12-19-2012, 04:31 PM
#1 |
Oddometer: 26
950 clutch line routing
the clutch line on my 950 run through a triangular bit of plastic just behind the steer tube
is there a reason i should not route it above this and then come back along the normal route my issue with running it through the plastic is that it is held in place by the radiator and it looks like i will have to take both tanks off and let the rad hang to move this bit of plastic |
12-19-2012, 05:15 PM
#2 |
Semi-Adventurer
Oddometer: 9,937
My clutch hose is routed through the same plastic gizmo as the brake hose, and the choke cable. It is on the front of the top triple clamp.
I miss round headlights. "When I was a young man, I liked to race my horse...." - G.H.W.S. 1878-1962 |
12-19-2012, 05:29 PM
#3 |
Oddometer: 26
different bit of plastic
the bit of plastic i am talking about is behind the lower part of the steerer tube about ten inches further along the line from the bit your referring to
12-19-2012, 06:58 PM
#4 |
Semi-Adventurer
Oddometer: 9,937
I don't see anything like that on mine, but it is a very early model. I think the later models had some plastic parts in that area that mine does not.
Sorry I couldn't help.
12-19-2012, 09:28 PM
#5 |
мотоциклист
The 950's just ran them down the inside of the frame, sort of in where that plastic bit sits and then down the side of the airbox.
I haven't paid that much attention to the routing on my 990. But either way as long as you don't pinch it, let it come into contact with something that will allow it to melt or have rub thorugh, I can't see that it would make any difference how it is routed.
Stories from the Seat Facebook My Photos Cannonball Charity Ride No Four Wheel Drives, No Fixers and No Fricken Whingers Personal Attacks - the last refuge of the intellectually impaired. |
12-19-2012, 11:15 PM
#6 |
Oddometer: 26
thanx
i am guessing the p.o. did when he was doing some electrical nonsense and had everything off...
12-20-2012, 09:05 PM
#7 | |
MotorcycleMayhem
Oddometer: 2,154
Keep in mind that this triangle part did not show up until 2005 if I recall correctly... the early bikes did not have it... and that whole area behind the steering tube would get packed with road debris.
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla 2008 KTM 690 ADV- 2006 KTM 970 frankinADVsmSD ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
12-20-2012, 09:45 PM
#8 |
Semi-Adventurer
Oddometer: 9,937
Do you think this would be a good retrofit?
12-21-2012, 01:42 PM
#9 |
Oddometer: 26
i just cut the old line
and ran the new one above the little plastic bit...
in hindsight i guess i could have loosened the other tank and the radiator but i kept thinking that i was going to have to drop both tanks and looked for another way to route it |
12-21-2012, 04:59 PM
#10 |
мотоциклист
I can't see the point - my '04 never collected road debris in that area.
12-22-2012, 09:47 PM
#11 |
MotorcycleMayhem
Oddometer: 2,154
If its not fitted with one, yes I think its a good update. They are cheap
Part Number: 60003087000 Description: SPLASH PROTECTOR FRAME 05 all of about $4 USD
12-23-2012, 11:15 AM
#12 | |
Semi-Adventurer
Oddometer: 9,937
Though it hasn't been a big problem, some mud has collected there, and is annoying.
