Old 12-27-2012, 09:55 AM   #16
Super Tracker OP
Oddometer: 16
It lives & Rides!
I'm about 95% done with it. I still need to have the custom tank built (have the bungs, petcock already). I also need to wire in some resistors so the blinkers flash slower. I had to weld a gusset in the compression release bracket, because the stiffer valve springs are harder to pull, and the cable bracket just bent over when pulling the lever.
I also need to get my rear shock rebuilt. I went to have it charged, and oil came out of the Schrader valve.
With the crazy Kansas weather, I've actually managed to put a couple hundred miles on it this Dec. Overall the bike is really well balanced.
1970 CB750----1987ish XL600R Super Tracker in progress....
Super Tracker is offline   Reply With Quote
Old 12-27-2012, 11:29 AM   #17
gatorgrizz27
Oddometer: 133
Looks awesome, great build. What is the story on that Triumph engined cafe racer?
gatorgrizz27 is offline   Reply With Quote
Old 12-27-2012, 07:10 PM   #18
Super Tracker OP
Oddometer: 16
Thanks. The Triumph is a Thruxton that was built by my friends @ Medusa Fabrications, here in KC. They did my aluminum subrame welding for me and will be fabricating the aluminum tank too.
Old 12-27-2012, 07:34 PM   #19
plugeye
mc caregiver
plugeye's Avatar
Oddometer: 3,838
[QUOTE=Super Tracker;20338141] I still need to have the custom tank built
UOTE]
that tank looks pretty sweet to me.
plugeye is offline   Reply With Quote
Old 12-28-2012, 09:04 PM   #20
12120
Indenturedx5
12120's Avatar
Oddometer: 454
Yep!
Very cool man! Wish I had the time to do something like that. Try it when you have 4 kids! Very cool though.
Chris
If you find yourself in a fair fight, your tactics are wrong.
'83 XL 600r
12120 is offline   Reply With Quote
Old 12-29-2012, 08:23 AM   #21
kubiak
Oddometer: 4,829
Originally Posted by Super Tracker View Post
With a new baby in the house, progress has been slower than expected. I'm home on paternity leave now, so I've been getting some done, between the baby's naps.
On with the pics!
that thing is looking great!
Old 04-12-2013, 10:09 AM   #22
Rusnak_322
Oddometer: 24
Very nice.
looking to do something similar, but I have some questions.
How did you choose the CRF swingarm? was it to get the disk brake? Did it fit the frame without any modifications? What swingarm bolt did you use?
Can you post some more/better pictures on how you did the upper shock mount?
How is the bottom shock linkage set up?
I am in the planning stages now - I don't even have a bike yet.
thanks,
Eddie
Rusnak_322 is offline   Reply With Quote
Old 04-12-2013, 10:26 AM   #23
VxZeroKnots
VxZeroKnots's Avatar
Oddometer: 2,867
bad ass!
I say we take off and nuke the entire site from orbit. It's the only way to be sure
No bike does everything perfectly. In fact, no bike does anything until someone gets on it to ride.
VxZeroKnots is online now   Reply With Quote
Old 04-12-2013, 11:43 AM   #24
teledan
teledan's Avatar
Oddometer: 85
Bike looks mean! nice work.
teledan is offline   Reply With Quote
Old 07-04-2013, 10:22 PM   #25
Super Tracker OP
Oddometer: 16
Sorry guys, haven't been on here to update or reply in a few months.
Old 07-04-2013, 10:54 PM   #26
Super Tracker OP
Oddometer: 16
Thumb
Originally Posted by Rusnak_322 View Post
Very nice.
thanks,
Eddie
I chose the CRF swingarm because it was aluminum, had a disc, was from a Honda, clean and the right price. I actually looked at a bunch of different swingarms on ebay, contacted the sellers and asked what the width was at the pivot. Turns out many many models are between 7-8 inches (CR, YZ, Aprilia SXV etc.) I wanted the SXV, but didn't want the extra price tag or weight.
I have a stainless washer between the swingarm bearing and frame, on both sides. The pivot bolt is from an 06' CR. I drilled out the left side of the frame pivot hole, to take the larger CR bolt; it tapers down at the threads, so the right side fits. I used a hardened nut from a clutch basket, slid it on the pivot bolt, and welded it to the back of the head. CR bolts don't have a hex head, they fit in a groove and keep themselves from turning. So I actually needed a hex, or could have welded tabs to keep it from spinning.
You can kind of see it here.
The top shock mount was made from square tube, with a 1" hole drilled in it, and a piece of 1" 4130 CrMo pipe going through the holes. Notched the bottom of the square out a little in back, for the shock to fit inside. I also gusseted pipe. The weakest part would have been the factory, paper thin, tubing, where new pipe is twisting it like a lever, between new pipe and original mounting point. So, I add another rectangle tube from new mount up to original, with a pipe spacer, up in the hole.
I built the bike, using a 1982 CR250 rear shock. It had an after market resevoir (the sweet finned one above). But, the bladder was blown out (almost wiped out riding a blown shock on a REALLY FUN bike...), and I didn't know who made it. It's the same length as the stock XL600 shock. I then started digging and digging through forums and on Racetech, finding another shock. Turns out that the Suzuki LTZ400, 4 wheeler, has the same spring rate as a 1982 CR250 (both Showa). They are the same length and have the same diameters. The LTZ shock has a fixed reservoir that is turned perpendicular and on the piggyback.
The two holes in the gusset are for the header tab/hanger.
IMAG0491
Super Tracker screwed with this post 07-04-2013 at 11:54 PM
Old 07-05-2013, 02:16 PM   #27
joexr
Oddometer: 3,773
The tread pattern on your front tire is backwards. Should be opposite of the rear.
Old 07-05-2013, 09:56 PM   #28
TonyfromOR
TonyfromOR's Avatar
Oddometer: 62
I was thinking of doing something similar to your headlights; what did you use?
TonyfromOR is offline   Reply With Quote
Old 07-06-2013, 06:33 AM   #29
Super Tracker OP
Oddometer: 16
It's an 18" rear tire that is on the front. It's mounted per the arrow.
Old 07-06-2013, 06:40 AM   #30
Super Tracker OP
Oddometer: 16
I used these 2" square LED's. I recommend one 20 degree and one 60 degree beam. The didn't offer the 60's when I ordered mine, and I had a 120 and a 20. the 120 was too wide and didn't reach far enough, so I called them and they sent another 20 lens. They are well made and very bright for the price.
Times are GMT -7.   It's 05:50 AM.
