Old 11-11-2012, 07:10 PM   #346
slowpoke
slowpoke's Avatar
Oddometer: 103
Originally Posted by Motorfiets View Post
Donation to all those with the wp swap
So how can I get one?
slowpoke is offline   Reply With Quote
Old 11-13-2012, 11:37 PM   #347
Motorfiets OP
Motorfiets's Avatar
Location: North of Jack Daniel's, South of Country Music
Oddometer: 2,997
pm me your address
Motorfiets is offline   Reply With Quote
Old 11-14-2012, 02:06 PM   #348
Pomo
gonzo
Pomo's Avatar
Oddometer: 611
26000ish miles
top end rebuild aka new rings
You must be wringing the shit out of that thing!
Stubborn and Stupid
"It's supposed to be a challenge, that's why they call it a shortcut. If it was easy it would just be the way." ~ Rubin, Road Trip
Pomo is offline   Reply With Quote
Old 11-14-2012, 02:13 PM   #349
Motorfiets OP
Motorfiets's Avatar
Oddometer: 2,997
Something like that.... haha
Old 11-14-2012, 04:14 PM   #350
LukasM
Oddometer: 5,386
Don't believe a word Ben says, the biggest adventure that bike has seen is riding over the curb at the local Starbucks parking lot!
Old 11-14-2012, 06:25 PM   #351
Motorfiets OP
Motorfiets's Avatar
Oddometer: 2,997
starbucks is down the road
Old 11-14-2012, 06:59 PM   #352
Motorfiets OP
Motorfiets's Avatar
Oddometer: 2,997
Ok so with all the parts in I set off to work!
headed off to work to clean these up a bit
pistons cleaned up nicely and piston to cylinder wall clearance was PERFECT!! almost zero wear
enlisted the help of a friend
long story short here but the connecting rod bolts are all non reusable.... so a week or so went by with no update due to my busy school schedule, waiting on parts and with work....
in the meantime I decided to replace my R/R with a compufire
snip snip
bolts finally arrived and the motor went back together.... well.... almost...
a good eye will notice that I managed to reassembly the motor without the idler gear or starter gear.... no problem right? just slid the shaft out....
uh... nope... shaft is hammered into the block.... MOTHER F***ER!!!! so the decision was made to install the engine and bring the bike to work in the morning where we would pull the flywheel to install the gears...
so the motor was in and bike was headed to work in the morning...
so at work the 14mm flywheel bolt came off with no problem... no heat needed... the flywheel however... with a 1/2 inch impact running full max and the heat gun heating away the flywheel wouldnt budge! repeated attempts left us with a dilema.... what to do next?
after some careful thought we heated the pin for MAYBE 30 seconds.... and the pin slid right out like a hot knife through butter!
that evening which would be last night I had class but raced home straight afterwards went to work! no assembly pictures... sorry folks! but I was hyped up and was on a roll! basically from having just an engine in the frame I managed to completely assemble my bike from approx 7 pm all the way through to 2 am this morning.... long night!
here are just some pictures of the process
final picture...
Old 11-15-2012, 06:42 PM   #353
MTrider16
Ridin' in MT
MTrider16's Avatar
Oddometer: 1,674
final picture...
I must say, I like the look of the TT tank, high fender, and no beak. Nice job sir.
-David
'13 VFR1200D, '13 XVS950, '09 F800GS, 07 CRF250X
Riding roads in Montana - Big Sky Country
www.mtrider16.smugmug.com
Mountains, Moose, and Miles: a Montanan's Alcan Highway Story
Continental Divide and More: the "No Dust" Tour of WY and MT
MTrider16 is offline   Reply With Quote
Old 11-15-2012, 08:52 PM   #354
Motorfiets OP
Motorfiets's Avatar
Oddometer: 2,997
-David
thank you!!
Old 12-19-2012, 09:53 PM   #355
xpdishun
tarmac xplor
Oddometer: 4
Awesome bike mate! What's that crazy windscreen you have? And what are those supports in the back of the screen? I've seen a couple pictures of them but can't seem to see where you talk about it. I've tried looking through most of your posts to no avail.
http://www.advrider.com/forums/showp...postcount=6234
http://www.advrider.com/forums/showp...postcount=6226
Chris
xpdishun is offline   Reply With Quote
Old 12-20-2012, 08:20 AM   #356
xpdishun
tarmac xplor
Oddometer: 4
Love the bike Ben!
What is that awesome windscreen you use for commuting? I've seen it in a couple of your pictures but couldn't find in your threads where you mentioned it. Are those braces something that came with the screen? Where do they attach?
Chris
Old 12-20-2012, 08:30 AM   #357
Motorfiets OP
Motorfiets's Avatar
Oddometer: 2,997
Originally Posted by xpdishun View Post
Love the bike Ben!
it's just a simple bolt on el cheapo
mounts with some handlebar clamps
Ben
My Photo's
Old 12-20-2012, 09:02 AM   #358
xpdishun
tarmac xplor
Oddometer: 4
How are the clip type masterlinks working out for you? I saw on one of your pics you had two clip type master links two links aways from each other.
Chris
Old 12-20-2012, 09:06 AM   #359
Motorfiets OP
Motorfiets's Avatar
Oddometer: 2,997
they hold up just fine. I use them when I have my 47T "play gear" rear installed
Ben
My Photo's
Old 01-13-2013, 02:34 PM   #360
Motorfiets OP
Motorfiets's Avatar
Oddometer: 2,997
anyone care to give me an idea how much my bike is worth? I am thinking about selling it but just don't know what the damn thing would sell for?
Ben
My Photo's
Times are GMT -7.   It's 11:37 PM.
