12-14-2012, 06:51 AM
#16 |
1986 R65
Oddometer: 60
When I disassembled, I just pulled the front wheel, fender, and caliper, drained the sliders and and removed the vertical allen screws on the very bottom inside where the axle goes. Then the whole slider assembly pulls down and away. I didn't disturb the upper tubes at all, except for removing the fill plug.
12-14-2012, 07:31 AM
#17 | |
Oddometer: 118
This is what I was planning on doing, but if there's a alignment checking/adjusting procedure I'd go through that as well. |
12-14-2012, 08:31 AM
#18 |
Screwed the Pooch
Oddometer: 510
Yeah, at this point, I'd "disturb" everything. Disassemble, clean & inspect, check tubes against a very good straight edge, etc. If the tubes are straight and everything else looks good, it would be worth checking the tubes with a mic, but wear usually is apparent visually.
I'd also only lube with grease upon reassembly, that way you'll know where the oil comes from if you get any.
If your gonna be dumb, you gotta be tough When you get knocked down you gotta get back up, I ain't the sharpest knife in the drawer but I know enough, to know, If your gonna be dumb, you gotta be tough |
12-22-2012, 08:37 PM
#19 |
Oddometer: 104
I know this is an outside chance but are the seals OEM or copies. Im only mention it because I had the expereince of buying a set from offline that I couldnt get to seal - always leaked from day one. Eventually pulled them out thinking something wrong with tubes etc but by chance measured the seals and they were about 1mm to big. Put OEM ones in and they havent leaked. Never heard of it before or since.
BMW - a love hate relationship |
12-22-2012, 10:31 PM
#20 |
A proud pragmatist.
Oddometer: 3,001
^^^ You may be right, my friend sure had "online copies" leak. But those look like OEM with some of the metal exposed. Not that good BMW leaving some metal exposed.
Road salt got under the caps on my bike and rotted the metal. They sure leaked then....! I grease them now and inspect every year. Different bike....same seal design.
Have tools, will travel!
12-23-2012, 12:26 AM
#21 | |
De Jo Momma
Oddometer: 8,735
My money is that the seals were damaged on installation. I always tape around the top of the fork tube with electrical tape to protect the seal lips, then carefully slide the new seals down the leg. There were no snap rings holding those seals in? Just friction? Something isn't right. Edit: just saw pictures of an R65 fork tube. Yup, totally smooth on the bottom. I'd still bet on damage to the seals.
Greg |
12-23-2012, 04:32 AM
#22 | |
Stay Horizontal
Oddometer: 1,642
Changing BMW fork Seals/ springs/ gaiters/ oil, or how I did it on my 1982 model R100RS. Nomenclature: I call the chromed tube the fork tube. The fork leg is the lower forged bit that the calipers attach to. 1. Put new seals in the freezer for 1 hour beforehand. 2. Loosen, remove, the top fork bolt to allow drainage and refill of fork oil..move h/bars to get to bolt. 2a. To replace the springs, you need to remove the large hex bolt at the fork top, therefore no need for point 2. That hex bolt is very tight and easy to round off. Make sure your tool fits well. 3. Remove the lower drainage small bolt. Allow oil to drain. 3a. Replace springs, loosely replace top bolt. 4. Disconnect brake calipers from fork legs...hang carefully, no weight or bending of the lines. 5. Loosen, don't remove, the retaining bolt at the bottom of the fork. Better leverage before the axle comes out. 6. Remove axle/wheel/front guard. 7. Now remove retaining bolt, drop fork leg down, leaving the fork tube on the bike. Remove old gaiters/boots. 8. Clean fork leg internals. 9. Carefully lever out the old seal. I use a blunted straight screwdriver. Insert the cold new seal, use old seal to push new seal in. 10. Slide upper gaiter spacer then gaiters onto fork tube. 11. Install fork leg with new seal carefully over the fork tube.. 12. etc, etc...both sides 13. Reinstall drain bolt, refill oil, tighten top bolt. 14. wheels etc back on... 15. fiddle with the gaiter spacer, locate it into the breather tube on the inside of the lower triple clamp. One hour max. Quicker the next time.
R100RS Gallery, over 1000 pictures... |
12-24-2012, 03:47 AM
#23 |
Confirmed Curmudgeon
Oddometer: 4,013
Yes, the Randy Glass procedure is excellent and definitive;
http://aatherton06.home.insightbb.co...age/TITLE.html --Bill
'73 R60/5 Toaster |
12-24-2012, 11:15 PM
#24 | |
because I can
Oddometer: 6,206
12-25-2012, 04:46 AM
#25 |
Oddometer: 4,013
Of course not.
![]() And your detailed and definitive procedure is published where? ![]() Otherwise... ![]() --Bill
'73 R60/5 Toaster |
12-25-2012, 05:53 AM
#26 | |
Oddometer: 1,028
Ray ABC #12947 '75 R90S craydds screwed with this post 12-25-2012 at 05:55 AM Reason: R65 |
12-25-2012, 10:35 AM
#27 | |
In-Dented Savant
Oddometer: 757
Woodgrain |
12-25-2012, 03:00 PM
#28 | |
because I can
Oddometer: 6,206
supershaft screwed with this post 12-25-2012 at 03:06 PM |
12-25-2012, 03:57 PM
#29 | |
Oddometer: 907
"No hour of life is wasted that is spent in the saddle." =Winston Churchill= |
12-26-2012, 01:55 AM
#30 |
Oddometer: 4,013
That is simply the procedure for reinstalling the front wheel. The Glass article is for for checking the forks for straightness and alignment. And for straightening and correcting the alignment if they're not.
--Bill
'73 R60/5 Toaster |
