump piston which was only barely able to maintain oil pressure at idle. I replaced it and the problem went away immediately! And this was at 33K mi.
Bugman
Norman, OK
Wind in my hair, bugs in my teeth!
Bugman98 is offline   Reply With Quote
Old 12-10-2012, 11:16 PM   #3
skidxr OP
Excuses
skidxr's Avatar
Oddometer: 388
I thought 20 - 50 was what the manual called for. I just went and read it again. 10 - 50 . oops.. Think that could be it huh?
Old 12-13-2012, 05:32 PM   #4
skidxr OP
Excuses
skidxr's Avatar
Oddometer: 388
Does anyone have any other thoughts on this? I swapped out the oil with 10-50 but it didn't make any difference.
Thanks...
Old 12-13-2012, 06:28 PM   #5
zeegman
zeegman's Avatar
Oddometer: 375
Put bike on center stand and listen close
Thanks...
Put bike on center stand and have somebody start it and listen around the bike close up.
Put it in gear, run the engine and listen close up.
You should find the source of the noise pretty easy this way.
Most have a somewhat loose drive chain which it should be, and noise will result especially if lugging.
MZ
zeegman is offline   Reply With Quote
Old 12-13-2012, 07:47 PM   #6
BigNastybrp
Big Nasty
BigNastybrp's Avatar
Oddometer: 678
MZ
good info. use a long screw driver put your ear to it and move it a round till you find it.
XR650 parts for sale. http://www.advrider.com/forums/showthread.php?t=1038286
BigNastybrp is offline   Reply With Quote
Old 12-14-2012, 02:14 PM   #7
Steveman
Steveman's Avatar
Oddometer: 471
Which does not surprise me a bit, seen the thread too late otherwise had warned you not to waste money on the oil change...
Steveman is offline   Reply With Quote
Times are GMT -7.   It's 07:57 AM.
