Old 12-25-2012, 12:01 PM   #286
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 54,052
Originally Posted by WhiteShark View Post
Sweet!
Jim
Old 12-25-2012, 03:34 PM   #287
Alanjnc
AlanjNC
Alanjnc's Avatar
Oddometer: 38
The shorai battery Impressed me as it is a lithium and is not supposed to drop a charge over time of storage. Which is really not an issue here because I can ride every week anyway. But it is very very light and a drop in install.
Also started the bike ('11 GSA) well at 35 with 20/50 oil.
You cannot multiply wealth by dividing it....
Alanjnc is offline   Reply With Quote
Old 12-25-2012, 08:27 PM   #288
macadamia
XK Red 27 Technique
macadamia's Avatar
Oddometer: 1,386
It was 35 there today? Ooooof, what am I getting myself into... I'll be there in a week to pick up my bike. I need to make sure I pack my long undies and my heated gear for this trip...
"The early bird gets the worm, but the second mouse gets the cheese." Unknown
'12 BMW R1200GSA '02 BMW R1100S BCX
macadamia is offline   Reply With Quote
Old 12-26-2012, 06:38 AM   #289
Murkidi
R1100GS adict
Murkidi's Avatar
Oddometer: 229
Cut in half 3 times my R1100GS '95
My bike has a M94 gearbox , and had the conical bearings in the imput shaft, so I found a recall from bmw that recomend to replace all bearings with clean or sealed ball bearings, so I look up for the and cut the bike in 2 halves open the gearbox and replace the bearings, but (there is always a "BUT")I made A mistake in the roller bearings from the intermediated shaft and had to split the bike again and change the wrong roller bearings, so the gearbox was like new and silent, but (again) after a month using it on the weekends , start to developing a problem with the clutch, so I consult JVB and explaind what was happening to the cluth and he answer me "no lubrication on the shaft splines" so I remove the starter to check the shaft and was rusty and also check the thickness of the clutch plate and was 4.8mm , apractically wrong out!! so I split the bike again!! and replace the clutch with a complet set that I bought at Beemerboneyard that works great, so in the las 2 and half months I have split the bike 3 times, so I have an almost new '95 R1100GS
PS thanks a lot to JVB and Mike from Beemerboneyard for all the help and atentions!!!
So That's what I have beem doing to my GS latelly !!!!!!
manuel...
sorry for my english in case of any mistake!!
'95 R 1100 GS
Murkidi is online now   Reply With Quote
Old 12-26-2012, 06:54 AM   #290
lhendrik
Truffle Rustler
lhendrik's Avatar
Oddometer: 2,397
What, are you tracking submarines with that thing?
Normal is just a setting on the dryer.
2009 R1200GS A, 2008 K1200GT
lhendrik is offline   Reply With Quote
Old 12-26-2012, 07:02 AM   #291
Murkidi
R1100GS adict
Murkidi's Avatar
Oddometer: 229
Bearings and Pics
Here is the list of the bearings in case somebody need it:
all SKF
6205 2RS C3 Qty.2
6304 2RS C3 Qty.1
6204 2RS C3 Qty.1
6303 2RS C3 Qty.2
manuel...
'95 R 1100 GS
Old 12-26-2012, 10:23 AM   #292
rutard
Magnanimous Madcap
rutard's Avatar
Oddometer: 326
New gps bracket!
What is this?
rutard is offline   Reply With Quote
Old 12-26-2012, 10:55 AM   #293
oalvarez
Resident Raggamuffin
oalvarez's Avatar
Oddometer: 2,630
^ it is the emergency pull-strap that activates an inflatable device in the event of a deep-water crossing.
2012 Vespa 300 Super
past: Ducatis, Aprilias, Moto Guzzis, a Husky, KTM 1290 SDR, and some BMWs as well
oalvarez is offline   Reply With Quote
Old 12-26-2012, 03:11 PM   #294
MotoBoss
Bad Influence
MotoBoss's Avatar
Oddometer: 3,895
I thought it was the power outlet for the mocha super cappuccino deep fryer............., sorry my bad.................
Adventure Before Dementia
MotoBossMotoBlog
AdventureRiderRadio
Donate To ADV
MotoBoss is offline   Reply With Quote
Old 12-26-2012, 03:40 PM   #295
Martad00
Martad00's Avatar
Oddometer: 11
Clearwater Kristas, Wunderlich Vario shield.
Martad00 is offline   Reply With Quote
Old 12-26-2012, 04:20 PM   #296
WhiteShark
Oddometer: 19
Originally Posted by rutard View Post
What is this?
Just a temp sensor that come with that volt meter under the gauges? Not quite sure if I need it, but what the hell, it's there.
WhiteShark is offline   Reply With Quote
Old 12-26-2012, 07:40 PM   #297
Twilight Error
Going nowhere slowly
Twilight Error's Avatar
Oddometer: 22,763
100k mile rework.
Head gaskets, valve seals, rear main and transmission input, spline lube (splines are near perfect, BTW), driveshaft and final drive seal.
Big doings this week.
If you're all about the destination, take a fucking flight. - Frank Turner
Got brap, and twice as much fuel as you. - Akarob
Twilight Error is offline   Reply With Quote
Old 12-26-2012, 09:44 PM   #298
rutard
Magnanimous Madcap
rutard's Avatar
Oddometer: 326
Originally Posted by Twilight Error View Post
100k mile rework.
That's a lotta work. But sounds like it went well.
Is there gonna be a writeup?...
Old 12-26-2012, 10:29 PM   #299
Jazz62
Jazz62's Avatar
Oddometer: 1,032
100k mile rework.
How old is your garage (the stone walls I mean)? Very cool.
Jazz62 is online now   Reply With Quote
Old 12-27-2012, 03:04 AM   #300
Twilight Error
Oddometer: 22,763
Yes, there will be.
I haven't run into any expensive surprises yet, but the job is just begun and there is plenty of time to bust a transmission case or score a piston. The transmission input/output splines are in excellent condition. They need to be cleaned, but there aren't any signs of wear that I can see. The driveshaft universals are well and truly thrashed, the rear is notchy in both planes and the front is floppy to the extreme. I knew the rear joint was bad in October when my final drive seal started weeping, so I bought a good one from the flea market. I'll send the old out to be reworked sometime next year.
My busted bolt count is 2.
One is in the left head, it seized and twisted off when I was removing my head guard. The other secures the alternator belt cover, that bolt rounded out and I had to drill the head off.
Times are GMT -7.   It's 05:19 PM.
