12-24-2012, 11:24 AM
#16 | |
мотоциклист
Stories from the Seat Facebook My Photos Cannonball Charity Ride No Four Wheel Drives, No Fixers and No Fricken Whingers |
12-24-2012, 11:32 AM
#17 |
MotorcycleMayhem
Oddometer: 2,159
direct link to the thread with detailed instructions on making a LC8 sprag from LC4 sprag.
http://www.advrider.com/forums/showp...5&postcount=17 You will need a big breaker bar or pneumatic impact to get the crank bolt loose, then a grub screw (to push against) and a puller (pusher bolt really) to push the flywheel off the crankshaft taper, then you can get to the sprag.... will also need 648 loctite for reassembly. If you dont have the parts available, in a pinch and IF you can get the flywheel off... you can tighten the perimeter spring on the sprag to put more preload on the sprag pals... but this is only work around to the probably required replacement of the pals and the spring.
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla 2008 KTM 690 ADV- 2006 KTM 970 frankinADVsmSD ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
