12-16-2012, 02:58 PM
#46 |
Oddometer: 101
Keep the great ride reports coming. It's winter now
in Canada so I need this as therapy. |
12-17-2012, 02:38 PM
#47 |
Bugger, lost again
Oddometer: 12
Tow a Tenere
As I was reading through all of this the first thought that came to my mind was, if you get truly bogged then you've got a big problem. One of the small things I like about the Tenere is the tow hook. Have you thought of adding a small hand winch to the bag. I've seen them advertised for use with the 1200 GS but haven't taken a great deal of notice other than that. Travelling into the areas you do on your own, might be an idea?
Ad augusta per angusta
The Friar screwed with this post 12-18-2012 at 01:47 PM |
12-18-2012, 05:29 AM
#48 |
Minimal2 the fulness
Oddometer: 65
having a blast of time through your report... did you see any native? if i recall correctly they were sadly terminated but probably you crossed with some of them
2008 Suzuki DR200SE 2008 Yamaha XTZ 125 2+1 months living in Oaxaca's sierras and beaches: http://motoviajero.com/foros/viewtopic.php?f=4&t=2695 |
12-18-2012, 05:50 PM
#49 | |
Oddometer: 469
I've been considering a hand winch of some form.... but the small light ones are damn expensive... Someone in the Tenere thread suggested using a ratchet strap, which is an affordable option... I "was" considering a decent ratchet strap with with the strap removed, then load it up with that light/strong Spectra rope/cable... The thing that's holding me back is thinking about the logistics of actually using a winch solo... Like, I cant hold the bike upright and operate a winch at the same time... Also the amount of line/rope needed to reach a good anchor point is probably more than what's practical to carry... I'm sure a winch would be good in some situations, but every time I've been stuck or nearly stuck there's a good chance a winch wouldn't have helped me... I'll probably procrastinate about it till I get stuck in a situation where a winch would help
*** Tasmania - Gods own adventure playground *** Tasmania on a Dominator .... Tasmania on a Tenere |
12-18-2012, 06:07 PM
#50 | |
Oddometer: 469
You can read about their demise here: http://en.wikipedia.org/wiki/Aboriginal_Tasmanians :)
12-18-2012, 06:16 PM
#51 |
Oddometer: 469
Thanks for the comments
I had another awesome ride yesterday so I better get the last weeks one written up so I don't fall too far behind
12-18-2012, 06:25 PM
#52 |
Oddometer: 1
Awesome pics and ride reports, keep them coming.
www.royalderwent.com |
12-18-2012, 08:37 PM
#53 |
Oddometer: 469
2012-12-06 Plenty-Spurs-Powerlines
Distance: 275km Route: The general plan was to head out through New Norfolk, through the Mt Lloyd pine forests to check out a couple of the minor tracks (that caught my eye on Google Earth), then poke around a stack of dead-end logging spurs to the west of Plenty Valley Rd (Lanes Link Rd?)... Most the spur tracks were unmapped so I did up a rough route on RidewithGPS so I didn't have to put too much thought into into it while riding: http://ridewithgps.com/routes/1971737 (I often make a messy route like that so I've got a rough idea of what tracks are worth a look... As usual, I didn't do 1/2 of what I had on the plan, better to have more than not enough) ![]() Heading down the eastern side of the Mt Lloyd forest: (34 to 60km on the route) ![]() Quite a few decent hills!, a lot of it is fairly challenging on a big bike: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Then out the southern end of Mt Lloyd back onto the fast gravel roads: ![]() ![]() A 10 mins video: It's a great area to ride.. but it's popular with dirt bike riders on weekends, so I only go through there on weekdays, less chance of running into anyone... To be continued... .. .
*** Tasmania - Gods own adventure playground *** Tasmania on a Dominator .... Tasmania on a Tenere FLICKIT screwed with this post 12-19-2012 at 03:33 AM |
12-18-2012, 10:42 PM
#54 |
Oddometer: 469
2012-12-06 Plenty-Spurs-Powerlines... Part 2
60km to 190km on the route was just poking around logging spur roads.. I only stopped a handful of times on this ride so I don't have many photos:
![]() ![]() ![]() ![]() ![]() Most the roads up here were good fast gravel: ![]() ![]() There was a surprising number of new roads around the place: ![]() Over to the next hill, much the same: ![]() A lot of the new roads were made from course crushed rock, not bad to ride on, but the front tyre flicked a lot of big chunks up into the bash-plate: ![]() ![]() ![]() Before this ride I replaced the rear brake pads, the new ones are very grabby, it doesn't take much pressure to lock the rear wheel, it makes emergency braking almost impossible... as I discovered... Coming back down out of this area I went a bit fast into a downhill corner, it was covered in loose gravel, I jumped on the brakes, locked the rear, released it and jumped on it again just as hard stalled the engine, and gave myself a bit of a scare... 1 min video of how NOT to do an emergency stop: (the other tyre tracks are mine from earlier in the day, I went poking around the side track) It doesn't look too dramatic on the video, but it was for me at the time It was the first scare I've had since I got back on the road last year, about 15,000km ago... to be Continued... .. .
12-19-2012, 01:45 AM
#55 | |
Bugger, lost again
Oddometer: 12
12-19-2012, 02:56 AM
#56 |
Oddometer: 469
2012-12-06 Plenty-Spurs-Powerlines... Part 3
I made my way back down to the logging haul road, it's like a gravel hwy, hard packed with not much loose gravel:
![]() Amazing how well the D606 tyres hang on: ![]() With a few detours, to explore some other spurs, I made my way around to the power lines behind Moogara... These 220,000 volt power lines carry the power from Gordon Dam (as seen earlier in this thread), to Hobart, about 100km... They basically run in a straight line with just a couple of slight turns.... A lot of the way along there's a service track so the poles and lines can be checked and maintained, where the ground's too mountainous there's at minimum a grotty track to each pole.... I rode along a short part of the lines a while back, and as an excuse to get out riding, I've planned to explore as many of the tracks as I can... I got onto the power line service track at around 196km on the route, it was good fun, some parts were just dirt, some were fist sized stones, some course crushed rock... I only went a couple of KM and my fun was ruined by a gate (at 198km)... So typical! ![]() Not to be beaten I backtracked and went around some forestry roads to get back onto the lines... (at around 205km on the route)... The view back towards Hobart: (it doesn't look to special in the screen shots, but it's actually quite stunning) ![]() I started heading along the lines, away from Hobart, but the track was a mess, and soon vanished: ![]() I made my way around on another track which ended up running along the lines for a couple of K's: ![]() The last part of the track was quite steep as it descended down to the last pole on the edge of a steep valley... 9 min video to the end of the lines: (as far as I could go along this section) Nice spot ![]() Back up the hill where I came from: ![]() A waratah: ( http://en.wikipedia.org/wiki/Waratah ) ![]() There's no tracks going down into the valley, but there's tracks over the other side: (accessible off Styx Rd) ... At the right you can see the power lines heading over the hills in the distance: ![]() I was a bit worried about the climb back up the hill due to the loose rock, but it turned out to be no issue: ![]() 3 min video climbing my way back out: The camera makes everything look flat, it was fairly steep... (at the time I thought it was very steep, but after what I did yesterday, I'll just call it "fairly" steep) ![]() I headed back the way I came, with a couple of short detours, and a trip down to the other side of the gate that blocked my way earlier... Then started heading the other way along the lines towards home.. I cant be bothered grabbing screenshots so you'll have to watch the video if you're interested... The track goes up and down a few hills, some steep, some not too bad, a good fun ride.. 7 min video heading towards Moogara: I stopped and turned back when I got to a fairly steep grassy gully, I couldn't really see the bottom, or the track on the other side, and as it was late in the day I didn't want to risk getting stuck down there... Figured I'd do the next section another day, after checking it out on Google Earth... Not long after I turned around I noticed there was a bit of a grassy strip of cleared land running out either side of the lines, a fire break I guess, trying to make up my mind if I should check it out or not, I paused too long, stalled, and dropped the bike ... Being on grass, I didn't make much effort to stay on my feet, I just went with it ![]() ![]() 90 sec video of a VERY noobie drop ![]() So that's it for now... Sorry about the lack of decent photos, I should start carrying my DSLR again, and spend a little more time on pics... I had a 400ish Km ride yesterday exploring the powerline tracks and others stuff further out towards Lake Pedder.... I'll look at getting some videos edited and uploaded over the next few days, then write it up... Thanks for reading :)
12-19-2012, 05:01 AM
#57 |
Oddometer: 2,291
I have enjoyed all of this thread, thanks for posting. You are most fortunate to live in a part of the world with such great riding areas.
A good friend will come and bail you out of jail...but a true friend will be sitting next to you saying........."Damn..We F*cked Up" - Anon. |
03-17-2013, 11:16 PM
#58 |
Oddometer: 469
I slacked off and let this thread go for a while, guess I better catch up... Another mod to start with:
I wasn't happy with the Yamaha alloy sump guard, it left too much of the engine exposed and I was getting a few dings in the cases, + it was getting bent from rocks catching on the slots... It seems it was made for looks not function, glad it came on the bike and I didn't pay for it! ![]() I got a B&B one... it covers a LOT more: ![]() ![]() $245 well spent IMO...
03-18-2013, 02:23 AM
#59 |
Oddometer: 469
A couple of BS posts to push this out to a new page for a new ride report
03-18-2013, 02:24 AM
#60 |
Oddometer: 469
My current Tassie Tracks:
