Old 12-15-2012, 10:28 AM   #1
Irish John OP
Oddometer: 234
Transmission full of gas, DR125
My lovely girlfriend, left the vacum petcock on your DR125 in the prime position. As a result, the airbox and transmission filled up with gas...
It wasn't started in this condition, luckily, and I've drained the gas out of the engine. Anything else I need to do before refilling it with oil?
Irish John is offline   Reply With Quote
Old 12-15-2012, 10:48 AM   #2
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,863
Clean the carb so it doesn't happen again, the float needle has junk in it.
Old 12-15-2012, 10:49 AM   #3
stumpy-ktm
stumpy-ktm's Avatar
Oddometer: 76
hi , imho you have done everything right drain all gas and old oil out , refill with good oil , start that sucker right up , if its going to hydraulic and break ...it will do it quickly .... but it wont , it will be fine , now , go kiss your girlfriend and tell her its ok .....you love working on her bike ..
cheers
" lost a leg .....still riding "
2004 ktm 640 supermoto
stumpy-ktm is offline   Reply With Quote
Old 12-15-2012, 01:49 PM   #4
Irish John OP
Oddometer: 234
Thanks everyone, my girlfriend says thanks as well.
Old 12-15-2012, 02:07 PM   #5
sieg
sieg's Avatar
Oddometer: 2,825
Remove the spark plug and crank it over in case the cylinder is full of gas. Suk petcocks are shit, had three of them do this in the run/on postion. Get a manual one from a Yamy TTR, fits right on and works as long as you remember to turn it off.
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote" Ben Franklin
Current bikes F800GS-EXCF350-Versys-690R-RZ350
sieg is offline   Reply With Quote
Old 12-15-2012, 06:31 PM   #6
ping
Oddometer: 184
After you drain the engine oil , leave the oil drain bolt off and I would pour in oil to remove any hidden gas,
ping is offline   Reply With Quote
Old 12-15-2012, 06:57 PM   #7
Tosh Togo
Oddometer: 1,594
That's not necessary... as long as the OP got a decent drain on the contaminated oil (which drained better than normal due to its' dilution), the first time it runs long enough to get fully warmed up, what little gas might be remaining will evaporate and go out the breather pipe.
Tosh Togo is offline   Reply With Quote
Times are GMT -7.   It's 02:45 AM.
