Old 12-22-2012, 09:38 AM   #1
Deepc OP
Oddometer: 299
Gear indicator bolt stripped out.
Merry Christmas. I rode from new Orleans LA to My folks place in Sarasota Fl only to find a oil leak on the garage floor upon arrival. Upon closer inspection one of my gear indicator bolts was not only loose but stripped out. What are my options? Retap? Coil? Any help would be appreciated....
Deepc is offline   Reply With Quote
Old 12-22-2012, 09:44 AM   #2
DADODIRT
DADODIRT's Avatar
Oddometer: 3,557
I just replaced the o-ring and was worried I had stripped one of the threads. Not so, but while searching one of the options was drilling and tapping a slightly longer hole with the same thread/pitch. Add a longer bolt and it should be good to go.
The real trick is not to tighten it beyond about 8nm.
I find your lack of faith in the force disturbing.
DADODIRT is online now   Reply With Quote
Old 12-22-2012, 10:06 AM   #3
Deepc OP
Oddometer: 299
I just measured the bolt hole. It appears that the bolt only occupies 2/3 of it. I'm guessing that there are some good threads behind the stripped out section. I'm thinking about retaping and using a bolt that is 1/3 longer. What do you think? Also, does anyone know this bolt size and what tap to use?
Old 12-22-2012, 10:16 AM   #4
Peanuts
Peanuts's Avatar
Oddometer: 1,666
Screw is M5 x 12mm long. So I guess an 18mm long screw might go straight in there, but keep an eye open for the screw bottoming out before it nips the switch tight.
Peanuts is offline   Reply With Quote
Old 12-22-2012, 10:26 AM   #5
Deepc OP
Oddometer: 299
Thanks peanuts
Old 12-22-2012, 01:08 PM   #6
Deepc OP
Oddometer: 299
So, I think I got it fixed. I picked up a M5 bolt that was about 1/3 longer than the original. I retaped the hole with a .80 pitch tap to match the bolt and torqued it down. I took it for a test run and haven't found any leaks. Thanks for the help.
Old 12-22-2012, 06:22 PM   #7
scruffy
Oddometer: 222
When I had this problem I just took a tapered tap and ground off the tip to make a flat tap (couldn't find a flat tap) and threaded the hole all the way in. It seemed like the last 1/3 of the hole wasn't threaded. No drilling involved . The longer bolt wouldn't go in before I re -taped the hole. It must have been taped with a tapered tap originally. I did both screw holes because the original short screws weren't grabbing many threads. I think that's what caused the problem to begin with.
scruffy is offline   Reply With Quote
Old 12-22-2012, 06:26 PM   #8
TheMuffinMan
Forest Ranger Magnet
TheMuffinMan's Avatar
Oddometer: 6,133
I would go to only 3NM max.
"To strive, to seek, to find, and not to yield."
"You don't cross the mountains, they let you through."
KTM 525 XC-W // KTM 950 Adventure
TheMuffinMan is online now   Reply With Quote
Old 12-23-2012, 01:46 PM   #9
zedtours
zedtours's Avatar
Oddometer: 367
Please,somebody, explain what gear indicator is?Neutral switch???
zedtours is offline   Reply With Quote
Old 12-23-2012, 03:48 PM   #10
DADODIRT
DADODIRT's Avatar
Oddometer: 3,557
Probably the same thing. Sorry, no picture, but it is behind and slightly above the front sprocket. O-ring eventually goes bad. Mine was at 28,xxx miles when I replaced the o-ring.
Old 12-26-2012, 03:36 PM   #11
Questor
More Undestructable
Questor's Avatar
Oddometer: 4,175
I've stripped mine before.
Installed Heli-Coil(s) and it's better than new.
So what is this mysterious Gear Indicator switch, someone asked?
On the left side of the bike, behind the sidestand, is an oval panel with a green wire coming out of it.
This switch tells the bike when it is in neutral and is wired to the side stand and a switch on the clutch lever. As the bike is put in neutral, two brass ball bearings inside the switch complete a circuit that also tuns on the green "neutral" light on the dash. This ciruct prevents you from starting the bike when in gear, or the clutch is not pulled in or when the side stand is up.
The screws holding this switch into the engine, usually come loose, or the O-ring gets hard with age. Oil begins to leak out. Then people tend to over tighten the screws and strip the threads going into the engine casing. (Including myself - three times...)
It's a minor leak, but stripping the threads is a pain the a$$.
Easy fix though...
Q~
Old 12-26-2012, 04:32 PM   #12
Sadlsor
Oddometer: 691
I'm glad someone else asked "what is this?"
Obviously others knew what Deepc referred to; I was sitting here thinking "When did KTM put a gear position indicator on the 9X0?!...Wait...am I still in the OC forum?"
Semantics, I guess.
I'd be completely lost without my Orange Crush teachers.
You must be the change you wish to see in this world.
Sadlsor is offline   Reply With Quote
Old 12-27-2012, 06:21 AM   #13
zedtours
zedtours's Avatar
Oddometer: 367
Neutral Switch!
Just never heard it called that before!
Old 12-27-2012, 06:57 AM   #14
Peanuts
Peanuts's Avatar
Oddometer: 1,666
It tells the ECU if the gear is one that requires power restriction, more to it than just neutral ;)
Old 12-27-2012, 03:06 PM   #15
Questor
More Undestructable
Questor's Avatar
Oddometer: 4,175
Ooohhh! Even cooler!
Neat!
Q~
Times are GMT -7.   It's 05:34 PM.
