Old 12-22-2012, 07:31 AM   #991
dirtysouthjacket
dirtysouthjacket's Avatar
Oddometer: 539
Sorry about that, its an 800. I updated my post to include that. I have been meaning to check the steering head bearings this winter! I can easily check the tightness soon. Thanks!
I may not have gone where I intended to go, but I think I ended up where I intended to be. -Douglas Adams
2011 F800GS Alpine White, 1998 KDX 200, 2000 KL250G Super Sherpa
DSJ's Shenanigans
dirtysouthjacket is offline   Reply With Quote
Old 12-24-2012, 08:28 AM   #992
dirtysouthjacket
Oddometer: 539
Any word on whether or not the 2013 software can be flashed to 2012 or older F800GS to help out with the throttle snatch? Thanks!
DSJ's Shenanigans
Old 12-24-2012, 10:05 AM   #993
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,680
that are some interesting questions! someone would mind calling a real BMW dealer?
Keep the smile on your face!
Originally Posted by Reaver View Post
You can be imitated but not replaced. You're such a special blend the recipe is guarded like KFC's 11 herbs and spices.
Homeless Otter on the road One month to find the rising sun
Loutre is online now   Reply With Quote
Old 12-24-2012, 11:32 AM   #994
dirtysouthjacket
Oddometer: 539
Yeah, I tried Friday but didn't really get an answer...
Once Christmas is over I was going to call around to a few others. Didn't know if anyone happened to know off the top of their head. Merry Christmas!
DSJ's Shenanigans
Old 12-24-2012, 11:38 AM   #995
HighTechCoonass
Living the Dream....
HighTechCoonass's Avatar
Oddometer: 2,485
Laugh
There is no flash for the F800 that lessens the snatch. The bikes are tuned lean to meet the emission standards. So... If the 2013 throttle is "snatchy" going backwards with a flash wont help.
NEW dash plates for your F800..here... lhttp://advrider.com/forums/showthread.php?t=1007140
HighTechCoonass is offline   Reply With Quote
Old 12-24-2012, 11:48 AM   #996
Endurodude
Endurodude's Avatar
Oddometer: 173
A larger tooth in 1st will, though!
Endurodude is offline   Reply With Quote
Old 12-24-2012, 12:10 PM   #997
HighTechCoonass
Oddometer: 2,485
Laugh
Power Controller, Booster Plug, or Accelerator (any resistor tuning device that "properly' drops the air box temperature) fixes the problem perfectly with out effecting fuel economy.
HighTechCoonass screwed with this post 12-24-2012 at 04:51 PM
Old 12-25-2012, 09:09 PM   #998
HighFive OP
Never Tap-Out
HighFive's Avatar
Oddometer: 2,729
I used the $75 Accelerator plug-in, and yes, it solved the snatchy problem perfectly. But it did affect my fuel mileage. I'm only averaging about 48 mpg now, where I was getting about 55mpg stock. The bike runs so much better with the Accelerator, I don't mind the mpg loss..
Goes to reason that a richer fuel mixture equates to greater fuel consumption. So, I expected this occurrence. I don't no why claims are made to the contrary. Have you actually experienced something different than this on your F800?
HF
'13 Husky TR650 Terra, '11 Husaberg FE390, '10 KTM 450 XCW Six Days, '12 BMW R1200GS
The Okie-Dokie BDR Terra-izing the CDR Bergs Over the Rainbow
Texas or Bust! Rocky Mountain HighFive The Other Side of Nowhere
Athena Big Bore Project
HighFive is offline   Reply With Quote
Old 12-26-2012, 04:38 AM   #999
Endurodude
Endurodude's Avatar
Oddometer: 173
My taller first gear has slightly INCREASED the mpg, has steadied first gear snatchiness and hasn't affected acceleration at all, really (not hat I've noticed, at any rate!). It appears to be the cheapest option, too?!
Old 12-26-2012, 08:15 AM   #1000
JRWooden
Oddometer: 4,249
HF
HF:
I have the IICE module and I'm not "organized" enough to have done any real MPG benchmarking,
but I would for-sure notice a 7 MPG drop, and that's not my experience. Maybe you have something else going on? Take the Accel module back out and see if mileage goes back up by 7mpg?
Old 12-26-2012, 09:59 AM   #1001
itsatdm
itsatdm's Avatar
Oddometer: 4,867
I lost 1 or 2 mpg with the Accelerator module (58 to 56). Mileage can vary greatly on the bike depending on where and how fast you ride it.
Sprockets!!! I got sprockets, 15 and 17 tooth. I used the 17 for a year. It does have an effect on high speed vibes. I did not notice much impact on fuel mileage.
It is adequate for most fire roads, but not the steep twisty type with 1st gear hair pins. I took it off and will save it for long freeway travel. It was the installation of the fuel module that made the use of a 17 tooth on most of the fire roads possible.
itsatdm screwed with this post 12-26-2012 at 11:01 AM
Old 12-26-2012, 12:49 PM   #1002
runnin4melife
Oddometer: 804
Taller 1st gear? You mean front sprocket? Or you actually tore the gear box apart and installed a new gear? If so please pass the knowledge of this part on? Also did you run similar setups between the other gears?
I have done this on quite a few race bikes but in all my internet travels I have not seen anything for the F800 so far. It is not really that it has fixed snatchiness it is the derivation of the power being transferred over a broader spectrum. I can not believe that this is a cheaper option because of the work involved in just pulling the entire motor and dealing with seals, fluid, and the necessary knowledge just to do this. A fuel mapping ECU and a sprocket change would be easier, cheaper and more pliable to adapt to different configurations... More information please.
runnin4melife is offline   Reply With Quote
Old 12-26-2012, 01:43 PM   #1003
Endurodude
Endurodude's Avatar
Oddometer: 173
Sorry for the confusion! I meant sprocket. Not as exciting as you were hoping, sorry . . . .
Old 12-26-2012, 01:48 PM   #1004
runnin4melife
Oddometer: 804
No worries! Sprockets are the simplest and cheapest too.
Old 12-27-2012, 08:38 AM   #1005
HighTechCoonass
Oddometer: 2,485
Talking
One thing I don't want a taller 1st gear... that makes to tougher on the tight rocky trails when riding out west.
Times are GMT -7.   It's 12:07 PM.
