Old 12-25-2012, 09:21 AM   #856
stevemd
stevemd's Avatar
Oddometer: 81
Originally Posted by newcastleadam View Post
What can wear/need replacing with the kickstarter assembly?
The part that fits onto the serrated shaft sticking out the right case has a stub on which the kick lever pivots on when you flip it out to kick 'er over. That stub and/or the lever part that fits on it can wear.
http://www.partspitstop.com/p/Discou...C12C1229E13402
stevemd screwed with this post 12-25-2012 at 10:17 AM
stevemd is offline   Reply With Quote
Old 12-26-2012, 03:01 PM   #857
dan-o
Oddometer: 81
I have found the source of the rattling on my 2004 KLr250. I pulled the valve cover off and checked the valves ( which were good) but saw that the spring on the KACR is missing. Does anyone have a picture of how the spring is suppose to go? Is there only one spring?
thanks
dan
dan-o is offline   Reply With Quote
Old 12-26-2012, 03:59 PM   #858
newcastleadam
Artful Tagger
newcastleadam's Avatar
Oddometer: 3,455
thanks
dan
There is only one spring. I may have an extra off a burned cam, will check.
Adam
86 KLR250 01 KLR685 06 K1200LT
As ever, buyer and seller of all things KLR
KLR Doohickey Wrench available!
The North Florida Tag-O-Rama wants YOU!
newcastleadam is offline   Reply With Quote
Old 12-27-2012, 05:22 AM   #859
8gv
Oddometer: 2,521
Check this out...
Over in FM there is a KLR250 for sale that's been on quite a trip. It has a few miles on it too. This makes me even more confident to bring mine up to Newfoundland this coming summer.
Link:
http://www.advrider.com/forums/showthread.php?t=850555
8gv is offline   Reply With Quote
Old 12-27-2012, 10:20 AM   #860
stevemd
stevemd's Avatar
Oddometer: 81
My KLR fell over onto the left side, was on floor for about 30 sec. This being my first water-cooled bike, do I need to burp the cooling system or anything?
Old 12-27-2012, 05:11 PM   #861
newcastleadam
Artful Tagger
Oddometer: 3,455
Nope, should be fine.
Adam
Old 12-27-2012, 05:48 PM   #862
tjanson
Oddometer: 26
Link:
I took my KLR250 on the Translab from Vermont this summer... 3000 miles in 10 days. KLR did fine... just change your oil every 1000 miles or so. Mine would get thin and I'd start losing it after about 1500 miles of keeping it pinned at 65 mph (with Shell Rotella Diesel Oil, YMMV).
KLR before it got dirty in the dirt:
tjanson is offline   Reply With Quote
Old 12-27-2012, 08:12 PM   #863
gasolinetom
Mechanic
gasolinetom's Avatar
Oddometer: 21
Eek side stand
kickstand was broke off. tabs ripped off of frame. by a drunk driver backing into the klr250 at slow parking speed. i tried welding it on, but it just bent the weld. so im looking at bolting and then weldig this on
http://www.flyncycle.com/kickstand-m...tox-stand.html
please tell me what yall think.
also i must re true my wheel, not badly out of true, but enough to notice a difference at highway speeds.
gasolinetom is offline   Reply With Quote
Old 12-29-2012, 08:29 PM   #864
DrMoto
Oddometer: 26
running lights
Got a couple of 1.5W lights from superbrightleds.com (PLM series) and wired up today. Mounted to radiator supports. Not a bad result for a total investment of about $15. We'll see how they hold up. They look a bit yellow from off-axis; more white head-on.
'00 KLR250
'07 FJR1300
DrMoto is offline   Reply With Quote
Old 12-30-2012, 08:03 AM   #865
toddzacker
NO FILTER
toddzacker's Avatar
Oddometer: 732
Would like some help with mods for the 2000 KLR250...I saw someone had a cobra exhaust for it, can someone let me know who that was or help find the link to it? Here are the questions I had:
1) recommended exhausts
2) jetting ... Main & pilot also needle settings
3) valve clearances
This should be a good start for the winter mods. I am considering rebuilding the top end if the compression test is a little low. The bike has 8500 miles on it, not sure how long would be recommended before a top end refresh.
Any suggestions & comments will be greatly appreciated.
Thanks,
"That is one good tasting pickle", Jersey
'12 BMWR1200GS
'06 F650GS
toddzacker is offline   Reply With Quote
Old 12-30-2012, 03:39 PM   #866
Voidrider
Oddometer: 992
http://advrider.com/forums/showthread.php?t=848837
My project bike is taking a back burner to other projects, so I think I am going to have to hold off about thinking about getting this exhaust myself.
Voidrider is offline   Reply With Quote
Old 12-30-2012, 05:06 PM   #867
newcastleadam
Artful Tagger
Oddometer: 3,455
Does anyone have pics of the two rear axle spacers? Either mislaid one or it never came with the project bike, need to determine which.
Adam
Old 12-30-2012, 06:33 PM   #868
DrMoto
Oddometer: 26
same bike
[/QUOTE=toddzacker;20356938]Would like some help with mods for the 2000 KLR250...I saw someone had a cobra exhaust for it, can someone let me know who that was or help find the link to it? Here are the questions I had:
3) valve clearances
Thanks,[/QUOTE]
I have the same bike. 7500 miles (2/3 of them mine), starts easily, never burned a drop of oil, runs great and gives 65-70 MPG. So I can't tell you how long till a rebuild but I am guessing it is a long way off. I did change main jet from 118 to 120, and backed out idle air screw a bit. Stock exhaust and air box. I would upgrade rear shock before messing with motor.
You need two manuals. One for klr600, and supplement for klr250.
'00 KLR250
'07 FJR1300
Old 12-31-2012, 07:19 AM   #869
toddzacker
NO FILTER
toddzacker's Avatar
Oddometer: 732
Thanks- already started messing with the suspension, front & rear. I have a 130 lbs rider on it so not as much work needed as for a heavier rider. I also have both manuals & just figured I would reach out to this group for recommendations on things that work or didn't work.
I think I have found some good ideas, but keep them coming & I will give updates on what I feel worked best.
'12 BMWR1200GS
'06 F650GS
Old 12-31-2012, 05:35 PM   #870
HandKPhil
HandKPhil's Avatar
Oddometer: 508
My re-jet
I've done the following mods to both my '03 and '05 KLR250s, and have had excellent results:
#38 Pilot
#122 Main
FMF Q4 Muffler
Drilled four 1/2" holes in the top of my airbox.
I bought OEM jets from jetsrus.com (genuine Keihin)
If your bike runs well and is easy to start, you don't need to "freshen up" the top end. My '03 has 27,000 miles on it and it has never needed top end attention.
3) valve clearances
Thanks,
HandKPhil
HandKPhil is offline   Reply With Quote
Times are GMT -7.   It's 10:07 PM.
