Old 12-12-2012, 04:06 AM   #346
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,329
Well maybe it will be a loud christmas this year. I´ve found out that i may need a part(no shit).
All these faults about my immobiliser isn´t activated is possibly because of my lack of depth knowledge. I was surfing the ebay for parts and struck upon this:
I looked at the picture and was aware that the part in the top left corner with the grey wiring wasn´t in my bag. hmmm
Further investigation would tell me that it was the part nr 14 6111102000 Starter interlock(antenna).
This could my remedy for a real christmas.
Part is ordered and time to wait.
Mikael
KTM 950(1190) Adv-s, Soon to be Project 1190
KTM 530 EXC-R 08
LocuL is online now   Reply With Quote
Old 12-12-2012, 03:26 PM   #347
jimmibanke
jimmibanke's Avatar
Oddometer: 102
Uhlala sounds promising i'll stik my ears out the window and wait for the WROOOOOOMM from your garage
jimmibanke is offline   Reply With Quote
Old 12-12-2012, 06:08 PM   #348
sakurama
on an endless build
sakurama's Avatar
Oddometer: 1,486
Fingers crossed for you.
sakurama is offline   Reply With Quote
Old 12-13-2012, 03:31 AM   #349
StevenD
Hmmmm, dirt!
StevenD's Avatar
Oddometer: 1,143
thats not an antanna! thats the starter interlock box, it connects to stuff like the clutch and sidestand switch and desides if it's safe to start etc. I have 1 or 2 working units left over if you can cancell the ordered part still. will go for peanuts if your interrested!
Make sure that you have the right contact lock and the key antenna ring that fits around the lock though! you need that to communicate with your digital key's.
999 LC8 Rat-Rally custom - 500 EXC - XR666R '85
StevenD is offline   Reply With Quote
Old 12-13-2012, 05:48 AM   #350
roookie1
Oddometer: 117
Yep, me too
roookie1 is offline   Reply With Quote
Old 12-13-2012, 01:19 PM   #351
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,329
And i agree 100% but i didn´t knew that it was a part of this machine. But sound liable and thanks for the offer but patience weren´t my strong side when i found the (maybe) holy grail.
It should be the right ignition lock and keys, all the parts were bought together from new(ouch $).
I do not remember when i said that the bike had flashed me with the MAP sensor fault. But it has and i got my head out of my ass and found out that this engine don´t run 2 MAP sensor. I´ve always thought that a twin had 2 MAP sensors. But hey, I had a closer look in the parts manual and it showed that they only were sold 3 at a time...hmmm. I had one lying around, it fitted one of the empty plugs.
I went for the tune ECU to tell me if the ECU had the same thoughts.
After resetting error codes.
Ahhhh. I´m a mastermind. Or like the old danish saying: Fuck yeah.
Away with SAI and O2 since its scrapped anyway.
Well if i´m lucky and Murphy let me go(which he don´t). I should have a good chance of a running engine when the starter interlock arrives. Though an engine needs fuel...so made op this test configuration.
And yes i still have second thoughts about running the facet at that place and even thinking about going for the 990 EFI fuel pump. Those damn smart safaritanks tugs it away in the tank. But i´m not aware how faulty that is and that is the 990 efi fuel pump. I assume its mitshubishi again. I can always run the Facet as an replacement.
Next stop was my exhaust from the rear cylinder. The unbreakable sidestand relocater is in the way for routing my exhaust through the swingarm hole and out to the right side.
What would you guys think regarding strength, if i cut away the right part. It seems sturdy. I could reinforce the left one for the extra capacity. Give me your thoughts.
For the Danes:
Jimmi og Paw. Hvis det her pis dur, så bliver det sindsygt. I kigger jo bare forbi hvis i vil. Der er kolde bajer i værkstedet...eller alt er fanme koldt derude.
One last thing. The bike is jacked up but no more than only keeping balance. Rear tire is beyond done. Still...
Thanks. :fr eaky
out
KTM 530 EXC-R 08
Old 12-13-2012, 03:21 PM   #352
sakurama
on an endless build
sakurama's Avatar
Oddometer: 1,486
Dude! I can't wait for this thing to run!!!
G
Old 12-13-2012, 05:20 PM   #353
brents347
Trusting my Cape...
brents347's Avatar
Oddometer: 3,804
Wow. 102 cm is a 40" seat height. My 660 rally and 04 'S' 950 had about a 36" seat height (91 cm). I hope you're tall!!!!!
07 Yamaha R6
07 KTM 950 Super Enduro
04 KTM 250exc- plated two-stroke
01 Kawasaki KE100
74 Honda MR50
brents347 is offline   Reply With Quote
Old 12-13-2012, 08:05 PM   #354
Katoom119
Mmmm....Orange Kool-aid
Katoom119's Avatar
Oddometer: 1,837
That fuel pump in that location has me worried. I don't know how much heat the headers put out but it'd be shitty if you were out riding it and the bike was engulfed in a fireball.
The fuel pump in the Safari tanks would be the way I'd go. Works well and gets the fuel pump away from a possible ignition source.
Those who dance are considered crazy by those who do not hear the music.
I am not the same having seen the moon shine on the other side of the world. - Radmacher
5 Cylinders vs. Moab..........My East Tennessee.........Internships may go to Hell and I will go to Alaska
Katoom119 is offline   Reply With Quote
Old 12-14-2012, 01:15 AM   #355
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,329
I completely understand your thoughts about the fuel pump location. Fireball is not my worries, but the vaporlock it can create. My old 950 had the fuel in the right tank boil once or twice. The front header goes right by. No matter what I still got eyes on this.
KTM 530 EXC-R 08
Old 12-14-2012, 07:38 PM   #356
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,120
Do you still have the FI pump in the system somewhere? I'm not sure if I understand what you're doing, but the facet won't provide enough pressure to get fuel atomized at the injectors, it only works as a transfer pump or to get fuel to carb float bowls.
Zak
ktm
old bmw
others
slackmeyer is online now   Reply With Quote
Old 12-15-2012, 04:14 AM   #357
StevenD
Hmmmm, dirt!
StevenD's Avatar
Oddometer: 1,143
Yeah, this looks a lot like a low pressure pump that will only work with a carburator. You will need a pump that puts out 3.5 Bar + and a pressure regulator that will keer a constant (high) pressure to the injector rail. Find an old broken 990 pump and replace the motor with a new, better one. Install a large intank filter sock on it and put the fine filter outside on the line. That way you'll never have to worry about the FI pump again.
Not a single FI fault!! That sure looks like a LOT of noise in your shop when the part arrives!!!
To bad for me, i was looking forward to some macadamians or cashew peanuts
Old 12-15-2012, 05:03 AM   #358
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,329
uhhh...you see problems before i get to them. Nice.
Hmm...maybe the pump from the RC8 would be enough, it may even fit the safaris.
Edit:
Just checked with the parts microfiche. They look very much the same 990 efi pump vs 1190 pump.
KTM 530 EXC-R 08
LocuL screwed with this post 12-15-2012 at 07:11 AM
Old 12-15-2012, 07:47 AM   #359
StevenD
Hmmmm, dirt!
StevenD's Avatar
Oddometer: 1,143
Yeah, if you have the 1190 pump, perfect! that fits right in your safary tanks. same pump as the 990's!
Old 12-15-2012, 09:33 AM   #360
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,329
Here is microfiche view.
990 efi
1190 RC8R
BUT sheees the price from new is insane...
4,600.00 SEK = 688.953 USD
wow. Ebay here we come.
KTM 530 EXC-R 08
Times are GMT -7.   It's 11:42 PM.
