Old 12-16-2012, 10:37 AM   #136
Nailhead
Free at last!
Nailhead's Avatar
Oddometer: 6,226
Originally Posted by Motornoggin View Post
As does Dodge, Ford, Toyota, Nissan, Mitsubishi, Isuzu, Jeep, or anything else with a Dana, Eaton, or corporate semi-floating axle. It's worked well for over 100 years in many iterations...
That may well be, but it still doesn't make an abundance of sense to me given that axle shafts aren't made of bearing steel.
This S10 is the first vehicle I've owned with a C-clip axle, so they're new to me.
As for the bearing arrangement, what works works, I guess.
-Chris
'7? Benelli 650S, '80 BMW R100 RS, '93 Ducati 900 SS, '07 KTM 990 Adventure
Nailhead is offline   Reply With Quote
Old 12-16-2012, 11:45 AM   #137
nofate
what blackflies?
nofate's Avatar
Oddometer: 2,841
Originally Posted by G-Mac View Post
Use to own GM then turned to Ford. Much better bang for the buck. Now with Honda, couldn't be happier. Ridgelines rock. Everyone thinks they need a truck for that once or twice a year they haul drywall or plywood. Buy a Honda get reliability comfort and the truck you will need. I have many many times hauled more than 1000kilos in my truck trailer combo and it did it with out a blink of an eye. This is all the truck most people need. Very underrated.
Cheers
Ridgelines aren't considered trucks in northern Ontario. In my town there are more pickup trucks than cars and I haven't seen a single Ridgeline except for the odd summer tourist.
Rick, Chapleau, ON
Triumph Scrambler 900
Honda Trail CT90
Flying with Rick float plane video: http://www.youtube.com/watch?v=g6my0FM9F_Q
nofate is offline   Reply With Quote
Old 12-16-2012, 11:50 AM   #138
TooFast
TooFast's Avatar
Oddometer: 1,257
[QUOTE=Nailhead;20262139]That may well be, but it still doesn't make an abundance of sense to me given that axle shafts aren't made of bearing steel.
Not that I like it, look how many bike/car/truck motors spin their overhead cams directly on their aluminum heads - no bearings other than an oil film...
always wondered about dry starts after oil changes, running low on oil, etc
TooFast is offline   Reply With Quote
Old 12-16-2012, 12:24 PM   #139
RED CAT
Bumpy Backroader
RED CAT's Avatar
Oddometer: 2,985
Used Vehicles!
Ever notice how the high end vehicles always seem in better condition than the plain janes. Reason for that is the person who can afford the higher end vehicle to start with can usually afford to get it serviced regularly. The plain janers tend to be more neglected, mostly by women. Can I say that? When you see an ad for a used car and it says, woman owner, run. 90% of the time it hasn't even had the oil changed. There are exceptions of course. Try to buy new if you can. Take care of them and they should all last a while.
RED CAT is offline   Reply With Quote
Old 12-16-2012, 04:36 PM   #140
Nailhead
Free at last!
Nailhead's Avatar
Oddometer: 6,226
[QUOTE=TooFast;20262577]
A pressurized oil film, remember-- those cams aren't (shouldn't be) actually touching the metal of the bearing itself.
That axle shaft is subject to an unpressurized "catch-as-catch-can" splash oiling system in contrast.
Not a big confidence builder given what'll happen if that bearing fails.
-Chris
Old 12-16-2012, 04:46 PM   #141
troidus
Oddometer: 15,410
[QUOTE=Nailhead;20264461]
I've read that if you change diff oil after the first hundred miles that you'll double its life. This was some time ago; the rationale was that the first hundred miles would scrub off any remaining grit from machining and suspend it in the oil.
troidus is offline   Reply With Quote
Old 12-16-2012, 06:28 PM   #142
green hell
yawning or snarling
green hell's Avatar
Oddometer: 19,967
i don't recall the steel, but the bearing end of the shafts were induction hardened after machining. (also don't remember the customer or if there were any finishing operations. )
lookin' for a place to happen;
makin' stops along the way - the tragically hip
needless dickery
green hell is offline   Reply With Quote
Old 12-16-2012, 07:09 PM   #143
fullmonte
Reformed Kneedragger
fullmonte's Avatar
Oddometer: 5,373
Thanks to people like you, I have saved many tens of thousands over the last 20 years in depreciation costs. I pay cash and buy used (non euro)cars in good condition. I usually drive them until 150K miles.
"If you are looking for the typical ride to a restaurant, eat tacos, hold the middle finger over the food, stop and take a picture of a gravel road type ride, you probably won't be interested." - dlrides
"A guy I know was the lead researcher for the University of Utah federally funded study of cellphone and texting use while driving. He found that your twice as dangerous as a drunk while using your cell phone and I think it was up to six times worse if the driver was texting."-dakardad
fullmonte is offline   Reply With Quote
Old 12-16-2012, 08:02 PM   #144
koncha
Oddometer: 10,044
You're welcome to my ass-gas infused seats. Well worth the depreciation.
koncha is offline   Reply With Quote
Old 12-16-2012, 08:21 PM   #145
Motornoggin
Two-Bit Throttle Bum
Motornoggin's Avatar
Oddometer: 21,203
Actually, they are made from tool steel (many, many different varieties of treatable steel), hardened, then precision ground, just like a bearing.
O.K. Joke's over. You can bring back the constitution now. Please.
My Wyoming has an East infection.
http://motornoggin.smugmug.com
Motornoggin is offline   Reply With Quote
Old 12-16-2012, 09:14 PM   #146
Bun-bun
Bun-bun's Avatar
Oddometer: 625
Here's one for the books, my 2004 Buick Rendezvous transmission speed sensor failed, causing the transmission computer to perform hard shifts, which broke the transmission output ring gear, which chipped the planetary gear assembly, and the sun gear on the transfer case. Because of a failed $20 sensor, I now need a new transmission computer, transmission, and transfer case.
Oh, and all of you with GM AWD cars from the early oughts remember: Your rear diff fluid needs to be changed every 50k miles. It take 2 quarts. GM sells the diff fluid at their dealers for $50 per quart. OEHQ.com sells it for half of that, but that is still felony robbery for a quart of fluid that won't get you drunk.
2002 Ducati ST4s - Grey Mouser
1965 Honda Super 90 - project
2002 Ducati Monster - Duc l'orange - sold
1985 Honda XL600R - sold
Bun-bun is offline   Reply With Quote
Old 12-17-2012, 12:53 PM   #147
mark883
Holding up Michoagán
Oddometer: 1,612
Hmm. Maybe that explains why BMW buys their X3 transmissions from GM.
mark883 is offline   Reply With Quote
Old 12-17-2012, 02:28 PM   #148
RedRocket
Yeah! I want Cheesy Poofs
RedRocket's Avatar
Oddometer: 20,144
You should feel worse about admitting to owning a Rendezvous .
RedRocket is offline   Reply With Quote
Old 12-17-2012, 03:03 PM   #149
Bueller
Cashin?
Bueller's Avatar
Oddometer: 17,311
What he feels worst about is the fact that he kept driving with the failed speed sensor and hard shifts, which is the reason the gear damage occurred.
"Bueller, you're an island of sense in a sea of bullshit" - swimmer
"bueller, you ARE an island of reason in a sea of bullshit" - quasigentrified
Bueller is offline   Reply With Quote
Old 12-17-2012, 05:40 PM   #150
Bricen18
Oddometer: 148
How many of you have experienced the leaky crimp fittings on the oil and tranny cooler supply and return lines. For example 05 Chevy truck (oil) 06 Chevy 2500 (oil) Pontiac grand Prix (tranny).
grand Prix had tranny replaced under warranty under 60K miles WTF
Chevy wheel bearing design is garbage as well.
Bricen18 is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 02:46 AM.
