12-17-2012, 10:41 AM
#46 |
Oddometer: 825
Christmas bump.
Perfect time to try out a great 4 season pant, works excellent for both winter and summer riding. The full nylon shell makes the pant virtually windproof for colder riding, but the 4 large vents flow huge amounts of air for summer riding. Colorado Pant at Dubinky.com ![]() ![]()
Dubinky.com Enduro, Trail, Dual-Sport and Adventure Riding Apparel. Westfest 2013 Canyonlands Adventure Ride COXR650L screwed with this post 12-17-2012 at 11:03 AM |
12-17-2012, 06:12 PM
#47 |
after a good ride
Oddometer: 14,331
big thanks ben
ben, i just read on the 2013 noobs death valley rally that you are donating a pair of pants and jerseys.
i personally want to thank you for your support and conteacher for contacting you. few weeks ago, dave (dsm8) had mentioned to check out your pants. i did just too busy prepping for the holidays and a big ride this month. would love to buy a pair and wear it on my trip to baja after xmas. will go to you website, and hope i can get one by the 24th. cheers. joel |
12-17-2012, 07:24 PM
#48 | |
Oddometer: 825
just got the order, thanks They will ship out USPS priority tomorrow morning and I dont see any reason you should not get them by friday of this week. The stuff for the rally is going out tomorrow also, wish I could make it. I was reading the thread today and it looks like a good time. If you guys want to see some of Colorado check out this years Westfest ![]() Thanks again and have a good time in baja ![]() Ben
Dubinky.com Enduro, Trail, Dual-Sport and Adventure Riding Apparel. Westfest 2013 Canyonlands Adventure Ride |
12-17-2012, 08:45 PM
#49 |
Adventourist
I had been keeping an eye on this thread (and the gear) before it was mentioned in the DV Rally connection. Now I'm definitely gonna have to pick something up
I just finished shopping for Christmas, but I will place an order before the rally in March. Ditto what Joel said, thanks a lot for your support of the rally |
12-18-2012, 07:37 AM
#50 | |
Oddometer: 825
Have fun and thanks for the interest. ben
12-19-2012, 07:22 PM
#51 |
Oddometer: 190
Not sure if this was covered, but any plans for a waterproof version or ideas on making these water resistant?
thanks wizz
"These things are like intellectual viruses loose in the theater of discourse, and you can’t really argue with these people, because they don’t understand the rules of argument," also noting that "the howling tide of unreason beats against pure fact with incredible fury." Terence Mckenna 2006 Ducati Multistrada620, 2013 KTM 350 exc-f |
12-19-2012, 10:02 PM
#52 | |
Oddometer: 825
Hey Wizz, Yes eventually Right now the Colorado Pant is water resistant, but how well they work really depends on your needs, expectations and what your definition of water resistant is. So a little background on waterproof clothing first........ There is a big difference between "waterproof" and "waterproof/breathable" (WB). Almost all MC apparel that is waterproof/ breathable is made using some kind of speciality coating or membrane on the back of a normal nylon fabric. This coating has small pores that allow air particles to escape, hence the "breathable", yet are small enough to keep water out. The thing you need to really look at and weigh when choosing WB clothing is that almost all apparel on the market uses a lighter WB fabric then a comparable non-waterproof breathable garment, so the durability and crash protection, etc are decreased. (Some don't even use nylon, they are using a polyester shell which should be avoided at all costs for MC use. ) For example the vast majority, if not all, WB garments are made out of 500d nylon, where as the non waterproof versions are using 840d or 1Kd nylon. It is something to keep in mind when shopping around and if it is going to be abused routinely it may be better to look at a non water proof product and getting a little wet from time to time. If you dont plan on hitting the ground much it wont matter though![]() Having that in mind I said the Colorado Pant was water resistant, so let me explain why that is. Just about any nylon fabric comes with something called a Durable Water Repellant Finish (DWR) on the back of the fabric. This is a polyurethane coating that is applied to the fabric at the mill, the primary purpose being that it makes the fabric very resistant to unraveling from tears, cuts etc, thus the name durable. However it also has a convenient side effect of making the fabric basically water proof. For all reasonable purposes any fabric with a DWR coating is waterproof, however do not confuse it with being brethable, it is basically air tight also , if it were not for the natural minuet air flow created by the sewing process.Any garment that is made of all nylon with a DWR coating is waterproof, but it becomes water resistant when you sew the pieces together and the water actually leaks in from the needle holes. This is why truly waterproof gear uses "taped" seams to ensure all the holes from sewing are covered. This additional step in the manufacturing process also contributes to the higher cost for WB gear. In a long winded story the short answer to your question is this equates to the Colorado Pant being water resistant because it uses a shell made of 100% DWR 840 and 1680 nylon, there are no stretch panels, no mesh panels, or anything else that will let the water in besides the sewing holes. As a result the Colorado Pants can get much more water on them before they leak compared to other pants on the market, but I cannot give any kind of quantitative statement as to how long you can stay dry In full disclosure and based on lost of miles in the pants, the majority of your body will stay dry for quite awhile, but the first thing to get wet will be your crotch. This is because of the all the seams and needle holes in the crotch area and the fact water tends to pool there naturally. Sorry that was not a direct answer, but hopefully if gives you enough information to have an educated idea of what the pants will do and why I say they are water resistant. Let me know if that was totally confusing, or you have any other questions, always more than happy to help. Ben
Dubinky.com Enduro, Trail, Dual-Sport and Adventure Riding Apparel. Westfest 2013 Canyonlands Adventure Ride COXR650L screwed with this post 12-19-2012 at 10:08 PM |
12-19-2012, 10:40 PM
#53 |
Oddometer: 190
Very informative, thanks. I'm looking for an off road pant that is truly protective enough for the street, which these appear to be. I'm 6'2 195 which puts me at a measured 32-33 inch seem and 34-35 waist. I reckon that leaves me waiting for a tall size?
12-20-2012, 06:41 AM
#54 | |
Oddometer: 825
At 6'2" (and I think you mentioned you like them a little long) I would recommend waiting a few months for the tall versions. I will try and remember to send you a PM when I get the new stuff, but if I forget check the thread for updates around the end of February. Thanks for the interest, Ben
12-20-2012, 10:11 AM
#55 |
Oddometer: 427
I hope your (talls) will be TALL, I need a 36" at least. bete. PS: love the look of these.
12-20-2012, 04:03 PM
#56 | |
Oddometer: 825
The Tall Medium will be about a 35in inseam (measured). Keep in mind if you wear a 36 jean your actual inseam if you measure it is probably 34-35in. Ben
12-21-2012, 06:41 AM
#57 |
Oddometer: 825
Why Dubinky??
I touched on this briefly on the first post, but wanted to go into depth a little more on why this company is named Dubinky.
First what is Dubinky: Dubinky is named after Dubinky Wells in The name was adapted to the area (as I have been told) when years ago two brothers, Red and Dubinky Anderson, were camping in the area and Dubinky got lost. He was eventually found and the name Dubinky began to stick. So why name a Company after Dubinky Wells: Dubinky is to Enduro Motorcycle Riders as Not only are the trails amazing, but so is the environment, in a half day you can ride in a slot canyon with running water, blast through sand dunes, see old mining equipment, hit miles of whoops, ride single track for hours on end, ride some of the best slick rock trails around, or work your ass off getting up the most technical single track in the area. During all this you will probably never see another person. This is the draw to name my company after Dubinky Wells, not only is it one of the most unique words I have ever heard, but for those that have ridden in the Dubinky area it truly is an epic place for riding a motorcycle. Here are some videos that help illustrate the kind of riding in the Dubinky area. Most I got from inmate RideFreak’s Youtube channel as well as some other various videos (most of my Gro Pro videos show a great view of the front fender but not much else). Dead Cow: The Tubes: Brians Trail: Enduro Loop: Marys Trail: White Wash Dunes This is just a few of the awesome trails in the area. I hope it gives people an idea of why Dubinky is such an amazing and unique place for riding and why it is a perfect name for a MC apparel company.
Dubinky.com Enduro, Trail, Dual-Sport and Adventure Riding Apparel. Westfest 2013 Canyonlands Adventure Ride COXR650L screwed with this post 12-21-2012 at 08:34 AM |
12-22-2012, 10:26 PM
#58 | |
after a good ride
Oddometer: 14,331
nice vids.... ![]() just added it to my places to ride. i received the pants today.....awesome quality and built! |
12-27-2012, 10:05 PM
#59 |
Oddometer: 825
I have two pairs of pants that need to get sold so someone can get a good deal, one is a slightly used Large (worn maybe one time) and the other is a early production sample.
Used Large $125 Shipped: This pair was exchanged for a medium after it was worn, it looks like maybe one time. There are two slight blemishes so I need to sell it as used. On one of the inner leg leathers there is a slight color transfer, it looks like from a frame rail, that could probably be wiped off in all reality. Then on the knee there is a small scuff or abrasion. Otherwise the pants are in perfect condition and would pass as brand new. ![]() ![]() Large Prototype $90 Shipped The pants are a size Large (39.5-37in waist) and were a sewn sample from the manufacture that is making the current Colorado Pant. This pair is brand new, never worn, and identical to the current pant with the exception of: -No logos or embroidery anywhere on the pant. -2 seams on each thigh were only sewn with a single needle vs double needle on the current pant (the seam is still double stitched) -Fly zipper is plastic coil vs YKK metal -Leather on the inner legs is a "naked" leather and does not have the high oil content of the current pant. It will still hold up fine, but will show more signs of wear. -There may be a few faint chalk marks I missed wiping off..... ![]() ![]() ![]() ![]() ![]() Fit, function and performance are identical to the current pant. PM me to buy either pant, and paypal would work best. EDIT: These are sold. Thanks!! TheThanks, ben
Dubinky.com Enduro, Trail, Dual-Sport and Adventure Riding Apparel. Westfest 2013 Canyonlands Adventure Ride COXR650L screwed with this post 03-14-2013 at 08:08 PM |
01-07-2013, 03:45 PM
#60 |
Oddometer: 825
!!!WINTER SALE!!!
Colorado Pant and Colorado Jerseys are both on Sale ![]() $148 for the Colorado Pant ![]() $30 for the Colorado Jersey *Price on S/M Colorado Pant sizes only !!!WINTER SALE!!! DUBINKY.COM
