12-21-2012, 09:39 PM
#16 |
Traveler
Oddometer: 4,009
I'm gonna keep my mouth shut, I'm still getting over an air box full of oil after Gunner tried to talk some sense into me about valves.
Plus I have been through pistons and overheating problems that reduced me to idiot status. I wish I was just the pilot. bill
'02 KTM 640 Adventure-lowered "On the road there are no special cases." Cormack McCarthy-The Crossing The faster it goes the faster it breaks. And high performance=high maintenance. Bill Shockley |
12-22-2012, 09:30 AM
#17 | |
Oddometer: 149
So it is chamfered? Exellent! At worse I could of rigued a ring compressor out of a 2L coke bottle. :p Good call about the spokes and fuel line, had not thought of those. Even though I'll be carrying a spoke torque wrenche, I was forgetting some spokes. As for the fan switch and temp sensor switches; they know the bugger out? Or do you carry them just because if they quit your f'd and they probably dont take that much space anyway? Suspension is scheduled for sure and will be bringing a rebuild kit must probably. |
12-22-2012, 09:48 PM
#18 |
Traveler
Oddometer: 4,009
Umar,
Try to get another opinion on the Chamfer, my memory says yes. For the switches and the rear brakelight switch as well I carried them just because along with brake master cyl. kits and caliper kits. I'd pop the grease seal on the sprocket carrier bearing and add a little grease, grease the swing arm bolt and pivot, bleed the brakes and Only use Dot 4, Dot 3 won't cut long steep descents., especially the rear caliper will boil fully loaded dragging down a twisty mountain road in the 2nd/third world. For wheels, I tied my spokes and carried a regular motion Pro wrench, the torque wrench was in my wrist.I tightened my spokes every time I change a tire and oil them on the inside first so the nipples are smooth.the junk under the rim band will scare you so I clean that. You do have to go over every electrical connection with silicone grease or oil. You will need the countershaft O-rng and bushing. I reuse the bolt and spring washer but put it om with red Loctite. That's a hassle because you need a propane torch to get it loose. I carried filters behind the windshield. Clutch and throttle cables of course. Special tools...snap ring pliers, needle nosed vice grips, scissors, feeler gauges, Yada yada, the list goes on and on. bill
12-22-2012, 10:19 PM
#19 |
Big Bike, Slow Rider
Oddometer: 497
Bill mentioned the countershaft O-rng. Take 2-3 of these as they will double for the clutch slave o-ring if it shits itself(2006 have hydraulic clutch). You can use baby oil, fork oil as the fluid in a pinch. DO NOT use DOT Brake fluid.
2006 also has a lock washer and large nut on the countershaft. In Australia I have always got a different type of lock washer than when I order in the USA. Using the Australian lock washer, you can bend the washer over the large nut (after fixing to correct torque and using loctite). This ensures the nut does not come undone. Take a couple of the lock washer as well. I use Loctite on everything. If I don't use it, I lose the bolt/nut.
David 2005 KTM 640A 2008 Wee-Strom dnrobertson screwed with this post 12-23-2012 at 03:19 AM Reason: Cannot spell loktight :-) |
12-23-2012, 09:49 PM
#20 | |
Traveler
Oddometer: 4,009
bill
12-24-2012, 05:10 AM
#21 | |
Oddometer: 497
A quick check at Munn's shows it was a 2003.5 introduction and the part number for the washer only cross-references to various other models for the same tranmission shaft, not the clutch. For an earlier model, you would need a new shaft to use the new washer and nut. I know when I first got my 2006, I didn't bend the washer and the nut loosened with 1000 Km (it was tightened to the torque specs with loctite). Did it back up, and bent the washer and no more problems, EVER! And I have even re-used the washer several times.
David 2005 KTM 640A 2008 Wee-Strom |
02-10-2013, 10:09 AM
#22 |
Oddometer: 149
Tuning the carb & Fuel air ratio sensor
Came upon an interesting product today: a wide band Air/Fuel digital gauge plus sensor and controler for 200$.
I'm wondering if this would be a good thing to add to the lc4 for my coming trip. Since the bike will be going to lots at varing altitudes (front coastals to higher regions of patagonia) and me not being use to tunning carbs. Would having a display telling me just how lean/rich the mixture is help in keeping the carb properly setup? And if so, would the 14.7 to 1 (i think) be where I would want to keep it at all times or would I rather err on the the rich side a bit? |
02-10-2013, 10:46 AM
#23 | |
Oddometer: 1,125
Regards, Derek |
02-10-2013, 10:22 PM
#24 |
Traveler
Oddometer: 4,009
UM,
The BST40 is designed to self compensate for altitude changes, the KTM factory is 60 miles from the Alps where they test their motorcycles like the Adventure series. You can play with this map to see the relationship between the factory at Mattigofen and the Alps. http://www.maplandia.com/austria/obe...n/mattighofen/ bill
02-11-2013, 10:42 AM
#25 |
Still gettin faster
Oddometer: 950
Quick question for KTMBill??
Lurkin in here as usual. Quick question for KTMBill, then I'll get lost as not to jack the thread. Up on post #18, Bill recommended bleeding brakes with dot #4. My 2000 uses dot 5.5 which is a silicone based fluid. This is not compatable with the glycol based dot #3/4 type fluids. Did KTM change the spec fluid over the years? Am I missing something here? Don't mix 3&4 systems with 5. Just sayin.....Thanks guys, I now return you to the regularly scheduled banter..
02-11-2013, 08:15 PM
#26 | |
Traveler
Oddometer: 4,009
The top lid on my handlebar reservoir, '02 640a, says "Use Dot 4 Only". I used some Dot 3 cause I was leaving for Central America and was in a rush. I lost the rear brake completely coming down a volcano to Lago Atitlan in Guate. Problem cured with Dot 4. Speciality item in Guatemala small towns. Scares me to see blown out USA school buses coming down the mountains with Dot 3 in the system, teen age drivers shifting gears like crazy. bill
02-12-2013, 01:50 AM
#27 | |
Tyre critic
DOT 3, DOT 4, and DOT 5.1 are compatible, the higher number the higher temperature tolerance but not necessarily "better" depending on other characteristics. You can go higher than specified (eg use 5.1 in systems marked 4) but should not go lower - as Bill discovered when using his bike hard.
DOT 5.0 is the silicone-based stuff and can't be mixed with the others without proper flushing of the system first. /PEDANT
Cheers, Colin KTM LC4 640 Question? Check here first --> KTM LC4 (640) Index Thread Quote:
02-12-2013, 05:09 AM
#28 | |
Still gettin faster
Oddometer: 950
There are advantages to dot 5. For those intrested in conversion, read up on the term 'proper flushing' before trying this at home. It also appears KTM has changed the brake fluid spec. sometime after 2000. Thanks guys.
02-12-2013, 10:18 AM
#29 |
Oddometer: 1,125
