12-18-2012, 07:27 AM
#601 |
Given to fly
Oddometer: 5,497
12-18-2012, 07:47 PM
#602 |
Oddometer: 4
The headlight bolts right in. The headlight comes with the male and female end of the plug that your solder to the headlight low beam wires.
12-19-2012, 08:14 AM
#603 |
Given to fly
Oddometer: 5,497
Wow, that sounds easy and it must be a huge improvement in light output. I have an '07 with the older headlight shroud and have wanted to get the newer one just because I think it looks better. But add that Rigid light and it becomes a functional improvement as well.
12-22-2012, 01:41 PM
#604 |
Oddometer: 17
Is this the official TE510 Thread?
I just bought a 2007 TE510. A bit rough , but running.
# 1 big issue... ![]() Do I have any chance of finding a used Clutch Case and cover? biggsxr screwed with this post 12-22-2012 at 08:35 PM |
12-22-2012, 03:28 PM
#605 |
Twisted Throttle
Oddometer: 1,672
J & B Weld?
11 Husqvarna TE630 11 Husqvarna SM630 08 Husqvarna TE510- sold 10 Yamaha FJR 1300 |
12-22-2012, 05:47 PM
#606 |
TE450-KLE-FXDWG
Oddometer: 2,731
The infamous kickstart crack....another example, not really amenable to a JBWeld fix, I wouldn't think.
____________________________________ Get fit. Stay safe. Enjoy life. Learn something to help someone in need. |
12-22-2012, 08:42 PM
#607 |
Oddometer: 17
This is beyond JB weld, epoxy, etc, Mine is totally detached as well, cracked top to bottom, plus it propagated to the clutch cover. I'm not sure about the inner RH Case yet.
More pics; ![]() ![]() I can TIG weld, so I'll give it a go. I just brought it home today, so I'm beginning my search for knowledge; Factory Manuals, owner's manuals, "they all do that" knowledge. Seems they all self destruct upon kick start eventually... suck. |
12-22-2012, 10:41 PM
#608 |
Oddometer: 1,815
01-04-2013, 04:45 PM
#609 |
Oddometer: 139
2007 and 2010 TE450
I just bought a 2007 TE 450. The chassis, forks and other parts have a lot of rust on them but it works well. I am wondering why it feels a lot faster than my 2010? It makes less noise and runs stronger. It seams that it is geared a little shorter and that may be the difference. Both are full power as far as I can tell.
01-11-2013, 12:53 PM
#610 |
TE450-KLE-FXDWG
Oddometer: 2,731
2008-2010 TE 310, 450, 510
Watch for rubbed wire bundle into the ECU where it rests on the fuel injector bracket. On mine, the Brown with white stripe wire had a bare spot and was grounding to the injector bracket. This wire is connected to: Dashboard, DC relay, RH switch, Main switch, Pump relay, Fan relay, ECU interface, ECU, O2 sensor The short was weakening my spark to the plug, the plug fouled badly, I fixed the wire and put my old 10,000 mile plug in, and it started right up. ![]() ![]()
01-14-2013, 11:43 AM
#611 |
Richard
Oddometer: 73
Tank Problems
I. Just put a Safari tank on my 2009 TE 510 Everything fit well except the wiring to the in tank fuel pump was to short. I had to unwrap the wiring harness and reroute the pump wires. Has anyone else had this problem. Also the seat is a lot harder to put on. I,m not sure what to do about the seat fitting because the tank can not be moved forward and the seat needs to be moved farther forward to be able to latch it.
01-14-2013, 11:46 AM
#612 | |
Oddometer: 1,815
01-14-2013, 12:17 PM
#613 | |
Dorkus Malorkus
Oddometer: 1,777
I didn't have any issue installing the tank at all, including the wiring, but the Corbin seat did not fit, no matter what, and the stock seat needed the front slot dremeled out a bit to make fit.
01-14-2013, 12:43 PM
#614 |
Richard
Oddometer: 73
Tank
I think I need to Dremel the front slot on the seat and it will fit better. Thanks for info.
01-19-2013, 06:27 AM
#615 |
Legend in my own Mind!
Oddometer: 7,195
I looked at an 07' 510. Really like the look and having 1000 miles it seems to run right.
The Akropovic? sounds nice and not obtrusive. Already re sprung for my weight. Hard not to just lay down the cash. Great thread folks! This would be my 1st Husky.....
Getting Old ain't for pussies....................Lorazapam http://www.youtube.com/watch?v=aYDfwUJzYQg http://www.youtube.com/watch?v=9bVGTVrQd6M http://i155.photobucket.com/albums/s...6/img_5597.jpg |
