Old 12-26-2012, 02:36 PM   #16
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,493
Just curious, does anyone know roughly what a modern excel rim weighs compared to a 80s Akront rim?
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 12-26-2012, 03:04 PM   #17
AntonLargiader
AntonLargiader's Avatar
Oddometer: 4,228
Interesting info. From where did the weights come?
HP2 has an air shock, that's why it's so light. R11GS, you have to remember that the shock contributes less to the unsprung weight than the others do due to its location.
The Akront rear rims actually aren't that heavy. I was very surprised. The hub is heavy. I have not disassembled a front so I don't have experience there, but I do have a G/S front hub lying around that I could weigh.
Old 12-26-2012, 03:12 PM   #18
Airhead Wrangler
Adios Mexico
Oddometer: 6,493
Parts fiche.
Old 12-26-2012, 03:54 PM   #19
Phreaky Phil OP
Oddometer: 1,806
After studying Prutsers bike which he says is 188kg with a tank a ( 19l ) of fuel, I want one like that.
Take away the fuel it makes it 175kg ready to go with empty tank. Thats only 10 kgs heavier than my DR650 and the C.O.G would be lower on the Airhead.
So, can an R80GS be stripped of enough weight to make it the same. In theory the engine and main frame should weigh the same.
Phreaky Phil is offline   Reply With Quote
Old 12-26-2012, 04:07 PM   #20
Phreaky Phil OP
Oddometer: 1,806
GS fairing/ speedo etc 8.7kg. (weighed)
Collecter box 3.6 kg
standard muffler 3.7kg
staintune muffler 3.4kg
crash bars 1.3kg (pair)
Phreaky Phil screwed with this post 12-26-2012 at 06:50 PM
Old 12-26-2012, 04:08 PM   #21
Prutser
Prutser's Avatar
Oddometer: 989
But I guess you are going to use it 2up ? Than the subframe should be stronger than mine.
Must admit I think I weight it without the bashplate.
My front wheel is a lot lighter than stock. ( am using a G650X wheel)
The R100gs i had before was 185 stripped. So it must be possible.
Didn't measure that my self !
BMW R100'91/R80'93/R75/6 R80ST'83/R65GS'87/GasGasTXT300/DouglasW20-1920
Ride Report 2012
Prutser screwed with this post 12-26-2012 at 04:14 PM
Prutser is offline   Reply With Quote
Old 12-26-2012, 04:14 PM   #22
Kokopelli
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,644
Now I know pretty much stuff all about these things, but I am pretty sure Manuel does. I've seen what he did to make his bike lighter.
R1150GS
R80GS Basic
Kokopelli is offline   Reply With Quote
Old 12-26-2012, 04:53 PM   #23
Phreaky Phil OP
Oddometer: 1,806
Yes it would be a 2up bike.
The subrame can be braced with one straight tube from the footpeg end to the rear, either welded or bolt on and coule incorporate the pannier frame rails. For the GS a R80 basic subframe would proably be the best start point.
Old 12-26-2012, 06:33 PM   #24
AntonLargiader
Oddometer: 4,228
FWIW I think my '88 is 44x pounds without fuel. That's about 40 pounds more than your cited weight. That's with a PC545 battery and no oil cooler. Still has crash bars, stock everything else including exhaust.
What was stripped?
Old 12-26-2012, 06:56 PM   #25
Phreaky Phil OP
Oddometer: 1,806
What was stripped?
Hi Anton. 440 pounds is 200kg. Mine is a 92 so has the big fairing. I think it was 209 with a very small amount of gas. Staintune muffler, GS1150 battery. stock most other things. Extra couple of kilos with rear disc.
Old 12-26-2012, 09:36 PM   #26
Phreaky Phil OP
Oddometer: 1,806
Ok, here is where I think some weight can be cut
Fairing/ headlight/ instrument panel 7kg
crash bars 1.5kg
front wheel 4.5kg
side stand 0.75kg
muffler 3kg
subframe 1kg
centre stand 1kg
swingarm/final drive 2kg
forks/triple clamps 1kg
front brake caliper 0.5kg
Total 22.25kg
That still puts the weight with no fuel around 187kg
Not sure where another 12kg could be found. Hmmmm !
Old 12-26-2012, 09:57 PM   #27
Kokopelli
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,644
You could try and lose some of the metal bits off the engine. Replace the front cover with carbon fibre. Maybe the same with the airbox and starter lid. Maybe there are lighter starters available. The indicators can be replaced with something lighter. It just starts to get a bit expensive and time consuming, after the obvious stuff. Take the tools out, they can go in the luggage. Fit lighter mirrors. I don't know if there is much of a difference in shock weights. Batteries are heavy as well, Handlebars, could be another one. I am sure some are lighter than others.
R1150GS
R80GS Basic
Old 12-26-2012, 10:24 PM   #28
Phreaky Phil OP
Oddometer: 1,806
Yea could get tricky. I already have WR indicators which are pretty light and alloy bars. I took a mirror off, havent weighed it yet but it felt pretty light. I havent weighed the battery yet. I may be able to save a little yet on a smaller one. I dont think the Shorai batteries are quite up to the task yet. I have a Valeo starter, i read somewhere just recently that the Bosch starter is heavier and the Nippon Denso is lighter.
Old 12-26-2012, 10:32 PM   #29
Padmei
enamoured
Oddometer: 3,651
I don't think it needs to be necesarily that expensive . I have dropped as much crap off mine as I could & I'm as tight as a tight thing. Getting rid of the ridiculous BMW wiring, relays, lites, speedos etc is a great start. Got a real small motobatt. I dropped about 30kgs replacing the stock collector& muffler with phils cast off Y pipe & a Ti pipe
I couldn't believe the difference in weight between my DRZ & GS wheels either - WOW.
if I get another attck of motivation I would look at replace the subframe with something smaller but then you lose the luggage compatibility. I wonder if you could lighten the driveshaft without any detrimental effect.
Padmei is online now   Reply With Quote
Old 12-26-2012, 11:30 PM   #30
Kokopelli
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,644
I wish I could do that, too, but Basil is just a little bit special, so I don't want take too much off. Maybe if I win the lotto I can send him to Edelweiss Motorsport for a bit of R&R, but really, I am happy with the way he is now.
It will be interesting what Phil comes up with. I am glad he has rekindled his relationship with his airhead.
R1150GS
R80GS Basic
Times are GMT -7.   It's 12:27 PM.
