Old 12-15-2012, 10:33 AM   #1
deguoren OP
该出手时就出手
deguoren's Avatar
Oddometer: 161
new tire coming up Karoo 3
I am a big fan of the Heidenau tyres, but always open for something even better.
Just stumbled across a new model from Metzeler, available next spring
The Karoo 3
Apparently it has been presented on the EICMA. It will replace the MCE Karoo and the MCE Karoo (T)
Do what you love, and do it often. If you donít like something, change it. If you donít like your job, quit. Travel often; getting lost will help you find yourself. Some opportunities only come once; seize them. Life is about the people you meet and the things you create with them, so go out and start creating. Live your dream, and wear your passion. Life is short."
deguoren is offline   Reply With Quote
Old 12-15-2012, 01:45 PM   #2
Camel ADV
aka Oso Blanco
Camel ADV's Avatar
Oddometer: 1,483
Will be interesting hearing some real world feed back on these. The thread designs looks like it wouldn't offer much for lateral traction off the pavement.
Camel Tank auxiliary fuel tank for F series BMW twins. www.Camel-ADV.com
AT-BZ-CA-CN-CO-CR-CZ-CH-FR-DE-GB-GT-HN-IE-JP-KZ-KR-LI-LU-MX-NL-NI-PL-RU-SV-UA-US
'09 BMW F800GS, '14 KTM 1190 ADV-R
Camel ADV is offline   Reply With Quote
Old 12-15-2012, 04:14 PM   #3
4TooMany
4TooMany's Avatar
Oddometer: 321
I'm thinking the same thing. It's a strange design in that it doesn't have much of a center "strip" to make it quiet on the road yet it also doesn't have a very aggressive tread laterally to make it good off road. It appears to be the opposite of what I think makes a good dual-sport tire.
MSF RiderCoach
2012 BMW F800GS Trophy
2011 Suzuki DRZ-400S
4TooMany is offline   Reply With Quote
Old 12-15-2012, 11:44 PM   #4
Bayner
Oddometer: 1,602
The Karoo 2 was a good tire, let's hope they didn't screw up another good knobby just to make a show piece.
Bayner is offline   Reply With Quote
Old 12-21-2012, 12:10 PM   #5
X1Glider
X1Glider's Avatar
Oddometer: 600
Sorry, but they did.
Bob Krzeszkiewicz - 2013 Christini 450E - 2011 Kawasaki Ninja 1000 - 2000 Harley Davidson FXDX - 1999 Buell X1
X1Glider is offline   Reply With Quote
Old 12-21-2012, 12:34 PM   #6
BcDano
One Lucky Dude
BcDano's Avatar
Oddometer: 324
Hmm
Love the larger lugs, but would have to agree with the strange design comment. Cornering in the loose stuff looks like it could be very tricky with this design. Good luck to all the initial test pilots, I look forward to their reviews.
BcDano is offline   Reply With Quote
Old 12-21-2012, 04:55 PM   #7
Midnullarbor
Oddometer: 332
The new Karoo-3's rear tread is looking a good compromise for on-off road purposes . . . even the loose stuff, IMO (for a heavy bike).
The front, however, seems a bit more on-road biased.
For all-round riding, it looks fine for loamy surfaces [at moderate pace] and of course for bitumen ~ where the higher grip for braking is a big safety factor.
The front tread blocks look rather broad for those endless miles of loose-ball-bearing gravelly roads . . . but that's the compromise. A TKC or Heidi is always there as an alternative, on the front. Unless a more open Karoo-4 is in the pipeline !
Midnullarbor is offline   Reply With Quote
Old 12-21-2012, 09:19 PM   #8
Mr B
Mr B's Avatar
Oddometer: 504
I ran an bunch of other tires, loved the Karoo off road but forget it on the road at anything above 50 mph, squirmy !!! T me anyway.
I rode a set of those Heidenau's but as soon as the area got sloppy, they don't do much.. Put a set of good ole YKC 80's on and I am much happier !!!!
"For once you have tasted flight you will walk the earth with your eyes turned skywards, for there you have been and there you will long to return."
Leonardo da Vinci[/FONT]
Mr B is offline   Reply With Quote
Old 12-22-2012, 04:37 AM   #9
Angryrican
know nothing all
Angryrican's Avatar
Oddometer: 286
Looks like a slightly tweaked and beefed up version of the Metzeler Sahara tire which was an excellent all a rounder and did really well in sandy conditions. This looks like it will be an excellent dual purpose tire for a big bike like the R1200Gs and even an F800GS loaded up.
Angryrican is offline   Reply With Quote
Old 12-22-2012, 05:20 AM   #10
deguoren OP
该出手时就出手
deguoren's Avatar
Oddometer: 161
The reason I find this tyre attractive is the fact that it does not come with a center strip.
I need a good road tyre, because its a lot of miles before the dirt starts and the Heidi does it great.
But I think offroad the Heidi would be even better without the center strip.
If the 150 Heidenau tyre would be available with the same pattern as the 130 I would go that route.....
Old 12-22-2012, 08:39 AM   #11
Casejeep
Casejeep's Avatar
Oddometer: 736
Yeah my big problem with the k60 is that it had the center stripe, this one i like! i will get this rear tire.
MY F800 GS Build
Casejeep is offline   Reply With Quote
Old 12-22-2012, 08:50 AM   #12
ebrabaek
Oddometer: 4,763
Only reason I chose the K60, is that on the 18 inch version the pattern is different than on the 17 inch. 18 has half the center stripe, and it only contacts after 80% wear..... I like it a lot.
Erling
Old 12-22-2012, 02:07 PM   #13
biodieselandon
biodieselandon's Avatar
Oddometer: 358
Looks damn good
2013 BMW F800GS, Cordoba Blue, ASC, ESA, ABS
2012 BMW G650GS - 13,000 miles ***SOLD***
"If you're not mixing gas, you're not hauling ass!"
"A clean GS is a dirty shame."
biodieselandon is offline   Reply With Quote
Old 12-24-2012, 03:22 AM   #14
Snowy
Oddometer: 1,838
I wouldn't be so quick to dismiss these.
The rear looks promising.
The front, I think would work fine on most gravel surfaces.
One thing I've noticed in swapping between full knobbies and semi bar tread adventure tyres is that on gravel roads, and hardpacked base with shallow loose surface, the more road oriented tyres work better. Full knobbies work when you're in soft loamy dirt, loose rocks, or in mud. But on hard pack with a dusting of gravel they skate and float around like a bastard.
I rode some trails a week ago with a front Pirelli Mt90At, which I really like as an all round tyre, and then again this weekend with a Scorpion Rally front. I have a Scorpion Rally rear on at the moment.
Until the thunderstorm made everything greasy and sticky, the knobbie was losing. It works best in the pure off road/no road environment. The MT90At works better everywhere else. Wet dirt, the knobbie rules.
This Metzeler is more open than the MT90AT, but less open than the Rally. I think it could work well for me.
Snowy is offline   Reply With Quote
Old 12-26-2012, 06:37 PM   #15
toowheels
on a mission...
toowheels's Avatar
Oddometer: 966
Yes it's an interesting tread design!
I'm curious to see what kind of lifespan they'll have with the rubber compounds they're using and what the pricing is going to be like. I'm sure they've done some homework on them. As a front I'm a little less sure but we'll see...
After using the K60 (140) without the centre strip and then with (I stick to the 140 since it has less of a centre strip and some side cuts where the 150 doesn't) I'm not all that big a fan anymore even after cutting some of the centre strip out.
I'm on to the Mitas E-07 rear and E-10 front now. They'll be installed next week.
I'll report back on one of the tire threads...
Dave
Moto Overland [MOD] -Skid Plates, Top racks, Tool Boxes etc for Adventure bikes
www.motooverland.com
toowheels is offline   Reply With Quote
Times are GMT -7.   It's 03:33 PM.
