Old 12-20-2012, 01:59 AM   #4081
Montauk
Oddometer: 260
As an engineer, when actual data is not available, you try to approximate as close as possible and leave some room for error. In this case I would find the difference in weight of current model 2012 GS/GSA using "dry", and do the same for "wet". Now you have 2 weights. Add 1-2 lbs for ABS (chime in guys if I am wrong in my ABS approximation). We are assuming that GSA gas tank will remain same as current. In the new, they might shave off 1-2 lbs using stronger and lighter plastics. This will cancel with weight added due to ABS. To approximate the wet weight of a new GSA, add the wet difference to new 2013 GS model. So there you have it. Similarly you could approximate dry weight backwards.
Montauk is offline   Reply With Quote
Old 12-20-2012, 02:14 AM   #4082
Montauk
Oddometer: 260
Originally Posted by GSMarc View Post
weight is one of the main variable for a bike, specially if you want to go in various environments.
Yes, but it becomes fixed variable, you can't decrease it but will only increase due to farkling etc. No matter which environment you go on the globe, it will remain static. Am I missing something here? Perhaps you are trying to figure out something that we don't know
Old 12-20-2012, 02:19 AM   #4083
GSMarc
GSMarc's Avatar
Oddometer: 723
main variable for making your choice to buy or not...
Why do you believe I have only HP2...
GSMarc from BELGIUM
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
2000 R1150GS (sold)
GSMarc is offline   Reply With Quote
Old 12-20-2012, 02:40 AM   #4084
Montauk
Oddometer: 260
Specific Gravity of gasoline (petrol) is 0.739 Kg/L multiply with 20L = 14.78 Kg (32.6 lbs) -> weight of gasoline in the GS.
1 US Gal gasoline = 1.629 lbs/L x 3.785 L/US Gal = 6.2 lbs.
Old 12-20-2012, 02:48 AM   #4085
Montauk
Oddometer: 260
Choice is rather clear. Don't buy GS or GSA. It's too heavy to ponder on
Old 12-20-2012, 03:12 AM   #4086
GSMarc
GSMarc's Avatar
Oddometer: 723
when I had my R1150GS, I remember BMW said :
"The target of our technical staff for the new model is to reduce the weight by 30 kg (66lbs)" and they did.
When they did the HP2E,MM,HP2S the target was to reduce weight too.
I don't understand why the new R1200GS increases its weight again
From my point of view, minus 30 kg again (-66lbs) with 110 Hp as DOHC has now was a better way to go.
GSMarc from BELGIUM
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
2000 R1150GS (sold)
Old 12-20-2012, 05:14 AM   #4087
oalvarez
Resident Raggamuffin
oalvarez's Avatar
Oddometer: 1,699
It could be due to a variety of factors.
We know the new GS weighs as much or more than its predecessor in wet form. The thought is as much as 29lbs depending on what option group the new one is being compared to.
Regardless, and as others (EJ?) have mentioned, why not subtract out the weight of the fluids and maybe even the battery to get an idea of the weight measurement you're after?
2012 Ducati 1199 Panigale
2012 Ducati MTS1200St Ti
2003 Aprilia Tuono Racing
2012 Vespa 300 Super
past: Ducatis, Aprilias, Moto Guzzis, a Husky, and some BMWs as well.
oalvarez is offline   Reply With Quote
Old 12-20-2012, 06:47 AM   #4088
GSMarc
GSMarc's Avatar
Oddometer: 723
Well, I was searching that info for another forum.
The fluid is 26 kg (57lbs) on the DOHC and 2,4 kg(?) for ABS
Dry : 203 kg (447.5lbs)
Fluid : 26 kg (57lbs)
sub-Total 229 kg ready to go (504.5lbs)
ABS : 2,4 kg (?) (5.3lbs)
Total : 231,4 kg (510lbs)
If the press relates 524lbs wet, it means 14 lbs more (about 6.5kg)
I'm not personnaly interrested, I know it will be too heavy for me
GSMarc from BELGIUM
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
2000 R1150GS (sold)
GSMarc screwed with this post 12-20-2012 at 06:55 AM
Old 12-20-2012, 07:00 AM   #4089
Marki_GSA
Oddometer: 199
BMW used to or still do (can't be bothered to go look) publish both dry and wet on their UK site. They also publish a maximum ladened weight as well.
Marki_GSA is online now   Reply With Quote
Old 12-20-2012, 07:43 AM   #4090
GSMarc
GSMarc's Avatar
Oddometer: 723
Yes, dry weight is present for all the models on all the national websites.
But missing everywhere for the new WC GS
GSMarc from BELGIUM
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
2000 R1150GS (sold)
Old 12-20-2012, 08:08 AM   #4091
Marki_GSA
Oddometer: 199
Just checked and the UK site has the fully fueled weight on it for the WC. It's 238kg and is in the technical data section.
Old 12-20-2012, 08:14 AM   #4092
GSMarc
GSMarc's Avatar
Oddometer: 723
yes, I know that.
Dry weight is missing everywhere for WC GS, not wet (ready to ride) weight
GSMarc from BELGIUM
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
2000 R1150GS (sold)
Old 12-20-2012, 08:28 AM   #4093
oalvarez
oalvarez's Avatar
Oddometer: 1,699
ok, excellent....onto the next.
Old 12-20-2012, 08:48 AM   #4094
cug
Oddometer: 3,475
You know, it's kind of useless to discuss raw numbers that way. The 2006 V-Strom DL650 I had weighed probably 30lbs less than the 2010 R1200GS and it felt like it was about half a ton heavier ... and then again, the Super Tenere 1200 is about 40 to 50lbs or so heavier than a standard GS (both standard trim, no farkles), and still feels smaller and and possibly even lighter.
It's not only about the weight, it's also where and how it's carried.
cug is offline   Reply With Quote
Old 12-20-2012, 09:21 AM   #4095
Dorsicano OP
Oddometer: 82
a few of us are all obsessed about the pounds on our bikes and tend to disregards the pounds on our waist.
I could buy a 238 Kg GS LC and lose 5 Kg myself and the net result would be same as old GS and current me.
Dorsicano is offline   Reply With Quote
Times are GMT -7.   It's 04:21 AM.
