Old 12-26-2012, 12:48 PM   #1006
runnin4melife
Oddometer: 488
No worries! Sprockets are the simplest and cheapest too.
runnin4melife is offline   Reply With Quote
Old 12-27-2012, 07:38 AM   #1007
HighTechCoonass
Living the Dream....
HighTechCoonass's Avatar
Oddometer: 2,104
Talking
One thing I don't want a taller 1st gear... that makes to tougher on the tight rocky trails when riding out west.
The F800gs Snatchy Throttle Fix Boost your Beamer...BMW efi GS Power Controller - l Now the Juice NEW!TheJUICE
HighTechCoonass is offline   Reply With Quote
Old 12-27-2012, 07:57 AM   #1008
HighTechCoonass
Oddometer: 2,104
On our last trip my friend and I compared fuel consumption at every stop on a 5 day ride... and found no difference... this trip was mostly highway riding... not alot of on / off throttle movement.
Trip before....Colorado / NewMexico
I was using about a 1 to 2 tenths of a gallon more on fill up when riding out on the trails in Colorado. I will be the first to say I am not hard on the bike at all... I ride a medium pace... Average with 5 riders.
Originally Posted by HighFive View Post
I used the $75 Accelerator plug-in, and yes, it solved the snatchy problem perfectly. But it did affect my fuel mileage. I'm only averaging about 48 mpg now, where I was getting about 55mpg stock. The bike runs so much better with the Accelerator, I don't mind the mpg loss..
Goes to reason that a richer fuel mixture equates to greater fuel consumption. So, I expected this occurrence. I don't no why claims are made to the contrary. Have you actually experienced something different than this on your F800?
HF
Old 12-27-2012, 10:26 AM   #1009
DoWorkSon
Oddometer: 113
New owner question.....
Where can I purchase a spare tube for my bike and what is necessary for a tube repair change???? I'm new to tubed tires, so I have no idea what I need.
So far I have:
Cruz Tools tool kit
Slime air Pump
I need:
Bars to break bead and get tire off wheel
Lubricant?
Spare Tube
I have no idea where to purchase a spare tube or which one I need. I have K60's on bike now. I know a 21" tube will work on front/back, but I am not sure where to get or any other info. Any help would be great
DoWorkSon is offline   Reply With Quote
Old 12-27-2012, 10:31 AM   #1010
Reaver
Amusing Myself Again
Reaver's Avatar
Oddometer: 584
When you had your tires changed you could have (should have) gotten new tubes as well. I always ask for the old tubes back as they just get thrown out. You can go to any bike shop and they'll know what size you need. Mail order??
Life is a rollercoaster........and I'm not strapped in!
Reaver is offline   Reply With Quote
Old 12-27-2012, 10:40 AM   #1011
DoWorkSon
Oddometer: 113
Yeah, never occurred to me until it was too late... The local shop is not far, so It's not a big deal. But, sometimes online ordering is cheaper/more convenient...
Old 12-27-2012, 02:23 PM   #1012
itsatdm
NoMoTDM still Gary
itsatdm's Avatar
Oddometer: 3,709
I recommend you do a few tire changes in the comfort of your garage. I can't count the number of pinch flats I went through until I learned the tricks of the trade. Good practice when there is no tire shop nearby.
Breaking the bead on the rear is a chore. See if you can do it with your tire irons. I could not until I got a long one.
itsatdm is online now   Reply With Quote
Old 12-27-2012, 05:00 PM   #1013
dirtysouthjacket
dirtysouthjacket's Avatar
Oddometer: 429
What he said. It never really clicks, regardless of what you read, until you try to do it yourself. Also, before you even think about taking any tires off to practice, make sure you have PLENTY of extra tubes. Not just one!
I read these to start...
http://www.advrider.com/forums/showt...ht=neduro+tire
http://www.clarity.net/~adam/tire-changing-doc.html
Then I went out in the garage on a day that I had nothing else to do, and started swapping tires and tubes on my KLR. The first time you will be learning how to take your wheels on and off and redoing the chain tension. I did the front first (its easier I think) and had no issues once I figured out how to get the tire on and off. I then did the rear. I pulled the rear, swapped tires and couldn't get it to inflate. Put a hole in the tube with a tire iron. Went to Cyclegear, got ONE tube. Went home and promptly put a hole in that tube. However, the leak was slow enough that I had got it back on the bike and chain tight when I realized it was losing air. Went back to Cyclegear and bought the last remaining tube they had in the size I needed. At this point, I'm peeved and in a hurry. I furiously speed the tire on and off and put another hole in that tube. I contemplated setting the garage on fire at this point. It had been a long time since I've been that pissed in the garage. Went to Walmart and bought a patch kit and used that and carefully put the tire back on. The following week I got my tubes in I had ordered, swapped to a new tube carefully with no issues.
Point is, you need to practice in the garage, so you know what you are doing if you have an unexpected flat. Good luck!
I may not have gone where I intended to go, but I think I ended up where I intended to be. -Douglas Adams
2011 F800GS Alpine White, 1998 KDX 200, 2000 KL250G Super Sherpa
DSJ's Shenanigans
dirtysouthjacket is offline   Reply With Quote
Old 12-27-2012, 05:20 PM   #1014
PatrickM
Oddometer: 170
Is there a link for the $75 Accelerator plugin?
PatrickM is offline   Reply With Quote
Old 12-27-2012, 08:23 PM   #1015
itsatdm
NoMoTDM still Gary
itsatdm's Avatar
Oddometer: 3,709
Good question: When I bought mine, I got it straight from the manufacturer: http://www.sol2.be/Performance/ENG/Order/index_BMW.html
Since then North America got turned over to a vendor in South Africa? The short version, that works just as well, is not available from the vender and Mark won't sell here.
Old 12-27-2012, 11:37 PM   #1016
DoWorkSon
Oddometer: 113
I ordered directly from that site a few weeks ago. It took about 2 weeks or so
Old 12-27-2012, 11:37 PM   #1017
DoWorkSon
Oddometer: 113
Thanks... I forsee some swearing and throwing of tools.. I know it's necessary to practice... Just dreading doing it
Old 12-28-2012, 07:54 AM   #1018
dirtysouthjacket
Oddometer: 429
Its not bad once you figure it out, no need to dread it. Just think about how much money you'll be saving and knowing that the job was done right. Good luck!
DSJ's Shenanigans
Old 12-28-2012, 01:40 PM   #1019
runnin4melife
Oddometer: 488
I suggest using a piece of cut up tubing that you can put between your rim and tire when using irons unless you want to scuff up your rims. This method has worked much better than rim savers for me but it is user dependent I guess. Also talc up your tube. Some people say it doesn't matter but I have had issues in the past. If it is wet out just roll with it until you can do a proper fix.
Old 12-30-2012, 06:41 PM   #1020
Vettel
Vettel's Avatar
Oddometer: 20
This is a damn good thread and I have read every page. Thank you all.
Vettel is offline   Reply With Quote
Times are GMT -7.   It's 07:05 AM.
